Undo Goo Part 2 Or Parting is Sweet Sorrow - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 03-22-2012, 05:24 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 57
Originally Posted by Crescent View Post
Are either of these flexible materials?
yes they are flexible...no less flexible than laminate. 3mm can roll into a 24-30" roll. 6mm not quite... but still quite flexible enough to bend around a 90 degree angle.
pb_maxxx is offline
post #32 of 36 Old 04-06-2012, 12:38 PM - Thread Starter
Crescent's Avatar
Thanks to all.
For now, I decided to try Da-lite da-mat cut to order screen material via AVS.
My home improvement buddy was unfamiliar with sintra or PVC board.
Crescent is offline
post #33 of 36 Old 04-06-2012, 08:24 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2182 Post(s)
Liked: 982
And he was "more" familiar with the Da-Lite material?
Good luck then.
MississippiMan is online now
post #34 of 36 Old 04-07-2012, 08:40 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Thanks to all.
Good luck bud. What ever makes you happy. In the end, it's the only FACT that matters.
smokarz is offline
post #35 of 36 Old 04-14-2012, 02:34 PM - Thread Starter
Crescent's Avatar
Good luck then.
These words turned out to be prophetic. The screen material was very thin and "stretchy". It was very difficult to get all the wrinkles out. It took about two hours to install and could very easily have been ruined during the process if extreme care had not been taken.
I'll let you know the results after watching it a while. But in retrospect, I probably should've researched the PVC board more, uncertain. Since my buddy had never heard of it, I assumed it was not available at the nearby Lowe's or Home Depot. At least now there are no rollermarks or uneven spraying splotches to content with.
Crescent is offline
post #36 of 36 Old 11-17-2012, 02:45 PM - Thread Starter
Crescent's Avatar
This is the follow up. After 8-9 months, I'm convinced this was the best way to go for me. No visible blemishes, reasonably inexpensive DIY solution. Installation is slightly tricky, you'll need more than one person. However the results are very good.
Parting with the CRT was sweet sorrow. It served me well for many years. Couldn't even give it away. But undo goo with screen fabric.
Crescent is offline
Reply DIY Screen Section
