Will 2 yard spandex moleskin white/silver enough for 120" diag 16:9 screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-05-2012, 09:43 PM - Thread Starter
vincentxw's Avatar
It seems people suggest a stretch of 50%, it should be enough but just want to get some idea if the assumption is true
I plan to use silver over white
Pj is pro 8200
vincentxw is offline
post #2 of 7 Old 11-05-2012, 10:15 PM
Duke Broadway's Avatar
Definitely 3 yards.
Duke Broadway is offline
post #3 of 7 Old 11-06-2012, 06:44 AM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
I bought two yards for a 120" 2.35:1 screen and it is stretched very tight and barely made it. I have silver over white and I bought three yards of the white locally and it was much easier to attach. I would agree that three yards is ideal.
ahajr143 is offline
post #4 of 7 Old 11-06-2012, 09:52 AM - Thread Starter
vincentxw's Avatar
thanks, would probably buy 3 yards anyway
I'm looking for lumber to build the frame, and homedepot have some 1x2x8' post, but it's only 96" long, to make a 16:9 120" you will need 108" in length, any suggestion there?
post #5 of 7 Old 11-06-2012, 03:34 PM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
I used 1"x3" poplar boards from Lowes that are available in 10' lengths. My 120" diagonal screen at a 2.35:1 aspect ratio is about 111" x 47". Make sure the spandex you order is 4-way stretch. Also, the higher the spandex content the more it can stretch.
ahajr143 is offline
post #6 of 7 Old 11-06-2012, 03:38 PM
As noted on other spandex threads 1x2's wont cut it. Your best option is getting 1x(3 or 4)x 10 for the top and bottom. Actually four 1x4x10 should get you top, bottom, 2 sides and 2 vertical supports on the middle. I highly recommend checking out all the spandex threads, you will learn alot.
post #7 of 7 Old 11-07-2012, 06:00 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
3 yards of spandex
and 1x4x10' poplar
smokarz is offline
Reply DIY Screen Section
