Alternative for Sherwin-Williams ProClassic? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-13-2011, 03:03 PM - Thread Starter
K4i
K4i's Avatar
Another long time (years and years) lurker, first time poster; you know the drill.
I have had my Panasonic AX200U (bought 3 years after reading the positive reviews here) hanging from the ceiling and projecting to a white concrete wall for years and finally found the time to improve the screen quality.
So, after hitting up the DIY Screen area and spending hours upon hours reading, I decided to start with the Sherwin Williams ProClassic Smooth Enamel Satin Finish Extra White in a 6260 UNIQUE GRAY tint (since I have some ambient light). Simple enough, or so I thought.
Much to my disappointment, I found out that the ProClassic line is not available in Central America (that's where my wall is). I have checked with every Sherwin Williams distributor in the country and the answer varies between "forget about it" and "maybe, if you wait 45 days for delivery."
I'm looking for an alternative starter paint suggestion which might be a little easier to find. I'm fine with a higher price tag but spraying or mixing more than 3 components is outside my comfort zone. Thanks.
K4i is offline
post #2 of 6 Old 11-13-2011, 07:24 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2169 Post(s)
Liked: 981
Not much you can dependably alternate to and stay within the boundaries of a simple mix.. Personally, I have shipped paint World Wide so if you need help in getting some SWPC, just PM me and I'll see that you get hooked up.
MississippiMan is online now
post #3 of 6 Old 11-14-2011, 10:15 AM - Thread Starter
K4i
K4i's Avatar
I can probably get it shipped down here if it is not flammable. Would it be better to have it shipped already tinted or do the tinting locally?
Know any online sellers of SW paint perhaps?
K4i is offline
post #4 of 6 Old 12-13-2011, 02:47 PM - Thread Starter
K4i
K4i's Avatar
I ended up buying some in Miami and shipping it down, should anybody want to know.
K4i is offline
post #5 of 6 Old 12-13-2011, 02:52 PM
Liked: 981
That's cool...but tell us more. What did you get? Have you applied it yet? How did you apply it? What were your end results?
WHERE THE "ELL ARE YOUR SCREEN SHOTS !!!!
post #6 of 6 Old 12-22-2011, 01:30 PM - Thread Starter
K4i
K4i's Avatar
I had one coat of SW primer pained with a 1/4" NAP about a week ago and I had a second layer of primer and the first layer of ProClassic pained today. I am going to wait for it to dry for a few hours and then turn on the projector and see how it compares to my previous plain white wall.
What the typical number of coats needed? 2-3?
K4i is offline
Reply DIY Screen Section
