laminate DIY for start up screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-03-2012, 07:52 AM - Thread Starter
pb74's Avatar
I'm building a DIY home Theater and planning to use as a projector either a SONY VPL HW30ES or JVC RS40U. because I'm running out of money I need to do a $100-200 DIY screen.
I read about the laminate Designer White D354-60 that I can find easely at Lowes. Should I need to prime it or paint? ( white or grey ??)
The room is light controlled but I'm not sure the right color to pick
pb74 is offline
post #2 of 8 Old 01-03-2012, 11:50 AM
Jim McC's Avatar
Quoted: 157 Post(s)
Liked: 64
Do not paint it, it's ready to go. Make sure you get the matte finish. I'm using the Designer White and it's been great.
Jim McC is offline
post #3 of 8 Old 01-03-2012, 02:52 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2030 Post(s)
Liked: 898
Your gonna push that budget to the limit, and perhaps your DIY skills, because the WA-DW will require a adequate braced frame.
Depending on where you live, 6mm Sintra Board might well be a better, more affordable and easier done DIY project. With a $200.00 max limit, you can "easily" construct a terrific screen, (...even paint it to suit your final PJ selection...) and it'll be one that shares none of the fragility or potential for hot spotting from the slight degree of sheen the Matte WA-DW possesses.
MississippiMan is offline
post #4 of 8 Old 01-04-2012, 05:37 PM
MadMyers's Avatar
Quoted: 205 Post(s)
Liked: 123
Regarding the DW laminate... does it "roll up"? How does one get it home?
I've ordered a sample already... looking forward to trying it out.
I'm going to dig further tonight, so perhaps I'll find it, but what's the best approach to attach it to a wooden frame?
MadMyers is offline
post #5 of 8 Old 01-04-2012, 05:56 PM
citizen arcane's Avatar
Quoted: 342 Post(s)
Liked: 10800
Yes, mine was delivered rolled up and it fit in the cab of my truck.
FWIW I velcroed mine to a 1" square aluminum frame - it came out perfectly and has been hanging for a few years now.
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
post #6 of 8 Old 01-04-2012, 05:57 PM
20fan's Avatar
... Altan
Mine came rolled up in a cardboard box. Check out my screen build thread in my sig.
20Fan
Ohio State Buckeyes- GO BUCKS !
My Aluminum frame build
20fan is offline
post #7 of 8 Old 01-04-2012, 06:44 PM
domingos38's Avatar
Quoted: 26 Post(s)
Liked: 38
what is the biggest piece of sintra i can buy?
domingos38 is offline
post #8 of 8 Old 01-04-2012, 08:04 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 57
5.5 x 10 (70" x 120") is VERY rare... but it does exist.
5 x 10 is much more common.... for 122" diagonal.
pb_maxxx is offline
Reply DIY Screen Section
