106" 2.35 = what size 16x9? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-24-2012, 07:51 PM - Thread Starter
junglalien's Avatar
I have 106" 2.35 screen. If I was to put the same image on 16x9 screen with black bars what would the diagonal be?
junglalien is offline
post #2 of 5 Old 05-24-2012, 09:03 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2117 Post(s)
Liked: 960
How tall is that 2.35'er. Are you describing the actual screen width as being 106"?
Best guess if 106 is "width"?
82" diagonal
MississippiMan is online now
post #3 of 5 Old 05-24-2012, 09:16 PM - Thread Starter
junglalien's Avatar
106" diagonal, 96"x 41" which is closer to 104".
post #4 of 5 Old 05-24-2012, 10:03 PM
Brad Horstkotte's Avatar
Liked: 72
41 / 9 *16 = 72.9" wide
83.6" diagonal (http://www.calculatorsoup.com/calcul.../rectangle.php)
Edit - nvm, misread the question - you want the diagonal of the 16:9 screen that would fit the same size image as your current 2.35:1? That would be: 104" wide x 58.5" - 119" diagonal 16:9 screen
Brad Horstkotte is offline
post #5 of 5 Old 05-24-2012, 11:14 PM - Thread Starter
junglalien's Avatar
Thanks Brad!
Reply DIY Screen Section
