vivitek qumi which version of silver fire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-04-2012, 05:41 PM - Thread Starter
cakegetter's Avatar
Hey guys what version of silver fire do I need for best daylight viewing with the qumi? I plan on mounting it about 12 feet from the screen. Thanks in advance.
cakegetter is offline
post #2 of 6 Old 05-04-2012, 09:01 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1763 Post(s)
Liked: 806
Don't thank me too soon.
That PJ will be at a distance that....while giving you a 106" diagonal image, will also only be providing 9 foot lamberts.
It's only a 300 Lumen unit, and as such you need some real gain.
Easiest suggestion? RS-MaxxMudd LL
Best choice? See Easiest Suggestion
Wisest path to take? The Best choice and a PJ placement of 10' 4" (92" diagonal & 15 fl.)
Silver Fire determined? SF v2.5 2.0 @ 92" diagonal
You could get another one a stack them.....
MississippiMan is online now
post #3 of 6 Old 05-04-2012, 09:17 PM - Thread Starter
cakegetter's Avatar
Thanks MM I appreciate it, Do you have another LED suggestion? How about the optoma ml500? it's 500 lumens.
post #4 of 6 Old 05-04-2012, 09:29 PM
Liked: 806
I like the Optoma best...but even so, ambient light resistance is dependent of optimizing PJ'd Light received as opposed Ambient light. An effective amount of PJ's light must be available to drive into a Gray'd surface w/gain or it's not gonna do much good.
Screen size will still tell the tale....and I'm hatin' myself for being the one to tell ya to go smaller. With the "O" you can manage 106" and use a SF 2.5 2.0 but you still have to try to manage ambient light sensibly. 92-96" diagonal would be all the more reasonable to shoot for.
post #5 of 6 Old 05-05-2012, 09:57 AM - Thread Starter
cakegetter's Avatar
so 96" with the optoma ml500 and rsmaxxmudd or silverfire v2.5 2.0? I sent you a PM by the way MM.
post #6 of 6 Old 05-06-2012, 04:04 AM
Liked: 806
Yes. RS-MaxxMudd LL will provide the most gain....SF 2.5 2.0 the most Contrast boosting and ambient light resistance.
Reply DIY Screen Section
