Best paint for a mirror? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 08-04-2012, 07:21 AM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Originally Posted by MississippiMan View Post
(Color Components)
100ml - filtered/distilled water for rinsing color components from utensils
50ml - Liquitex Basics - Napthol Crimson Red
25ml - Liquitex Basics - Phthalocyanine Green
16ml - Liquitex Basics - UltraMarine Blue
9ml - Liquitex Basics - Cadmium Yellow - Deep Hue
Liquitex Basics Gold 1.50 oz (...get a small tube of this and have it handy in case you notice any tendency of the completed Mix/Colorant to push toward Blue)
Be careful using those Glass Mirrors!
OK, so that's the whole recipe? Using the fine tip on the sprayer, approximately how much mix do I need to cover the ~30 sq feet of the mirror? (or are those quantities listed above sufficient) I want to make sure I order enough to cover it the first time biggrin.gif
Also hah, I heard a Lowes' commercial for the HV2900 - $99 biggrin.gif Yay eBay!
Kaido is offline
Old 08-04-2012, 08:55 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1813 Post(s)
Liked: 822
No.
Your last post had a link to RS-MaxxMudd LL
So that constitutes almost the entire bulk of the paint mix.
I supplied the correct colorant recipe, and from the amount that makes (approx. 4 oz.) you would use 1 ounce of colorant mixed into the entire RS-MaxxMudd LL amount. ( over 3 quarts...)
the object being to darken the RS-MM LL mix just enough to further enhance contrast but still maintain virtually all of the mix's original gain.
1 Ounce is all that can be added without switching to Silver Fire so as to also maintain gain as a mix darkens up even more. but any shade of SF above 1.0 is not going to have a higher gain than the suggested mix above.
You got that?
MississippiMan is offline
Old 08-04-2012, 03:05 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Okay, so I'm mixing RS-MaxxMudd LL with the colorant recipe a few posts up. Let's see if I have this right:
~1/2 gallon RS-MaxxMudd LL v.2: http://www.avsforum.com/t/1139061/rs-maxxmudd-mix-the-official
20 oz. Delta Pearl Metallic #02601
8 oz. Liquitex Basics Silver
12 oz. UPW flat
12 oz. Minwax Polycrylic - Satin finish
15 oz. distilled/tap water**
~4 ounces Colorant: (use 1 oz. of final colorant mix in the RS-MaxxMudd LL mix) http://www.avsforum.com/t/1419944/best-paint-for-a-mirror#post_22268045
So let's put that all together...
Shopping List: (rounded up milliliters to ounces for minimum purchase amounts)
19 oz. Distilled Water
12 oz. Behr 1850 UPW Flat
12 oz. Minwax Polycrylic - Satin Finish
8 oz. Liquitex Basics - Silver
2 oz. Liquitex Basics - Napthol Crimson Red
1 oz. Liquitex Basics - Phthalocyanine Green
1 oz. Liquitex Basics - UltraMarine Blue
1 oz. Liquitex Basics - Cadmium Yellow - Deep Hue
2 oz. Liquitex Basics - Gold
It looks like the Liquitex Basics are sold in 4 oz. and 8.5 oz. tubes, so I'll snag one 4 oz. of each color, plus two 8.5 oz Silvers at either Michael's or Amazon, along with the Delta Pearl, then hit up Home Depot for the Behr & Minwax stuff. I have one of the Poland Springs water coolers for distilled water. Found some spray instructions here, albeit for the Wagner:
http://www.avsforum.com/t/799078/a-wagner-for-mississippiman
Tentative plan:
1. Remove mirrors from old wall & prep for install
2. Purchase paints
3. Mix paints according to spec
4. Spray on mirror (3 coats?)
5. Enjoy!
I need to pick up some black felt and design a cool frame for it, too. What do people usually clean the mirror with for prep, Windex?
Kaido is offline
Old 08-04-2012, 03:35 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Just seeing what I can find online:
128 oz. Dilstilled water: (I kid, I kid - I mean, just look at the shipping prices biggrin.gif)
http://www.amazon.com/Nestle-WATER-DISTILLED/dp/B000P9BAFA/
8 oz. Delta Pearl Metallic: (via this post) $6.66 + $5.99 shipping = $12.65, times three = $37.95
http://www.amazon.com/Plaid-Delta-8-Ounce-Ceramcoat-Acrylic/dp/B000YQK3CA
32 oz. Behr 1850 UPW Flat: (in-store only, apparently) $11.68
http://www.homedepot.com/h_d1/N-5yc1v/R-202761546/h_d2/ProductDisplay?catalogId=10053
32 oz. Minwax Polycrylic - Satin Finish: $15.66 + $3.64 = $19.30
http://www.amazon.com/Minwax-63333-Polycrylic-Protective-Finishes/dp/B000BZYYH4/
4 oz. Liquitex Basics: (7 total - Napthol Crimson Red, Phthalocyanine Green, UltraMarine Blue, Cadmium Yellow - Deep Hue, Gold, 2 x Silver) $3.99 * 7 = $27.93 + shipping
http://www.dickblick.com/products/liquitex-basics-4-oz/
So it looks like about $97, plus whatever shipping at Dick Blick runs. Next time I'm by the mall I'll hit up Michaels & Home Depot and snag me some paint! And if they don't have what I need, now I have some resources for ordering online...
Kaido is offline
Old 08-04-2012, 07:14 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Mirrors acquired.
Kaido is offline
Old 08-04-2012, 07:35 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
The mirrors were heavier than I anticipated...going to be feeling that teardown for a few days tongue.gif They are mostly intact, a few scrapes on the edges, but fortunately they were not glued onto the walls - just a top & bottom metal rail. Measured in at 1/4" thick. I think I am going to go with the largest mirror in the bunch in order to fit the 800p resolution of the projector; I've decided to use a PC as the primary source, so I can use the full resolution for other stuff (gaming, web surfing, etc.). Using the 16:10 calculator below, it looks like I can do an 84" W x 53" H screen, with a 99" diagonal. The largest mirror I have is 5' x 7', so I'd have to trim off 7" from the height, which I'll do with some black velvet.
http://www.draperinc.com/ProjectionScreens/CustomSizeCalculator.asp
I'd like to make the screen removable, so I'll conjure something up with that Mirror Mastic glue and a custom frame that uses the trim as support. Should be fun. Also, I've settled on the Viewsonic PLED-W500 (~$599) for the projector:
http://www.amazon.com/ViewSonic-PLED-W500-80-Inch-Front-Projector/dp/B005LHM6OA/
* 1280 x 800 resolution
* DLP technology
* 20,000-hour LED bulb
* HDMI input
* 500 lumens
* 3500:1 contrast
* 3D-capable (requires $360 Viewsonic VP3D1 3D processor & $99 ViewSonic PGD-250 Active Glasses)
* 8.4" x 6.4" (1.6" H)
* Instant-on (no warmup time)
It's been getting good reviews, and the footage on Youtube looks pretty good, so for $600 I'm willing to give LED a shot (mostly for the "cool" factor, I'm such a nerd! haha). Plus it's portable - I'm replacing both my PowerPoint projector (XGA Optoma EzPro745) and my Home Theater projector (720p Mitsubishi HD1000u) and have recently moved, so consolidation is a plus for me (it's also going in a small multi-purpose mancave room, so tiny dimensions are a Good Thing). I am also anxious to give it a shot outdoors on my 12' Walmart inflatable screen; we'll see if 500 lumens of LED goodness can hold up outdoors!
Next action list:
1. Design & build frame
2. Confirm paints & purchase
3. Paint screen & assemble frame on wall
4. Purchase projector
Kaido is offline
Old 08-05-2012, 06:11 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Had one casualty in the move:
I'm not sure if I can glue it back together and spray it - would the line be seen through the paint when the light from the projector hits it? It was a clean break and fits together perfectly. Otherwise I'll just have to resize the whole thing.
I also forgot, there was a small power outlet cutout from the large mirror I wanted to use. Might have to re-size that one, too.
Even after the cuts, both will make decently large screens, just not as large as anticipated, unless the glue/spray thing works. Fortunately the room is only about 200 sq. feet, so it's not an overly huge viewing area to begin with...
Kaido is offline
Old 08-06-2012, 09:33 AM
Liked: 822
Personally, I would not chance it, because the layer of paint is so thin and translucent, it's almost assured you'd see a line.
Re-size and be confident of your end result.
Old 08-06-2012, 11:33 AM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
OK. Just for a final check, does my shopping list look good? I plan on painting this weekend. Here is my plan:
1. Purchase paints from list
2. Mix by hand
3. Clean mirror & Spray 3 coats onto glass - found a procedure here: http://www.avsforum.com/t/630888/black-flame-light-fusion-patent-pending-diy-mix-disclosed
Kaido is offline
Old 08-06-2012, 12:01 PM
Liked: 822
2. Mix by hand
Number #2?
No way! You absolutely must use this. No exceptions....no substitutions.
http://www.amazon.com/Homax-69011-1-Gallon-PolyPro-Galvanized/dp/B000ELORFE
It might be available "retail" at Home Depot or Lowes.
As for that older Thread example, that was done using a old Formula. And the instruction became rather oblique because at the time there was FooFaRah about supposed "marketing" (...even though the Thread was specifically encouraging DIY efforts...)
Since then, having been issued the Patents (US & UK) for the "RBYG & Reflective Mix Processes" and "Varied and Specific Substrate use", continual upgrades and changes have been made to the "DIY Oriented" Base mixes and Painting methods. It would not be wise to use any specific instructions or methods found on a 6 year old Post.. Also...and perhaps even more relevant, the Spraying process has changed due to the use of more effective and efficient Electric HVLP Guns.
The members who have done actual Light Fusion screens have all simply followed adaptive reasoning and specific instructions provided by PB-Maxx and myself when asked. So I'm glad your asking first....absolutely!
Go here and review:
http://www.avsforum.com/search.php?search=Light+Fusion
....and then ask any questions that you feel pertinent and/or that address any inconsistencies as far as information or materials / the spray application process.
You'll be combining the current "Silver Fire v2.5" at whatever "Colorant amount" you need / desire along with the Mirror, with the most explicit and complete spraying instruction I can provide.
Old 08-06-2012, 12:54 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Number #2?
Go here and review:
Welllllllll glad I asked! biggrin.gif Is there a "most current procedure" for the entire process posted somewhere? Like a reference thread containing the most up-to-date information? I haven't seen that Homax mixer before. If not, I'll write one out for us after this project is completed. Too much conflicting information in the historical archives, haha.
Kaido is offline
Old 08-06-2012, 05:24 PM
Liked: 822
Progress and revision, followed by "hands on" helping as substituted for composing new Tutorials. As such, we depend upon those like yourself to document and reveal their own experiences. The variables and differences always provide more "real world" info than a non-changing, static Tutorial.
Still, I usually toss a "Project Specific Tutorial" in at the time I'm actually doing one in real life. Beyond that, it's all about you Guys! It's become a point of order with DIY'ers
But I'm watching...waiting.....and always ready to advise.
Old 08-06-2012, 05:43 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Projector arrives Wednesday...couldn't resist. Amazon had it for $575 on sale...jumped up to $683 after I placed my order! Now I can afford the paint biggrin.gif
Kaido is offline
Old 04-12-2015, 08:10 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
Revisiting this project - moved & just dug the screen out of storage last month. Quick recap:
1. Was originally planning on re-purposing the glass mirror from an interior wall
2. It broke
3. Ended up purchasing a 48" x 85" acrylic mirror
I also got out the Graco HV2900, 1.5mm needle, and Homax mixer. I think all I need to do is buy the paints & spray! Has the paint mix formula changed at all in the last few years?
Kaido is offline
Old 04-12-2015, 10:55 PM
Liked: 822
Oh yeah. Silver Fire v2.5
But the newest version contains Rust-Oleim products (Silver - Pearl - Polyurethanne ) Check the listed ingrediants on the 1st page of the SF Thread.
The Official Silver Fire V.2 Thread.
...shouldn't be too hard to find.
Get this Needle though......
http://www.homedepot.com/p/Earlex-1-0-mm-Brass-Needle-Kit-for-Gemini-Spray-Station-HVACGEM10/204786904
Disassemble your Gun and check to see if the needle as shown matches your Gun's.
If you have any doubt, Contact "Direct Sales" at Earlex 1-888-783-2612 and ask about ordering the specific 1.0 needle Kit for the 2900.
Your Mirror deserves the best possible finish.
How much Ambient Light will you be dealing with?
Lastly....you now have a chance to get perfection in a Light Fusion application by doing correct duster coats with the 1.0 mm needle. Let's review anything you need to as far as mixing, straining, and spray painting technique before you start, to assure of you nailing it on the first go.
Old 04-12-2015, 11:01 PM - Thread Starter
Kaido's Avatar
Quoted: 30 Post(s)
I figured the state of the art had progressed since I started this project
For the mirror screen - no ambient light in the new location. I've already finished painting the basement & have the blackout blinds installed already. Projector is hung (adjustable), so the next step is to pick up the parts to build a strong, inflexible frame (with a French cleat for hanging) & get painting!
I had originally purchased the 1.5mm upgrade needle, but I don't mind picking up a 1.0mm needle - I'll check on the needle match tomorrow. I have some buddies who are building other screens with me (one Silver Fire & one of Ftoast's black screens), should I just use the 1.0mm needle on all of them? (planning on using my basement's French cleat mount for hanging them to spray one by one)
Kaido is offline
Old 04-12-2015, 11:12 PM
Liked: 822
OK....but be sure to create a level run-off around the edges using Cardboard to prevent Vortex-ing on raised edges.
With no ambient light issues you can go with a reduced Silver w/enhanced UPW mix. The Rust-Oleum silver real;ly creates a darker mix than the olde Liquitex version, even without adding Colorant.
........and yes, use the 1.0 Needle for all the screens.
Using the Mix guide as listed, simply add an additional 8 oz of UPW into the mix.
Glad to see you have a Homax Squirrel Cage Mixer. They are scarce has a Hen's teeth these days except in the 5 Gallon size.
