Can I build my screen before installing projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-26-2011, 12:42 PM - Thread Starter
Seminole94's Avatar
I have my room complete except for the screen. I am painting the wall with Sherwin Williams Pro Classic Satin White. Am I safe to frame it with my black molding by the 16:9 screen sizes listed on Projector Central for my desired size? Or is it safer to install the screen, shoot the image to the wall and mark the size at that time? Thanks in advance for the help!
Seminole94 is offline
post #2 of 3 Old 06-27-2011, 04:46 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1768 Post(s)
Liked: 806
If one can hang the PJ first and shoot/mask off the desired Image perimeters, that always allows for the easiest "do" and an assurance that there will be no surprises as far as formatting your image size to the desired screen size.
MississippiMan is offline
post #3 of 3 Old 06-27-2011, 07:27 AM - Thread Starter
Seminole94's Avatar
Thanks! That is all I needed to hear. I appreciate it!
Reply DIY Screen Section
