Sherwin Williams - Is it available in Europe? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-10-2012, 12:14 AM - Thread Starter
darbid's Avatar
Hi Everyone,
After reading the review of the ProClassic Smooth Enamel Satin at projector central I have been trying to find it in Europe, in particular in Germany.
I don't think I have missed a thread on this but it may be I have. So has anyone from this side of the world found a supplier of this paint?
Thanks in advance.
darbid is offline
post #2 of 6 Old 04-10-2012, 02:18 AM
Kirnak's Avatar
You want the Dulux "light and Space" with Lumitec technology. Velvet Matte. Here's a good thread for you to read: http://www.avsforum.com/avs-vb/showthread.php?t=1310840
Also, google the European forums on the Dulux paint.
Kirnak is offline
post #3 of 6 Old 04-10-2012, 03:02 AM - Thread Starter
darbid's Avatar
Hi Kirnak and thank you for tapping out a response. I am aware of alternatives (some years ago i even mixed some paints together), but given what projector central has written I would like to try the brand and type I have written about.
Unless the Dulux product is an exact copy or just rebranded I am still interested to hear from people who know if SW distribute in Europe.
darbid is offline
post #4 of 6 Old 04-10-2012, 07:41 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1773 Post(s)
Liked: 808
No it is not.
The Dulux Lumitec paint Kirnak suggests is the brightest "matte" paint I've found "over there".
Specifically, it's called "Ultimate White". The "Light & Space" designation is a grouping of products that represent the Lumitec technology.
Don't tie your hands by feeling that just because the PC article stated how good that specific paint is that it's the only applicable choice. Instead, read where the main criteria was to find a "roll-able" paint.
BTW...the Dulux paint is EXTREMELY thick, and in my opinion requires a bit of thinning with pure water if rolling, and a LOT of thinning if your going to spray.
MississippiMan is online now
post #5 of 6 Old 04-10-2012, 08:05 AM - Thread Starter
darbid's Avatar
Thank you Granddad,
Your experience in this section is easily identifiable.
I will have another look at the Dulux stuff. I am pretty sure last time I used it along with some other ones.
I have written to SW to once and for all check. Also if I find my self in a country that does sell it, I might get it there.
darbid is offline
post #6 of 6 Old 04-10-2012, 08:28 AM
Liked: 808
By all means, do check. It would not be the first time someone did so and uncovered a revelation. Learning can come from any direction, and often from those wholly unknown to those supposedly "in the know".
Reply DIY Screen Section
