Heavy(Thick)Spandex for S-I-L-V-E-R - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-08-2012, 04:44 PM - Thread Starter
The big picture's Avatar
Is there a white heavy weight spandex or somthing else with a very smooth surface, not BOC, in 120" width, that you could paint S-I-L-V-E-R straight on top of, without a need for primer ?
Would like a material that is thick enough so it does not need to be doubled up, to prevent light bleeding through the backside. I can only find real thin stuff in local stores.
The big picture is offline
Reply DIY Screen Section
