Cheap screen help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-24-2012, 03:11 PM - Thread Starter
langers_2004's Avatar
Hi all,
Need some help with my very cheap screen. I bought a roller black out blind from ikea and it was performing amazingly, but i now have these ripples showing on pan shots. They werent there before, im thinking that it is obviously slight waves in the material. The blind gets rolled up after use everytime so was hoping it would "iron" out the creases after each use.
I only paid £30 for the blind and really dont have a lot of funds so need some advice from another budget user.
Im using an optoma gt750.
langers_2004 is offline
post #2 of 15 Old 04-26-2012, 10:00 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1766 Post(s)
Liked: 806
Originally Posted by langers_2004 View Post
Hi all,
Repeated ironing of vinyl material isn't going to work for long...because the degree of heat required each time will further deform the material. Stretching the material slightly during use is the better solution.
The best suggestion is to try attaching a weighted bar across the bottom edge of the material when it's lowered, and when rolling it up, do so with care so as to make it roll up as evenly as possible.
MississippiMan is online now
post #3 of 15 Old 04-26-2012, 11:48 AM - Thread Starter
Ok spot on thanks. So replace the wooden bar with something heavier. Its a very big blind so i thought the weight of itself would stop these waves but clearly not.
post #4 of 15 Old 04-26-2012, 05:29 PM
Bushi's Avatar
I have a similar setup in that it's a screen hanging with a weight on the bottom. It is clear from experimenting that the ripples are caused because there is no lateral stretch.
This might be super ghetto for you but you could fashion some kind of clips on elastic to clip to the edges of the blind and pull the sides. Think binder clips on long rubberbands connected to a wall or something. You'd want it to pull straight and in the same plane but it would probably work. The more the better. I haven't tested something like this because the walls I would need to attach to are brick.
This opinion is from the mind of a poor college student. Binder clips on rubber bands wouldn't be the most ghetto thing I have jury rigged up.
Edit: Also, if you are looking for long cheap weights, places like Lowes have really cheap wood yard sticks for <1$ a piece that have some decent weight. You could try hanging those on the bottom.
Bushi is offline
post #5 of 15 Old 04-26-2012, 07:45 PM
The big picture's Avatar
Electrical and other types of conduit, comes in long lengths and I have seen it in 1-inch thru 2-inch dia for cheap. You could fill it with cement, sand, pennys, nickels or whatever, then cap the ends. This would make for quite a heavy bar.
The big picture is offline
post #6 of 15 Old 04-27-2012, 05:52 AM
Liked: 806
Nickles!
I wonder what that would amount to?
post #7 of 15 Old 04-27-2012, 06:02 AM
Archaea's Avatar
Quoted: 2846 Post(s)
Liked: 2427
You should just make a wood frame, buy a staple gun and 1000 staples, cut the blind off at the top and stretch it over the wodden frame. The results will be everything you want and the project won't cost over 100 bucks.
Archaea is offline
post #8 of 15 Old 04-27-2012, 06:51 AM
Liked: 806
You should just make a wood frame, buy a staple gun and 1000 staples, cut the blind off at the top and stretch it over the wooden frame. The results will be everything you want and the project won't cost over 100 bucks.
That would be an obvious thing to do, however it seems that the use of a inexpensive Roller Blind was specifically intended because of a need to roll up the screen between uses.
Bushi gave a suggestion that parallels what a Tab Tensioned screen dies...pull "sideways". But also once again, the need for langers_2004 to roll up the material, and the lack of a design/enclosure to accommodate any DIY Pins & Bands and Strings makes that a unworkable solution.
No...langers_2004 only real hope is that a significant amount of added weight across the bottom will reduce if not wholly elliminate the existing waves he's getting.
If not....then perhaps he will be willing...if not sooner then later....getting something / making something that will be more appropriate for his needs.
post #9 of 15 Old 04-27-2012, 12:47 PM - Thread Starter
Great ideas :-) The sode supports would be brilliant but one side of the screen is the door to the room so not a great solution lol
Perhaps i will try weights in the bottom of the screen. The screen rolls down infront of my plasma so it needs to roll up again :-)
I think i will try lots of 1p coins or 5p coins in the bottom. Or perhaps i could fill rubber glove fingers with cement and thread these in?
I assume stapling this blind to another blind would not be an option? In the effort to make it thicker.
post #10 of 15 Old 04-27-2012, 06:18 PM
How big is the screen ?
There are threads on this forum by people that have made fold-up-and-away screens.
The top edge is hooked to the ceiling with a hinge so you can swing it up and down. When not in use, it is swung up to the ceiling and the bottom edge has a clasp/lock that holds it in place.
This would allow you to use a rigid frame for your screen.
post #11 of 15 Old 04-30-2012, 05:51 AM
Liked: 806
Yeah...I'd like to see the OP go solid......but it seems that a Roll Up is preferred.
It seems he's living in "Ol Blighty", and if so...and he's in a CITY sized "Flat" or "Walk-up" he just might have problems using the ceiling for "Fold Up" storage.
Not a lot of sizable real estate over there for most people unless they be Lords or Ladies.
......or Football Club owners.
post #12 of 15 Old 04-30-2012, 08:59 PM
I see your point MississippiMan, and I think I have the solution.
The all new, MM-Murphy-Screen-Bed...Theres a 120 inch silver monster under your bed, and we call him..MississippiMan...LOL
post #13 of 15 Old 05-01-2012, 03:30 AM
Liked: 806
Under the bed, in the closet... you gotta hide when you gotta hide where you gotta hide,
....... but Monster? Well, I suppose I have been called worse.
post #14 of 15 Old 05-01-2012, 12:44 PM
No, you are not a monster, in fact, when theres a problem, you are our #1 demon killer.
post #15 of 15 Old 05-01-2012, 03:06 PM
Liked: 806
Originally Posted by The big picture View Post
No, you are not a monster, in fact, when theres a problem, your our #1 demon killer.
I represent that remark....nuk...nuk...nuk...nuk...nuk.
Reply DIY Screen Section
