So a forum member has offered to drive a piece of SIntra down to Tucson from Phoenix for me next week. You people on this forum are very generous with knowledge and time. I appreciate that in this often cold and indifferent world.
I want a screen of about 135" and the Sintra only comes in 5x10 so I'd need a few more inches of height. Is it reasonable to consider joining two pieces of Sintra by mudding the gap or some other technique? Is it worth the additional hassle and expense to use Sintra over BOC in this scenario? It would cost about $80 more to use Sintra over BOC.
The wall this is going on is slump block so completely irregular, bumpy and not flat and of course solid so how should I consider mounting this? Perhaps a frame and hang it?
I'd like to hear recommendations for a paint mix as well.
Here's my original thread with some description of my situation. I mostly will use it at night and although it's in the living room there is often no ambient light but it would be nice to have the option.
http://www.avsforum.com/t/1431762/spraying-a-manual-screen-or-other-suggestions
