Spandex World out of Moleskin Matte (Silver) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-03-2012, 07:40 AM - Thread Starter
Jamz's Avatar
Title says it all. There is a back order of at least 1 month for Moleskin Matte (Silver). Is it worth waiting for or is there an alternative I should look at? Plan was silver over white for an AT screen and Epson 8350.
Jamz is offline
post #2 of 11 Old 08-03-2012, 08:26 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2031 Post(s)
Liked: 898
Blame the current demand for it because of recent uptick in DIY popularity. Maybe this will give them reason to restock in a bit larger quantity?
Using a Simple Gray instead would work, but you would have to expect some additional attenuation. Better to put your order in now, use the White until it (SM) arrives.
MississippiMan is online now
post #3 of 11 Old 08-08-2012, 02:12 PM
perpetual98's Avatar
Quoted: 84 Post(s)
Liked: 50
Drat, I was actually going to pull the trigger and order 3 yards of it recently. I've been using a couple bed-sheets and lately it seems as if I can see the threads in the sheet, but I haven't quite yet figured out if it's just the screen-door-effect from my ancient projector. I might fire it up tonight and do some up-close looking. I think I'll need a large area of a constant color to figure it out. Probably an old Disney cartoon as I really noticed it on Baloo in The Jungle Book when my daughter was watching it the other day.
perpetual98 is offline
post #4 of 11 Old 08-10-2012, 07:41 PM
jimmyk36's Avatar
Quoted: 82 Post(s)
Liked: 36
Any other sources for the Silver Spandex????? I am having my basement finished and it should be ready next week - I have everything for the HT I need except the screen :-) and I would really like to get the AT Spandex.
Any thoughts?????
JimmyK
jimmyk36 is offline
post #5 of 11 Old 08-11-2012, 06:29 AM
Liked: 898
I suggest you stick with a known "poison" and place an order so as to get your place in line.
The quality and properties of the particular Spandex are what makes it particularly suited for the job. And deviance from that by trying something else might be OK...or a complete disaster.
Now....to effect a good example you'll need White Spandex as well, so if you want something ready to shoot on, and since you'll need to build a Frame anyway, getting halfway there isn't a bad course of action to take.
The only real penalty is paying for Freight 2x.
post #6 of 11 Old 08-20-2012, 08:07 PM
BretJ's Avatar
Just ordered 3 yards each of the Moleskin matte silver and white. Seems it may be back in stock. Keeping my fingers crossed. BTW, is the moleskin matte white suitable as the backer material?
BretJ is offline
post #7 of 11 Old 08-21-2012, 04:31 AM
memphisanid's Avatar
It absolutely is. and the recommended backer for the Silver
memphisanid is offline
post #8 of 11 Old 08-24-2012, 12:15 PM
IA_Hi_Fi_Guy's Avatar
Quoted: 21 Post(s)
What kind of gain can one expect from and Silver spandex screen backed by white spandex?
IA_Hi_Fi_Guy is offline
post #9 of 11 Old 10-17-2012, 10:49 AM
ricocetj's Avatar
Has anyone gotten an update on the availability of the moleskin matte silver? I sent an inquiry to spandex world but have not heard back. Seems like it has been out of stock for quite some time, and there's no option to pre-order that I see.
I was also searching around and found this product on amazon: http://www.amazon.com/Nylon-Spandex-Milliskin-Matte-Silver/dp/B006MBK830/ref=sr_1_1?ie=UTF8&qid=1350495933&sr=8-1&keywords=matte+silver+spandex
Milliskin instead of moleskin... not sure if it's a similar product of equal quality or an inferior version. Does anyone have any experience with it? I'm ready to build a screen for my new projector!
ricocetj is offline
post #10 of 11 Old 10-18-2012, 12:16 PM
CJSchmidt's Avatar
Milliskin (from what I've been able to find) is the thin version of moleskin. Unfortunately the thickness is a big part of why it works so well as a screen. Maybe you could not stretch it very much and/or do two layers? I'm currently using some cheap fabric while I wait for the good stuff to get back in stock. Please let us know if you find another source or hear back from Spandexworld.
CJSchmidt is offline
post #11 of 11 Old 10-19-2012, 11:58 AM
ricocetj's Avatar
Thanks CJ! Sounds like I'm stuck waiting to see what happens with the moleskin. I did get a response from spandexworld yesterday saying they expect to have the matte gray back in stock in 5-7 days, but also saw someone in another thread saying the communication they received from spandeworld was that they don't know when or IF they will get it back in stock. So, I guess we'll just have to wait and see.
ricocetj is offline
Reply DIY Screen Section
