One paint - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 04-04-2012, 07:51 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1775 Post(s)
Liked: 809
Originally Posted by damthrill View Post
Is there not any local store at which I can buy this pearl other than menards or online? I am on west coast.
Nope.
You can try Dutch Boy Pearl Luster #DB1201 if you have an actual "Dutch Boy" Store. They will probably have to order it though.
Really.....getting it via Amazon is the best possible route to take.
MississippiMan is offline
Old 04-04-2012, 07:55 PM
Liked: 809
I am non partisan in this topic. But I have asked a couple of times what the fabric costs. How much is it for a 92 inch screen worth of material? You must have some idea? I can tell you that I will try both. But, there is so much more flexibility in paint.
As a matter of fact, all fabric has color in it which is a form of paint.
What does MFG stand for?
I will also not entertain fabric if it is going to get into the hundreds, I just won't. Otherwise I will also try a fabric screen. But first is paint period.
I am wondering if I should have just got the $12 board instead of the Plas Tex? Will the plas tex sit fine with just one 1x4 in the middle? the twb seems stiffer.
I just wish I had some time to start assembly of the frame.
Go to http://www.rosebrand.com/category12/...n-screens.aspx
Be inventive.
