Best roll on paint combination... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 08-21-2012, 07:39 AM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
(Newbie) Given this will be my first time applying a painted screen...although I would like to attempt the "silver fire" but am a little weary of using a paint gun...can I get something similar with a roll on and and have the same effects as "silver fire"?
buddylee7 is offline
post #2 of 24 Old 08-21-2012, 09:35 AM
memphisanid's Avatar
The only rollable DIY paint I have seen on the forum is RS-MaxxMudd LL but to put it in the words of MM
Of course you can roll RS-MM LL....., but you could also Kiss Your Sister on New Years too. Both are going to be less than satisfactory experiences than you might otherwise aspire to.
Spraying is not hard at all, it really just takes a little bit to get used to the gun and how close and fast to move across the screen. I did all of this in one day from about 10 am to 8pm. I had the help of a space heater to quicken a bit but this also included the learning of using the gun. There are a bunch of people on this forum that will help you with the process, you just need to ask the questions BEFORE so that you can go into with all the knowledge of everyone else who has done it.
So in short, you can roll but it is worth it to spray as the end result is that much easier with proven results
memphisanid is offline
post #3 of 24 Old 08-21-2012, 09:32 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2179 Post(s)
Liked: 981
Wary....? Or truly "weary" as in too pooped to squirt?
Tell me everything you can relate about your equipment and viewing environment. Let's see if a simpler solution can be had.
But don't discount the possibility of Spraying, because as mentioned above, in truth, you'll face more chance of unsatisfactory results from using poor rolling technique than you would from spraying using the technique and equipment we suggest.
So....leave your Sister alone.......
MississippiMan is offline
post #4 of 24 Old 08-22-2012, 01:42 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Wary would be the word and damn Siri! Laziness on my part...
Projector: Epson Powerlight 6500ub
Screen size: 110'' to 120'' - would like to go bigger but in wall speakers are in the way (previous owner)
Location: open basement with some ambient light during day
post #5 of 24 Old 08-23-2012, 04:32 AM
Liked: 981
Hey...sorry, I forgot to say "Welcome to DIY Screens".
The "Speak to Text" on my Galaxy II was at best spotty until a recent upgrade was added...now it's almost "Spot On' if I at least enunciate. Still, to avoid embarrassment...i try to always review before hitting send. Sadly..."Try to" doesn't always happen. tongue.gif
[quore]Projector: Epson Powerlight 6500ub
Location: open basement with some ambient light during day[/quote]
Stick with 110" Mount the screen centered between the center Speaker and ceiling...or if anything, a bit closer to the Speaker.
Nothing "Rolled" can approach Silver Fire in it's darker versions. RS-MM-LL will do great, but it's still gonna need at least some degree of effect light control on the window on the tight. Non-directed ambient light from incandescents? No problemo. cool.gif
But no matter what, for the very best results...ya gotta consider spraying as being mandatory.
Really hot?
Take her to Vegas.
Avoid the Paparazzi.
Deny everything...admit nothing.
post #6 of 24 Old 08-23-2012, 07:03 AM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Thanks for the welcome and thanks again for the info. I will see what I can do this weekend...off to the store to purchase a spray gun. smile.gif
I'll keep you posted on my results...
*purchased two tickets to vegas*...
post #7 of 24 Old 08-23-2012, 06:31 PM
Liked: 981
Whoa.
Do you know what type sprayer to get?
This is the current champion at being both effective and inexpensive:
http://www.ebay.com/itm/GRACO-HV2900-39-CFM-450W-HVLP-House-Paint-Spray-Station-Machine-System-Painter-/230791007590#ht_4652wt_1140
It comes with a 2.0 mm Tip. If you get a 0.5mm accessory Tip, you can use it to apply Tanning Solution too.cool.gif
You wouldn't want to run across George Hamilton on the Strip looking like...........well, me. redface.gif
post #8 of 24 Old 08-25-2012, 01:50 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Do you have a recommendation just for this for the spray gun itself that can connect to an air compressor?
post #9 of 24 Old 08-25-2012, 09:10 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
I went out and got the supplies but am I missing something? Some of the listed ingredients do not have the amount you need to add.
50ml - Liquitex Basics - Napthol Crimson Red
25ml - Liquitex Basics - Phthalocyanine Green
16ml - Liquitex Basics - UltraMarine Blue
9ml - Liquitex Basics - Cadmium Yellow - Deep Hue
(Viscosity Components)
16 oz. Minwax Polycrylic - Satin Finish
24 - 36 oz. Distilled or Filtered water*
(Reflective Base Components)*
? - Metallic Accents – White Pearl
? - Liquitex Basics Silver
? - Behr 1850 UPW Flat
? - Liquitex Basics Gold
post #10 of 24 Old 08-26-2012, 04:28 AM
Liked: 981
Sure it does / they are..
Go here: http://www.avsforum.com/t/1311989/the-official-silver-fire-v-2-thread
........and in the first post, scroll down to "Reflective Base Components".
To the right of each listed Component you'll see a graduating scale "in Ounces" that is based around the "Colorant Amount needed".
For your situation I'd suggest SF 2.5 2.0
When looking across from the "Silver Fire v2.5 hue (Colorant amount in ounces – oz)" the use of 2.0 ounces of the Colorant lists the following amounts of the Reflective Components.
Rustoleum Metallic Accents – White Pearl ................... 21 Oz.
Liquitex Basics Silver .............................................. 21 Oz.
Behr 1850 UPW Flat ................................................10 Oz.
Liquitex Basics Gold ................................................ 1.75 Oz
post #11 of 24 Old 08-26-2012, 11:07 AM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Ah, cool. Thx!
post #12 of 24 Old 08-26-2012, 11:14 AM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Do you have a recommendation on what paint to use as a primer?
post #13 of 24 Old 08-26-2012, 11:25 AM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Here is my list...So I dont have to mix multiple batches will this list cover a 110 to 130 inch screen?
SILVER FIRE v2.5
100ml - filtered/distilled water for rinsing color components from utensils
post #14 of 24 Old 09-01-2012, 09:51 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Hello?
post #15 of 24 Old 09-02-2012, 06:58 AM
Liked: 981
Hello?
Sorry...your post must of gotten pushed down toward the bottom and went unnoticed. I tend to get a bit bleary eyed on Saturday nights after 3-4 Micros on top of my Wife's good cookin'. And when my forehead crashes down onto the keyboard....I usually go to my chair and get int "Sleepy Bear" mode. redface.gif
Thanks for bringing it on........
The amount listed is enough to do up to a 144" diagonal screen of proper technique is used and no "re-do' is required. At 110" to 122" you'll hae several ounced left over, so seal it up in a tight lidded container and save it for any necessary repairs or such.
post #16 of 24 Old 09-02-2012, 08:25 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Cool. Thanks! Do you have a recommendation on a primer or will any white primer do?
post #17 of 24 Old 10-13-2012, 03:42 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Minwax Polycrylic - Satin Finish.......16oz = 473 ml
24 - 36 oz. Distilled or Filtered water* = 710 ml - 1,065 ml
Rustoleum Metallic Accents – White Pearl ................... 21 Oz. = 621 ml
Liquitex Basics Silver .............................................. 21 Oz. = 621 ml
Behr 1850 UPW Flat ................................................10 Oz. = 296 ml
Liquitex Basics Gold ................................................ 1.75 Oz = 22 ml
I'm going to get started today mixing all of this together....look correct?
post #18 of 24 Old 10-15-2012, 11:31 AM
burton123's Avatar
did you purchase your items? if yes can you mark which one you bought from where? smile.gif
I am on the same boat also.
I was planning to purchase one from the web but i read a lot about Silver Fire2.5 and decided to go with this path.
burton123 is offline
post #19 of 24 Old 10-16-2012, 08:50 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
All Liquitex Basics @ Michaels or United Arts and Education
Minwax Polycrylic - Satin Finish @ Home Depot or Lowes
Rustoleum Metallic Accents White Pear @ Menards
post #20 of 24 Old 10-22-2012, 08:46 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Mississippi Man: Given the fact I have a Epson power light 6500ub what setting would you recommend, dynamic or theater mode? I know that dynamic will decrease the longevity of the bulb but the picture looks much better with it on granted I am saying this without applying the super fire and only the primer as of yet.
What are your thoughts on LED projectors?
post #21 of 24 Old 10-23-2012, 07:49 PM
Liked: 981
I most often use dynamic because on the Epsons...particularly the 65-85-8700s, it's pretty close to being color correct, leastwise it take minimal Calibration to zero it in.
Add to that added advantages of enhanced contrast and deeper colors of "Silver Fire" ("Super" doesn't seem to far of...) delivers a Plasma / LED_LCD like image in controlled lighting, and a extremely serviceable image in what can only be called obscene and crazy amounts of ambient light. Halfway between those points can be awe inspiring.
post #22 of 24 Old 10-27-2012, 03:06 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
Just mixed all my paints and followed the instructions and the final product/batch has a grey/almost purple hue to it...does that sound about right? I'm assuming it will dry different compared to what I see right now.
post #23 of 24 Old 10-27-2012, 03:10 PM - Thread Starter
buddylee7's Avatar
Quoted: 20 Post(s)
I'm still a little reluctant to run the projector on dynamic given the fact it kills the bulb...I'm hoping theater mode will suffice with silver fire applied. Do you have any suggestions of LED bulb projectors as of yet or is that technology a ways off from being perfected?
post #24 of 24 Old 10-31-2012, 11:13 PM
Kirnak's Avatar
Dynamic doesn't kill the bulb. Running in "Normal" mode will age the bulb faster than running it in "ECO". All Dynamic does is take the light correcting filter out of the light path. Running the PJ in "Dynamic" combined with "ECO", the bulb will last longer than "Theater" combined with "Normal".
Kirnak is offline
Reply DIY Screen Section
