A little overwhelmed..could use some DIY SCREEN guidance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-28-2012, 09:33 AM - Thread Starter
tbcq715's Avatar
Greetings! I am about to delve into the world of home projection. I have been scouring this website for two days and am a little overwhelmed at all the incredible info!
Here's what I have:
Epson Pro6010 Projector
A 11' x 19' room...completely light controlled.
I need to paint on my screen. If I use the MaxxMudd paint scheme, which one would I need to use? Are there any comparable kits that I can buy that produce the same quality screen? Being that the 6010 is supposed to have such good contrast, which gain should I use? Or should I go SilverFire??
One other question. Unless I settle for much smaller screen, i can not place front left and right speakers to sides of screen. Is below screen, in-line with center, ok?
tbcq715 is offline
post #2 of 4 Old 05-28-2012, 10:22 AM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
Going with speakers under the screen may work out well. I don't have any comment on the paint to use though. I have always been a person to just do a quick one paint job on busy weekends. Ultra bright white or Silverscreen had been my choices, but I have heard that these other formulas can really make the image pop. I don't personally know and have been pleased with what I had done. Good luck with the project. It will be very rewarding in the end. All of mine had been.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
post #3 of 4 Old 05-28-2012, 10:39 AM - Thread Starter
tbcq715's Avatar
nm
tbcq715 is offline
post #4 of 4 Old 05-29-2012, 08:31 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1768 Post(s)
Liked: 806
Welcome tbcq715!
I see you joined up well over a year ago, so by now you must have read a lot!
The 6010 is a great PJ, and needs little in the way of actual contrast boosting assistance iin a light controlled setting. However if your considering usiong the 3D option, it would be good to consider going with a Paint option that maintains at least 1.2-1.3 gain.
RS-MaxxMudd LL would be an excellent choice. Be advised that there are NO commercially available "Kits" to paint screens that will cost anything remotely as little as RS-MM-LL, and few will provide anything nearly as worthy for all that extra expense.
A few other considerations.
You did not mention what size screen you want to go with (...to keep the speakers below the bottom of the screen...) nor the expected / necessary throw distance?
Or the ceiling height and ceiling / wall colors.??
Ecven with the 6010s performance envelope, if you get undue reflections off the adjoining walls and / or ceiling, even in a fully darkened room the reflections can noticeably reduce black levels and overal contrast. While this isn't a issue watching very dark content (obviously), when you get a bright image that also has dark elements contained within, colors and blacks can get washed out.
I really don't thing going with a darker gray would be as conducive to obtaining a "best" results as would be effectively controlling reflections heading back toward the screen's surface. The ceiling is usually the biggest offender, but closely adjacent side walls can be pretty annoying as well.
Let's keep up the dialog!
MississippiMan is online now
Reply DIY Screen Section
