replacement screen - AVS Forum
post #1 of 3 Old 09-18-2012, 12:10 PM - Thread Starter
sjdis's Avatar
I'm looking to replace my old 120" screen. The frame I built (1x4) is still great. Any suggestions on where to get just a replacement screen for a great price?
Thanks in advance for any suggestions.
sjdis is offline
post #2 of 3 Old 10-08-2012, 10:22 PM
Bobofbone's Avatar
You didn't say what you were looking for. However, you might try http://www.carlofet.com/ They have blackout cloth that you can buy by the foot that will work. While it isn't on their web site, they also stock other materials. Send them an e mail and ask-they'll send samples. I build a 131" 2.4:1 screen using white blackout cloth, and the material was about $62 with a pretty generous margin that I trimed. They also filled the order and answered their e-mails promptly.
Bobofbone is offline
post #3 of 3 Old 10-09-2012, 07:34 AM - Thread Starter
sjdis's Avatar
Thanks for the response. I honestly don't really know what I want....I was given an old outdoor screen that I cut down to size but it has a terrible glare or bright spot to it when the scene is light or white. I have great light control in the basement and I have an Epson 8700. Any suggestions?
Thanks again!
sjdis is offline
Reply DIY Screen Section
User Tag List
