need help with my first attempt HT DIY screen!!!!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-24-2012, 05:15 PM - Thread Starter
deathinc's Avatar
Finally! after about a year I have moved to my new home. I was at first going to invest in building a dedicated HT rooms but I no longer have the resources to do so....at least for now . In the living room theres a custom made console for an old tube tv......house was build in 2007....imagine that lol. My wife and I were thinking about tearing it down but then I got an idea! I want to cut a hole inside of it, strip the ugly brown plaint and stain it with a nice dark red mahogany. The hole in the center is suprisingly near 16:9. it measures 57' high and 95" across. I think that gives enough space for a 105"-110" screen. I plan on having the inside walls covered with black velvet in order to get a good picture. The projector is going to be about 13" away from the screen.
Questions-
What materials do i need to paint the screen ?
What type of material do I use for the screen? plywood Sheetrock etc...
What size screen should i go for? Projector- Sony vpl-vw70
Need help finding a mount! (less than $40 if possible!)
Screen paint -silver fire v.2?
need help!!!!!!!!!!!
Av123 Onix Rockets RS1000 , AV123 RSC200 BIGFOOT, B&W WM6 White, Denon AVR-4311CI 9.2
DIY Stereo Integrity SI 18" Subwoofer X2, HTPC Running XBMC 14TB , Roku HD Player
Sony VPL-VW70 Pojector, Xbox 360 250GB, Yamaha RX-V573
deathinc is offline
post #2 of 4 Old 02-24-2012, 07:29 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
the current favorite substrate for painting is sintra/komatex. i just finished a screen painting with komatex
use projectorcentral calculator to see what screen size is supported by your projector.
i just bought this atdec mount for my epson 8100. very solid and sturdy built. i know it's over $40 but you get what you pay for. if you want a budget mount, get one of those monoprice mounts.
http://www.amazon.com/Atdec-TH-WH-PJ...0136868&sr=8-2
i am sure MM and/or maxx will jump in with paint advise pretty soon.
smokarz is offline
post #3 of 4 Old 02-27-2012, 09:52 AM
threed123's Avatar
Liked: 39
Read the MaxMudd thread for paint ideas. Can't go wrong with it.
threed123 is offline
post #4 of 4 Old 02-28-2012, 09:57 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
That's a real good shot of advice!
The Sony isn't much of a Light Cannon, being only 800 Lumens max, so RS-MaxxMudd LL is definitely called for.
It's also roll-able...but spraying will elicit the very best results. It also has the gain you will need so much.
Check with either a Local Plastic Sheeting Supplier (Piedmont or Larid) or a Local Sign making Shop for either Sintra or Comatex.
MississippiMan is online now
Reply DIY Screen Section
