Anyone build a 3-way screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-30-2012, 09:12 PM - Thread Starter
Mazeroth's Avatar
The theater I'm almost finished with will be used roughly 40% TV, 50% video games and 10% movies. My wife will be doing most of the tv viewing and she doesn't like a very large screen. The seating distance will be at 10 feet and I hung up the old 92" 16:9 screen and she thinks that is PLENTY big. Daddy doesn't. After visiting another forum member's house last week that has a 2.40 screen I was sold on going wide aspect. I took down the 92", set up my Epson 8350 and projected a 115" 2.35 screen, which has the same height as the 92" 16:9. I put on a movie and loved it. This is going to be great! I'll have a large wide aspect for movies, then I'll plop in two masking panels to shrink the 16:9 image down to a 92" and all will be well. Hehe, friends, life can't be that easy. With the projector still running I threw on a video game, Just Cause 2, on my PC. 1080p, maxed all settings, glorious. Oh no, what is this? I didn't adjust the screen size and I'm playing on a 122" 16:9 screen and I'm in love! Then the gears started turning. I could build the following:
60" high, 106" wide, 122" diagonal 16:9 screen. When it's time for a 2.35 movie I plop in two 7.5" high masks on the top and bottom and get:
45" high, 106" wide, 115" diagonal 2.35 screen. When it's time for television shows I leave the other masks in and plop in two 11.5" wide masks on the sides and get:
45" high, 80" wide, 92" diagonal 16:9 screen.
That may be a tad too big and I was also considering this setup, which I tested and thought it also was awesome:
54" high, 96" wide, 110" diagonal 16:9
41" high, 96" wide, 104" diagonal 2.35 screen
41" high, 73" wide, 84" diagonal 16:9 screen
Has anyone done something similar? It seems like a great idea, as in the past I've had some people complain that even my 92" was too big (watching fast sports like football) so I could please pretty much all the crowds with this setup. I bet 80% of the time I'm down there it will be for video games and after playing on that monstrosity I'm not sure I could go back. For games where that big 16:9 was too big (maybe a first person shooter) I could scale it down. The room is 11.5 x 17 and will be 9.2 with four 15" subs behind a false wall. Life is good!
Thanks in advance for any input!
Mazeroth is offline
post #2 of 3 Old 10-30-2012, 09:25 PM
ausdavep's Avatar
Quoted: 26 Post(s)
message member highjinx, he has a 2-screen setup http://www.avsforum.com/t/1315086/dual-setup-screen-this-guy-nailed-it/0_100
ausdavep is offline
post #3 of 3 Old 10-31-2012, 11:41 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1780 Post(s)
Liked: 813
I don't think the TS is asking about having two separate screens.
The easiest way to go about this is to install Side Curtains (Black Velvet) that hand-pull from 2.39:1 width into the format width desired, and constructing a simple Roller Blind mask of Black Velvet, and use the 8350's Lens shift to adjust image height.
MississippiMan is online now
Reply DIY Screen Section
