lost on what to use to build screen need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-21-2011, 05:05 PM - Thread Starter
hartastic's Avatar
just bought an optoma gt750 and im wanting to make a 120" screen.
the biggest blackout fabric i could find was 54" wide so the biggest screen i could make was 100"
everything seems to bright like theres a white haze. is there a better material to use? i dont want to spend alot of money but i want the best picture i can get for around $100 or less. theres no ambient light in the room also. and i cant paint the wall itself im mounting the screen infront of 2 windows. thansk for the help
hartastic is offline
post #2 of 4 Old 11-22-2011, 10:44 AM
Lop_posse's Avatar
There are other materials out there, but if you want blackout cloth in larger sizes, try an ebay search for "blackout cloth".
Lop_posse is offline
post #3 of 4 Old 11-23-2011, 10:10 PM
1Time's Avatar
Painted Sintra would work well for your situation, projector and budget. Or check out painting this substrate - http://www.avsforum.com/avs-vb/showthread.php?t=1356321. If you can't get those materials, you could paint the BOC. Just make sure you can re-stretch it after painting. The paint that I would use - http://www.avsforum.com/avs-vb/showt...4#post11975374.
Also considering your projector's specs, I wouldn't want a screen larger than 100" unless the viewing distance is over 15'.
1Time is offline
post #4 of 4 Old 12-12-2011, 09:54 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1823 Post(s)
Liked: 833
Stick to the "Sintra" suggestion. It's well founded.
MississippiMan is offline
Reply DIY Screen Section
