Best way to attach velvet border to spandex over wood frame? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By techtre2003
Old 08-29-2012, 01:27 PM - Thread Starter
SuperChupe's Avatar
If I'm using screen door spline for stretching the spandex, is there benefit to doing something clever that keeps me from having to nail/staple through the spandex for attaching the baseboard/velvet?
SuperChupe is offline
Old 09-14-2012, 05:22 PM
S_rangeBrew's Avatar
Quoted: 20 Post(s)
Liked: 43
I just found out about that screen tight spline stuff reading here today. Sounds much better than staples.
I was thinking of wrapping the velvet to peice of trim, then attaching that to the frame with velcro
I don't know.. I"m going to investigate some more. Whatever I do, I'll take photos and post here.
I currently have a 92" 16x9 AT Accuscreen (made by Draper) that cost me $200. Worth every cent, but
they only make them in 16x9 up to 110". Now I want a 130" 2.39:1 Cinemascope AT screen, and the
commercial offerings cost at least $1500!!! As far as I can tell, my Accuscreen is made out of
Spandex of some sort. It's very stretchy and has no visible weave unless you put your nose right up to it.
Looks like I"m back to DIY, thanks to the wonder of SPANDEX!
S_rangeBrew is offline
Old 03-03-2013, 07:50 PM
brendelac's Avatar
Quoted: 147 Post(s)
Liked: 83
I'm wondering the same thing. Is there a definitive answer?
brendelac is offline
Old 03-04-2013, 07:37 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
Stapling seems to get a bad rap. Using 1/4" staples, applying the Spandex becomes a very simple, easy process, and any needed removal is effected with the tip of a Butter Knife.
Using Screen Spline is of course a method that allows a quicker dis-assembly, but in the same regard it requires that the stretch be made / held over a longer area before the spline is inserted, so I'm not seeing where in fact it's use makes the Job any easier during initial assembly. Screen Spline makes pretty good sense when a actual Screen material, or Blackout Cloth is used, because those materials do not stretch much, if at all, and they can be prone to ripping / tearing. Not so Spandex. In the time I have been using it, and have had to remove a few Staples, even inserting a sharp point under the stapled Spandex did not result in any tearing or perforation. Spandex is pretty resilient to tearing, being so "stretchy" and all.
But the question pertained to Trim, did it not?
If the perimeter of the Spandex Screen is greater than the actual viewable area, then one should Wrap the baseboard with velvet first, then simply apply the Trim to the Screen Frame using small, 1.25" Bright Finish Nails if one does not have a Air / Battery Powered Stapler that uses the even shorter, smaller 1" Finish nails.
Applying Velco to a stretchable Cloth, and then expecting it to hold lengths of Trim firmly to / against such a surface (especially at the Mitered corners) seems pretty misdirected. What happens when you determine to pull the Trim back off? Unless you also staple the Velcro base pad to the Frame, it will pull outward with the Trim, and possibly ruin your Screen's stretched surface.
MississippiMan is online now
Old 03-05-2013, 12:52 PM
Conspiracy*'s Avatar
Quoted: 25 Post(s)
Liked: 37
Just to clarify, because it seems wrong...
You're saying to wrap the trim used for border in velvet, staple the velvet to back of trim, then nail through the velvet using a 1.25" bright finish nail to attach the now wrapped trim to the frame?
"Damn, you can't get black levels like that on your projector!"
- My brother, just before he realized his LED display had died.
Link to my Basement build
http://www.avsforum.com/t/1529034/conspiracy-basement-build
Conspiracy* is offline
Old 03-05-2013, 01:41 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
...and countersink the finish trim nail below the black velvet.
pb_maxxx is offline
Old 03-05-2013, 02:02 PM
Liked: 806
That process has been described., explained, and illustrated a great many times.
Old 03-07-2013, 03:16 PM
Quoted: 25 Post(s)
Liked: 37
And yet...I don't recall seeing it ever done in a thread. Deeper into the rabbit hole I go...
Edit - I didn't have to go very far. Found your thread MM. Weird that i've never seen it in all the times I've browsed the forum.
On a side note...I was watching a video the other day and the builder wrapped the FRAME in velvet before he put the four corners together. He then stretched the screen material over the "back" of the frame so that when he hung it it created a velvet wrapped shadowbox with the screen material in the back. Thoughts?
Old 06-03-2013, 05:46 PM - Thread Starter
SuperChupe's Avatar
Thanks, MM. I finally got around to wrapping the trim and borrowing a friend's brad nailer and now have it installed. Excuse the blurry cell phone camera shot.
Old 06-10-2013, 02:16 PM
Liked: 806
Hey, this posting got overlooked IMO. That's a nicely done project there....lacking only both a response (...well not anymore...) and the posting of some screen shots. There are actually not many such shots on the Board here, and I KNOW the potential is there for others to provide some.
So.....all ya all, get'ter dun!
Old 11-23-2015, 02:51 PM
DrBabs's Avatar
Quoted: 62 Post(s)
sorry to resurrect. I am planning on the same approach. I have a frame built from 1x6 trim. I have beveled the inside edge from 1" to 1/8" on the inside.
I plan to wrap the fram pieces individually, then join the mitered pieces together to make a complete frame. pocket hole screws, heavy metal "L" brackets and corner reinforcements. Then take the stretchy white screen material and staple it to the BACK of the frame (no wrap-around stretch).
is this a commonly used technique?
DrBabs is offline
Old 11-25-2015, 08:37 AM
techtre2003's Avatar
Quoted: 159 Post(s)
Liked: 90
That's exactly how I did my latest screen; worked great.
DrBabs likes this.
techtre2003 is offline
Old 11-25-2015, 10:46 AM
DrBabs's Avatar
Quoted: 62 Post(s)
how wide was your screen? Did you have any sag in the middle? I wonder if spanning 118" wide will give excess pull in the middle and cause the frame to bow in.
DrBabs is offline
Old 11-25-2015, 11:40 AM
Quoted: 159 Post(s)
Liked: 90
It is 130" wide. I didn't use any kind of middle bracing. It did sag a little when we were just holding it up, but once it was up and attached to the wall frame it was fine. I used metal tie plates and just screwed one end of the plate to the back of the screen frame and the other end to my wall frame. I think I used 5 plates across the top evenly spaced so that I didn't get any kind of sag.
Old 11-25-2015, 12:03 PM
DrBabs's Avatar
Quoted: 62 Post(s)
oh, so you have two frames? one for the screen and one on the wall that you attach that to? or what is the wall frame?
tie plates like this?
im afraid that I am not following you.
DrBabs is offline
Old 11-25-2015, 12:18 PM
Quoted: 159 Post(s)
Liked: 90
Sorry, that probably wasn't too clear. My false wall is just a frame made of 2x4s; that's the wall frame I was referring to. And yes, those are the exact plates I used.
Old 11-25-2015, 12:47 PM
Quoted: 159 Post(s)
Liked: 90
I couldn't find a pic of my new screen but here is my borderless spandex screen. You can see how I attached it with the plates at the top.
Old 11-26-2015, 04:48 PM
DrBabs's Avatar
Quoted: 62 Post(s)
dang Tech,
cant see the pic you posted. there's a green icon not a photo.
ps happy gobble day
DrBabs is offline
