Need help with paint for screen... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-04-2012, 09:02 AM - Thread Starter
Aubs84's Avatar
I've read a bunch of threads on here and finally decided it would be best to sign up and ask...
I have an EPSON PowerLite 710 and it will be set at 10-11ft throw ratio. We have no windows in the room and wall is currently beige and we're very pleased with the picture already...
I'm building a frame out of trim, but what kind of paint do I need for the wall?
Thanks for any help
Aubs84 is offline
post #2 of 16 Old 06-04-2012, 11:54 AM - Thread Starter
Aubs84's Avatar
Btw, I'm just looking for a simple paint solution....not a complex mixture. I don't have a sprayer, so it will be rolled on.
Behr Silverscreen the way to go?
Aubs84 is offline
post #3 of 16 Old 06-04-2012, 02:16 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2142 Post(s)
Liked: 970
No.
Go into Home Depot:
Ask for a Glidden Master Color Chart...and look for:
00NN 45/000 . . . "Dover Grey" [N7.3]
Have it mixed into a good paint, one with good leveling characteristics, and apply it using good quality roller with a modicum of care, and you'll have a overall better Gray Screen than the Behr Silver Screen can provide.
With the EP-PL 710 you have the lumens...and it would seem a "not too big Screen", so even on Low Lamp mode (recommended) you should have a bright, vibrant image whose Blacks have been considerably boosted (ie: lowered) Just be sure to re-calibrate the PJ to the shade of Gray the screen is so as to maintain a bright whites as possible.
MississippiMan is offline
post #4 of 16 Old 06-04-2012, 02:38 PM - Thread Starter
Aubs84's Avatar
No.
Go into Home Depot:
Great, thanks. Any suggestions on said "good paint" to mix it with? I'm a total novice at this stuff and have blown away by the info on this board.
I really appreciate the help.
What does Low Lamp mode accomplish?
Aubs84 is offline
post #5 of 16 Old 06-04-2012, 03:14 PM
Liked: 970
PAINT: Glidden Professional White Base (Deep)
Low Lamp = Longer lamp Life....Better Contrast ...quieter Fan operation
post #6 of 16 Old 06-06-2012, 09:33 AM - Thread Starter
Aubs84's Avatar
Would black out cloth work better than using the paint previously discussed in this thread?
Aubs84 is offline
post #7 of 16 Old 06-06-2012, 06:02 PM
Liked: 970
Silver Screen can never be "correct" in how it provides a screen surface....color correct-wise. Bur "similar" shades of more neutral Grays can get the ball rolling. But...AA or any Gray is not a valid comparison...with their being "Gray painted surfaces"...not coated White Cloth. And "Gray" surfaces do things differently to a projected image, things they are intending to do. Black Out Cloth can do on;y one thing in common with any correctly painted surface....reflect an image. But it's not going to do so as effectively as even Silver Screen.
So would a Raw BOC Screen do as good or better a job than a "Color Corrected" Silver Screen?
Not a chance in the World. The ONLY possible advantage it has is that you don't have to paint anything. But then....you don't get much of anything anyway.
To be fair, for those opting for a pure BOC Screen, done right...stretched taunt...and hit with an exceptional image, it could be, would be...and is something wholly unexpected coming from...as it does...Light Blocking Material for Windows. But it falls short in many ways I'll not delve into here. Better, more luminous Projectors, better signal sources and content...all can make Raw BOC look better than it ever has....but where's the fun in knowing that it's still is working against providing the best image possible?
Painted upon, it can become something magical. There is the point to be made though that unless you "MUST" use BOC Material to construct a out-sized Screen ( 125" diagonal -up), there are many "more suitable" materials that can be considered....and a few of them need no painting. Imagine that?????
post #8 of 16 Old 06-07-2012, 09:49 AM - Thread Starter
Aubs84's Avatar
Good deal, thanks for all the help. We're using a little different trim around the edges because the Mrs. wants it to be a little prettier than everything she's seen online, but I hope to have this project knocked out by next week.
Knowing the pj I have and that it's in a room with no ambient light, what would be the ideal throw?
Aubs84 is offline
post #9 of 16 Old 06-07-2012, 11:41 AM
Liked: 970
With that PJ and no light issues (artificial produced....not reflective) a 11' throw can give you between a 100" and 120" diagonal image. 34 fls with a 1.0 gain surface. That's quite a BRIGHT image.
If you go with a non-reflective Gray screen surface with .8 gain, you'd curtail that down to 27 ft lambert reflectivity.
Move the throw to 12' and you drop to 25 fl. Not enough to warrant the PITA of moving an existing installation IMO. cool.gif
But be advised that all the aforementioned figures are based upon "Normal Lamp Output". On the much desired Low Lamp" setting, the 710 will produced it's deepest contrast, and combined with the .8 gain Gray surface and the abundance of lumens you'll have great Black Levels and shadow detail.....all with an image that looks "Back-Lit LED" like.
And did I mentioned 33% longer bulb life?
....I cannot see you being a Unhappy Camper after all is said....and done. wink.gif
post #10 of 16 Old 06-07-2012, 12:17 PM - Thread Starter
Aubs84's Avatar
Pardon my ignorance, but higher gain is better, right? Sounds like Low Lamp mode and a grey screen surface at 11 feet is perfect, right?
What are fls?
Mississippi Man, I can't thank you enough for all the help. I would've been lost...
Aubs84 is offline
post #11 of 16 Old 06-07-2012, 04:17 PM
Liked: 970
Often that is NOT the case. A brighter PJ hitting a "too High Gain" surface will make the screen produce so much reflectance that detail a subtle shadows are washed out or non existent. Contrast values (...the difference between the blackest "Black" and the brightest "White" or "Color"...) are dependent upon there being a degree of balance between the incoming light and the degree of reflected incoming light. A balance can always be reached....but one must make the effort to allow such to happen.
In this instance, that is what I would strongly recommend.
What are fls?
foot-lambert
noun
(Mathematics & Measurements / Units) a former unit of luminance equal to the luminance of a surface emitting or reflecting 1 lumen per square foot.
A completely reflecting surface illuminated by 1 foot-candle has a luminance of 1 foot-lambert Abbreviation ft-L
The amount of Reflection is adjudged by the numerical standard. The higher the "foot lambert" value, the brighter the screen is.
Sometimes I feel like a 3 legged Seeing Eye Dog. I try...honest I do....but I'm not really sure how good a job I'm doing unless i receive the occasional "pat on the head". tongue.gif
post #12 of 16 Old 06-28-2012, 10:40 AM
general001's Avatar
so i am a complete newb and have been reading this place like crazy when i came across this page. i myself have the same epson 710 PJ but am displaying a massive 160 diagonal at 15.5 trow. i recently moved into a new house and the walls are no longer conducive to projecting. (dark brown flat walls). the previous house has a light grey paint that was good. now am also looking into a DIY paint on screen for under 200 bucks and would love a suggestion similar to the one you gave above.
thanks
general001 is offline
post #13 of 16 Old 06-28-2012, 11:14 AM
Liked: 970
thanks
Is the wall to be considered "paint-able" or will a substrate be necessary?
I'll suggest to you the use of Silver Fire 2.5 2.0 as a "best choice", followed by RS-MaxxMudd LL, the latter especially if you want to roll instead of spray.
Let's hope you can/want to spray though. wink.gif
Going either way you'll come in way far under a $200.00 budget if the wall can be utilized. Including the purchase of a $50.00 Electric HVLP gun as well as all the materials necessay.
post #14 of 16 Old 06-28-2012, 11:40 AM
general001's Avatar
already have a great sprayer and the wall is a brand new construction wall that is near perfect so im going straight on.
post #15 of 16 Old 06-28-2012, 11:44 AM
general001's Avatar
also i did a search on silver fire and maxxmudd ll and found so many threads. is there a little help to the actual mix and make of this. also is the silver fire supposed to be a first coat followed by the MM or is it one or the other, sorry if this is more asking then researching. i always hate when people what the info spoon fed but there is a tn of info in this place.
post #16 of 16 Old 06-29-2012, 09:20 AM
Liked: 970
People always apologize when asking instead of researching....but still they have their mouth open wide for that proverbial "Spoon". biggrin.gif But fear not....we are great Baby Sitters & Diaper changers on here, and the stink of having to repeat things ad-nausium never bothers us.....much. redface.gif
The RS-MaxxMudd formula is simple enough....but going into Silver Fire requires precise mixing of 4 separate Color Tints. Even so, if any real degree of care is taken, it becomes a "not to difficult" thing to accomplish, and well worth the effort come the end results.
In any case, the best thing to do is to autor your own dedicated Thread devoted to your project. As far as I know of, no one on here has ever ignored a honest plea for assistance, and there just might be several respondents who canoffer you plenty of advice and encouragements.
As for me....I'm not going anywhere so make a choice and get started. cool.gif
BTW....I really like "Wall oriented" DIY Screen projects. They represent the epitome of value in a high performance Custom DIY Screen.
Reply DIY Screen Section
