Best screen for a DLP projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 05-28-2012, 08:46 PM - Thread Starter
newguy12345's Avatar
so i finally decided to go with the benq w710st. its a DLP model and i hears white paint or blackout cloth don't work well with these. so what paint or cloth would work well with this? as soon as i know this i can buy the materials and make it so please help. thanks guys.
newguy12345 is offline
post #2 of 23 Old 05-28-2012, 08:59 PM
narhic_fd's Avatar
Quoted: 72 Post(s)
what will your main uses for this projector be?? Will you be doing 3D with it??? What are your room conditions where you projector will be set up in??? How much are you willing to put into a screen??
narhic_fd is offline
post #3 of 23 Old 05-28-2012, 11:43 PM - Thread Starter
that's a no on the 3D. and my room is the basement. my man room i guess you can say. and i have it set up so it's pretty dam dark at 2PM in the afternoon. so no lighting. movies and games only. and how much? well since it will be homemade i guess it doesn't matter. i just didn't know what kind of paint or cloth etc. i would like to make one of each if there's the right materials paint wise and cloth wise.
post #4 of 23 Old 05-29-2012, 03:31 AM
setesh's Avatar
This is in no way advice or anything. But i have some kind of White PVC/Vinyl screen that i use, It was ok but washed out, painted it with some matte white paint tinted grey and its alot better (i have a benq w1060)
Im sure if your in the USA you can source some better stuff though.
setesh is offline
post #5 of 23 Old 05-29-2012, 04:03 AM - Thread Starter
it don't matter. i am hearing way to much about the "rainbow effect" that DLP projectors have. so i am going to be looking into a LCD model. but LCD models are known for input lag for gaming and that's a big issue for me. so i don't know.
post #6 of 23 Old 05-29-2012, 08:35 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
Get the Epson 8350 (...or overseas equivelent) as it has virually NO input lag
Where exactly do you live? That will have a lot to do in regards to providing any suggestions as far as screen materials and paint choices.
MississippiMan is online now
post #7 of 23 Old 05-29-2012, 02:58 PM - Thread Starter
i might go that rout. i will first try and find a DLP projector on display to see if my eyes on effected by the color wheel. and if they aren't then i am good to go if not then i will go with that 8350. i live in Michigan.
post #8 of 23 Old 05-29-2012, 08:02 PM
Liked: 806
I hate to be the bearer of either false hopes or gloomy predictions, so be advise that these are all "what if's" and "might be's".
Rainbow Effects are both subject to a Viewer's sensitivity to light strobing introduced by the color wheel. Faster speed wheels (5x) and those with more segements have less potential to produce RBE....but it's still there.
.....and, Content. How it's provided and at what Frame Sequence it comes over at....all can make SDE be consipcuolusly absent...or in your face. Seating Position can add a degree of enhancement.
Yes...you might be a hyper sensitive type to SDE....or just someone who see it on occasion, when the move their head quickly enough to catch up with the Frame rate for a fraction of a second.
Point being....theres no effective way to judge your true sensitivity to RBE unless you have the opportunity to view alot of varied content. Or....it hits you so hard at the beginning you throw up. That'll convince 'em every time.
No really...for some it just takes them a little bit of RBE and they get dizzy...nausious. Hmmmm...just like some people do when watching Shutter Glass 3D, or poor Passive 3D(...far less frequent)
Soooo...do I hate DLPs or sumpthin'. Not at all. Some of my best work was/is with DLPs. But certain limitations must be made apparent...leastwise as far as how I handle such, and if performance and cost outwheighs the risks.....and if one doesn't go bobbing his head like a dope all the time trying to "catch" a Rainbow, I don't hear much in the way of complaing these days with 1080p resolution, mega better contrast specifications, and higher speed Color Wheels, better Optics, insanely better Image Processing........well, it pretty much boils down to this;
If you chose a decent DLP with good features and specs, and can preview it adaquately, it should become apparent quickly enough to allow you to make a informed decision.
Otherwise.............
.............be done with all the indecision, get a Epson 6010 and fly away....fly away....fly away....fly away....fly away....fly away....fly away.............................
post #9 of 23 Old 05-30-2012, 02:40 AM - Thread Starter
well i am gonna get a DLP one first. then a month later i will get a lcd model. 3010 or something. but you didn't recommend any materials etc. cloth etc. lol
post #10 of 23 Old 05-30-2012, 10:44 AM
Liked: 806
What size of a screen are you thinking / hoping / praying for.
Anything under 100" diagonal and there are several inexpensive choices you can apply rolled or sprayed coats onto. Topmost...and least expensive would be Thrifty White Hardboard @ Home Depot ($11.00 for 4' x 8' x 1/8") Lowes also cares a similar product.
Larger screens than that require solid sheet material (1st choice), or Black Out Cloth stretched across a frame.
post #11 of 23 Old 05-30-2012, 03:10 PM - Thread Starter
um i want one screen at 100" and one at 120".
post #12 of 23 Old 05-31-2012, 05:10 AM
Liked: 806
For the larger screen the best possible choice would. be Sintra @ 120" x 60" cut to 107" x 60"
post #13 of 23 Old 05-31-2012, 04:40 PM - Thread Starter
that's a board? all white? or paint it or cloth? wanna make sure i get the full details.
post #14 of 23 Old 06-01-2012, 02:06 AM
Liked: 806
that's a board? all white? or paint it or cloth? wanna make sure I get the full details.
Sintra (also called Komatex) is a hard, smooth "expanded foam" PVC Sheeting material used extensively in the Sign Painting industry. There is also Gator Board, a similar product that is less dense, and covered on each side with a Laminated white paper.
The latter is more prone to denting but can be had for less expense. Both are available from Plastic Sheeting Supply firms. Relate where it is your live (closest City & State ) and it'll be easy enough to find a local Distributor and price it out for you.
Those materials are the ideally suited ones to use. But if not available, then there is always the old standby Black Out Cloth, but that route carries with it it's own particular caveats....frame building, stretching it taunt across that frame, priming and painting as well. To me, that choice is a "last resort" one.
Now neither of the aforementioned are grossly difficult, and all have their specific advantages....and issues. Of them all however, Sintra has the most advantages and least issues, with initial cost being it's only real primary issue.
I can advise...even irrevocably "state" what you should use, but in the end it's your choice based upon availability, work ethic, and of course, expense.
post #15 of 23 Old 06-01-2012, 04:36 AM - Thread Starter
the foam seems like a not as good as the other options. its foam and its exterior seems rough looking. maybe that's just me. lol. since i last talk to you i saw that people recommend getting a piece of drywall or paneling at lowes and use a really white paint. ultra type etc. but i think i am gonna make a screen that way or with cloth and have it be 100" for the optoma ml500 and buy a elite screen because there $200 bucks on amazon. which is affordable.
post #16 of 23 Old 06-01-2012, 04:42 AM - Thread Starter
i just saw a better picture of the sintra board. its not rough. lol it looks real smooth. but i guess it depends on the price and if i can get it in the proper size. and what paint for it.
post #17 of 23 Old 06-01-2012, 08:37 AM
Liked: 806
If you'd simply relate as to where you live, you could be provided enough information to be able to determine as to if Sintra was available, ad priced within your budget.
From my own experience, you could / should be able to get enough Sintra to do both screens for just under $200.00. But using Thrifty White Hardboard, the overall price could be as low as $130.00 for both screens.
The smaller one really needs to be done right, or that LED PJ isn't going to be nearly as capable of producing a vibrant image. Using Sintra, which itself has a slight sheen to it, you just might be able to use it "as is"....but that is definitely a "might be".....but for certain, you don't want to mess with Drywall, or consider any type of Wood paneling that is not ultra smooth and coated so as to not be absorbent.
The biggest screen is all about affordability "AND" performance, and I assure you that the Elite screen will not begin to deliver the same performance as a well made DIY screen costing the same....or less.
So it's up to you to determine who you want to listen to and whose advice you want to follow. My suggestion....read more, and focus on the posted results of those who have used painted Sintra and Thrifty White materials.
Once you determine if you want some specific advice, all the instructional help you need will be available to you off these boards.
post #18 of 23 Old 06-01-2012, 05:07 PM - Thread Starter
i live in battle creek, Michigan.
post #19 of 23 Old 06-02-2012, 12:52 AM
Liked: 806
Piedmont Plastics
7650 Caterpillar Ct. SW Ste B
Grand Rapids, MI 49548
Toll Free: 866-491-7898
Phone: 616-281-3654
Larid Plastics
3839 east paris ave se ste. 309
grand rapids, MI 49512
Manager:Mark Kaufman
Phone:800-873-8408
616-726-6350
Sabic Polymershapes
8233 Neptune Dr, Kalamazoo, MI 49009
30.0MI from Battle Creek
(269) 276-9825
Total Plastics Inc
2810 N Burdick St Ste A, Kalamazoo, MI 49004
25.0MI from Battle Creek
(269) 344-0009
Ask for Sintra or Komatex. (Gator Board as last resort)
6mm thick @ 48" x 96" & 120" x 60"
All locations will cut to order ....usually at N/C if not time sensitive
..............one or more of these locations is bound to have inventory.
Check prices and compare then all. I myself can usually get / arrange for people to get a "best price" from thier local Piedmont Plastics. I have no clout at any of the other Suppliers.
post #20 of 23 Old 06-02-2012, 01:28 AM - Thread Starter
cool i will make some calls. also since you a projector buff and have a ton more knowledge that i do, see if you can solve this. i posted this in the under the screen section. i will copy and paste it below.
i will be purchasing a elite screen soon but there are two different elite screen shops. both with different contact info and different numbers. and there prices are a little different as well. those links are after the first two. this is stupid. is one fake? or are they a bit slow and don't know what there doing? lol
http://shop.elitescreens.com/contact-us.aspx
http://www.elitescreenshop.com/contact-us-a/131.htm
http://shop.elitescreens.com/manualseries.aspx
http://www.elitescreenshop.com/produ...16-colon-9.htm
post #21 of 23 Old 06-02-2012, 07:47 AM
Liked: 806
newguy12345,
Glancing at the Page source info it's pretty obvious that it's all the same company, just a poor example of web site management
Elite seems now be determined to sell direct to the public, but also seems to be suffering from early direct sales start-up growing pains.
But why should we care? We have DIY screen applications that can meet or exceed the performance of any Elite screen. And if someone absolutely needs a retractable screen, well then go ahead and get one and we will tell you what paint to use, and how to paint it.
BTW....... Tab Tensioned Screens make great artist's palettes on which to paint a masterpiece upon.
post #22 of 23 Old 06-02-2012, 04:36 PM - Thread Starter
yeah since there screens are affordable i will be buying one from them and making one instead of making two. thanks for all the info. when i first came to this site i didn't know a dam thing about projectors or the screens or how to make a homemade one etc. and now i know a pretty good amount. thanks.
post #23 of 23 Old 06-03-2012, 05:44 AM
Liked: 806
If you get one in the size your wanting, be prepared for the inevitable potential of having waves or the edges curling inward. Elite is not a bad source, but any large Retractable can get wavy.
If your considering it being a Fixed Screen, then there is less of a concern, but it's not eradicated altogether. Nothing is more safe and secure than using a solid, hard substrate.....period.
Reply DIY Screen Section
