reusing Visual APex frame for AT setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-02-2012, 01:01 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Has anybody tried to refit Visual Apex frames with AT screen material ( I am thinking Seymour Center stage XD) ?
Is there any reason to think it may not work?
thank you
zheka is offline
post #2 of 2 Old 12-09-2012, 03:23 PM - Thread Starter
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
I have retrofitted my VA screen with Seymour Center Stage XD without any modifications
I also tried using heavy spandex(molskin), but on bright scenes I could see vertical lines where the clips are. I guess more clips could have helped, but I did not like the picture quality any way and settled on the Center Stage XD material instead.
zheka is offline
Reply DIY Screen Section
