Can I do this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-14-2012, 10:37 AM - Thread Starter
punguy's Avatar
I bought a 72 inch 16:9 projector screen.it is just too big for my room. I want to have smaller display so can I use extra black tape to make the border on projector screen. I can't return the screen coz I bought from Craigslist.
punguy is offline
post #2 of 2 Old 01-14-2012, 08:24 PM
billybobg's Avatar
Quoted: 42 Post(s)
Liked: 46
Not sure this is germaine to this forum
Too big how? Is the room to short for the projector to fully fill the screen?
What type of tape are you planning to use? Perhaps strips of velvet could be applied.
Udder than dat, modifying commercial product is outside the perview of this forum.
Good luck.
Home Theater Man Cave: Onkyo 7.1 Klipsch LaScala Mains, Shortened LaScala Klone Center, Klipsch Academy Surrounds and Rears; Panasonic AE8000, Panasonic BDP 460, 117" DIY Screen.
Garage Man Cave: LaScala Industrial Splits; Second hand Denon Amp
billybobg is offline
Reply DIY Screen Section
