recomended screen form sony vpl-vw70 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-05-2012, 08:53 PM - Thread Starter
deathinc's Avatar
I have sony vpl-vw70 projector. I want to make a 105'-110" screen. projector will be shooting about 13' away. I want the best picture possible. I would prefer if I could use it with ambient light.
Av123 Onix Rockets RS1000 , AV123 RSC200 BIGFOOT, B&W WM6 White, Denon AVR-4311CI 9.2
DIY Stereo Integrity SI 18" Subwoofer X2, HTPC Running XBMC 14TB , Roku HD Player
Sony VPL-VW70 Pojector, Xbox 360 250GB, Yamaha RX-V573
deathinc is offline
post #2 of 8 Old 03-06-2012, 04:36 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1768 Post(s)
Liked: 806
You can make that size screen easily enough, but because the Sony has such a dearth of Lumens (800 w/new Bulb), any real Contrast enhancement will be had primarily during dark room conditions. Yes, ambient light performance will be improved over any "White" screen, but controlled and purposefully directed lighting will still be required for best results.
The Sony would be best served with RS-MaxxMudd LL
MississippiMan is online now
post #3 of 8 Old 03-07-2012, 12:27 PM - Thread Starter
deathinc's Avatar
do you recomend the SILVER fire screen? If so what version?
deathinc is offline
post #4 of 8 Old 03-07-2012, 02:05 PM
Liked: 806
No, as previously stated, RS-MaxxMudd LL (Low Lumen)
post #5 of 8 Old 03-07-2012, 07:48 PM - Thread Starter
deathinc's Avatar
Sorry for my ignorance but why the RS-MaxxMudd LL ? I see that there is two more versions , RS-MaxxMudd v.2.1 and RS-MaxxMudd Retro v.2.1. The sony is a very low lumen projector wouldn't it be better to go with the high contrast screen?
deathinc is offline
post #6 of 8 Old 03-08-2012, 06:18 AM
Liked: 806
While having a high contrast surface is almost always a plus, such surfaces do tend to attenuate light reflection. If you start out with low lumens, then that will mean even less reflection.
The "LL" is designed for low lumen output PJs. It contains enough contrast enhancement additives to help boost performance, but maintains a high gain factor of 1.4. This then also allows one to use Low Lamp, a setting at which that Sony units deliver their best contrast at.
Now yeah...the v2.1 / v2.5 Silver Fire apps do have significant gain while being pretty deep shades of Gray ( N 6.0 - 7.0) but even with that, they were developed with the latest 1600 lumen + PJs in mind. RS-MaxxMudd has always been about maximizing the lumens at hand.
When I come across and am dealing with a SXRD or LyCos PJ that has good native contrast without employing the Iris feature, I like to keep lumens at levels that don't work against the PJ's contrast efforts. Also, what with the smoother image such SXRDs and LyCos PJs are capable of, the potential for "graininess" that comes with needing auspicious amounts of reflective material in such darker paints often worries me just enough that I always consider the next step beforehand..
I'm usually just worrying for no reason...but when I think I have no worries, then along comes a Eagle Eyed person who can spot a freckle on a Fly's leg.
Everything else can be outstanding...but should there be a hint of graininess in a bright blue sky, as viewed from any reasonable distance, than Crap....nothing else seems to matter.
We keep working on ways to maintain gain without introducing such "speck-ularity"...and we are lickin' the issue more and more. But when gain is needed...and lumens are in short supply, the known values of such mixes like RS-MaxxMudd LL always deliver as promised.
post #7 of 8 Old 03-08-2012, 08:42 PM - Thread Starter
deathinc's Avatar
can this be rolled on? or does it have to be sprayed?
deathinc is offline
post #8 of 8 Old 03-09-2012, 07:40 AM
Liked: 806
RS-MM LL is "roll-able", but spraying will always elicit the best possible results.
Reply DIY Screen Section
