Retroreflective paint or spray for DIY high gain screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-11-2011, 01:08 AM - Thread Starter
Russell Burrows's Avatar
Quoted: 16 Post(s)
Any body using this stuff for DIY screens??
Russ.
DIY beats store purchased.
Russell Burrows is offline
post #2 of 8 Old 08-11-2011, 06:23 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
I looked into this and asked about it. I was told it would be next to impossible to get it even. After looking at a manufactured retro reflective screen surface under a micro scope I agree.
I even ordered some samples of a product used for making lettering for trucks and signs. That stuff did not work for screen use either.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 8 Old 08-11-2011, 07:20 AM
threed123's Avatar
Liked: 39
The beads you can get tend to be too big for screen projection and tend to make the image smear (fuzzy) from what I've read in the past. Dalite uses micro-bead process for their High Power screen that does the right job for relatively low cost.
threed123 is offline
post #4 of 8 Old 08-11-2011, 09:42 AM - Thread Starter
Quoted: 16 Post(s)
What size in microns are the Da lite beads??
I am noticing many new products using microbeads:
http://www.dcpindia.com/reflective.htm
post #5 of 8 Old 08-11-2011, 10:59 AM
threed123's Avatar
Liked: 39
I can't find any specs on the High Power,however, I know from past that the beads are embedded in a special emulsion that clings to vinyl and is washable. I think it's more than just beads, you have to have an suitable emulsion to evenly spread the beads across the screen surface. I'm guessing this emulsion would have to be transparent to avoid uneven light reflection and over a white vinyl surface for uniform color characteristics.
I encourage trying to to duplicate yourself, but get ready for lots of frustration. Mica angular reflective craft paints (and aluminum in some cases) mixed in white/grey wall paint and Minwax Polycrilic as described on this board are proven choices and work very well--without the need to experiment.
post #6 of 8 Old 08-11-2011, 01:56 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Here are a couple of up close and personal photos of the dalite fabrics.
discontinued 2.8 and 2.4.. better to just buy the screen if this is what you want.
Doug
post #7 of 8 Old 08-11-2011, 02:28 PM
threed123's Avatar
Liked: 39
Excellent Doug. Note how the beads are about 1/3 exposed--very important.It would be very difficult to create an emulsion (paint--probably not, maybe a polyurethane) this thin without technology.
post #8 of 8 Old 08-16-2011, 01:38 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
The RR properties inherent on a DaLite HP Screen (...both good & bad...) can be effectively duplicated by using certain Silver Metallic paints that are partially masked with a translucent emulsion
DIY'ers have created some real "Beamers" with extremely narrow viewing cones...however most of such screens were intended for pretty low lumen PJs ensconced on narrow rooms with limited seating.
You can find many materials that have similar properties, but very few that will not bounce the PJs reflection back at you like a searchlight reflecting off a Mirror.
MississippiMan is online now
Reply DIY Screen Section
