Rustoleum Metallic Accents Canada - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-02-2012, 07:39 AM - Thread Starter
CanadianZ's Avatar
This is the only product I am having trouble sourcing in Canada for my MaxxMudd screen. I have tried Homedepot, both online and in store.
I have also email tech support at Rustoleum and they said HD and Lowes carry it. I do not have a Lowes anywhere near me.
Has anyone in Canada had any luck finding this stuff?? Please let me know where you got it from. Certainly it can't be that only our brotheren to the South can paint a diy screen with this stuff!!
Thanks for the help,
Tony
CanadianZ is offline
post #2 of 8 Old 10-02-2012, 04:10 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
Tony,
I've never heard of either of those stores carrying such. confused.gif Only Menards stores. What's stopping you from ordering from the Amazon vendor? Shipping + VAT?
PM me and I'll do whatever I can to help you over the hump.
MMan
MississippiMan is online now
post #3 of 8 Old 10-02-2012, 04:48 PM - Thread Starter
CanadianZ's Avatar
Would this be the same stuff?/
http://www.rona.ca/en/metallic-paint-20135078--1
I don't think Rona would make their own paint. Someone (ie Rustoleum) would be making it for them.
Tony
post #4 of 8 Old 10-03-2012, 12:43 AM
Liked: 806
Tony
Might be...but the only way to know is to get some and report your findings.
Without the Rustoleum to compare directly to, it's going to be a case of blind judgement though.
post #5 of 8 Old 10-09-2012, 02:45 PM - Thread Starter
CanadianZ's Avatar
After some emails back and forth with Rustoleum I have found out they supply Rona with the Metallic Accents paint that is then rebranded as Rona brand.
So if you are in Canada and are looking for the toughest ingredient to find for Silver Fire check the closest Rona store.
CanadianZ
post #6 of 8 Old 10-09-2012, 10:25 PM
massengil's Avatar
CanadianZ
Much appreciated CanadianZ! I was actually just about to try to figure out if the Rona product or the Modern Masters metallics (carried at SW) would be the same (or at least acceptable similar).
massengil is offline
post #7 of 8 Old 08-06-2013, 01:59 PM
gerbersean's Avatar
This thread would have saved me a lot of work on my own.
Contacted Rustoleum and got the same list (plus Home Hardware)
Store websites were little help. Didn't show anything. My Home Depot didn't have a spot for the White Pearl, even though they had other colours.
Stop 2 was Rona (it's on the way to Lowe's and I was curious)
I got mine @ Lowe's, even though the site said they only had Silver.
The Rona stuff is absolutely the same paint. I pressed Rustoleum and Rona about the same thing before finding this thread. With all the colour names being identical I was suspicious. I was just about to post this info to the SF V2.0 thread, but wouldn't feel right about taking the credit for the find (even though I did it the hard way and almost a year late). I think it would be a good thing to add to the availability info in the main thread and credit where credit is due.
Good find CanadianZ
gerbersean is offline
post #8 of 8 Old 08-06-2013, 02:41 PM
Liked: 806
We shall "Make it so".
Can you PM me the email address for Rustoleum. I also contacted then a bit ago but never garnered a response.
Reply DIY Screen Section
