Formica 949 Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-22-2012, 07:37 PM - Thread Starter
jwh92020's Avatar
I was killing time today when I decided to experiment with a sheet of Formica 959-58 (Matte White) that I had stuffed in a corner. The screen is 85 x 48 - 98" diagonal. I built a frame from 1 x 4 poplar, glued a 5mm sheet of luan plywood to the frame, the glued the laminate to the ply. Total weight is 30 - 35 lbs, so 1 person (me) can handle it. I pulled the "Hangman" cleat off my BOC screen and used it to hang the new screen. I took a couple of shots to show how the black color looks. I'm no photographer so be kind. I'm thinking if I don't like the screen after a while, I can always paint it. Total cost was $30 (the laminate was left over from a kitchen I did a couple of years ago. Next is to put together a black velvet frame. That project will have to get done next weekend. Let me know what you think of the pics. Thanks.
jwh92020 is offline
post #2 of 2 Old 10-23-2012, 01:24 PM
Chezteladog's Avatar
That looks great. Better than that paint you used on the other screen. I think I have that same keyboard. smile.gif
There is nothing either good or bad, but thinking makes it so.
Chezteladog is offline
Reply DIY Screen Section
