Another silver matte moleskin screen build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 11-13-2012, 01:20 AM - Thread Starter
Kristofer's Avatar
Ok! I'm at last building my screen! Thanks to this forum i've decided to go with the matte moleskin silver spandex over matte white. The fram is built of ... i don't know the word in english smile.gif but i'ts supposed to be harder than just the ordinary, but it's not oak wink.gif
The screen is 113" without the black border, so depending how i build that it will be a 104 - 108" viewing area.
I've painted the frame in the same color as the wall behind it, just for safety. The middle frame supports are made of a the same material but a couple of millimeter thinner so there should be no worries about it touching the spandex.
More images and info. will be posted as i go along ... Keeping my fingers crossed that it will turn out ok!
Once again thanks to everybody in this forum, and a big thank you to MississippiMan who is a fantastic resource here on the forum!
Kristofer is offline
post #2 of 30 Old 11-13-2012, 06:03 AM
splatee's Avatar
Quoted: 30 Post(s)
Looking forward to your build and your review on how the screen performs. I too am in the process of redoing my blackout cloth screen with spandex.
Thank you
splatee is online now
post #3 of 30 Old 11-13-2012, 10:29 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Looking good. I like that frame already.
smokarz is offline
post #4 of 30 Old 11-13-2012, 10:37 PM
Duke Broadway's Avatar
+1 on the frame. I also like your approach to not having the supports show through. Great minds think alike.
Duke Broadway is offline
post #5 of 30 Old 12-15-2012, 08:35 AM - Thread Starter
Kristofer's Avatar
OK! So here we go! Got my silver & white matte moleskin, my screen tight thingys and the frame! Here are some images so far.
Put some thin wooden pieces along the front of the frame to keep the fabric from touching the frame.
post #6 of 30 Old 12-15-2012, 07:21 PM
blastermaster's Avatar
Quoted: 438 Post(s)
Liked: 555
Looks good! Keep up the good work and you'll be rewarded with a nice screen. I also went with Silver over white. I had some friends over to watch the Bourne Legacy and they were blown away by the picture. I was thinking about switching it to white over silver, but I'm just loving the blacks too much so I'm keeping it as is. The best part is being able to put my speakers in the right spot behind the screen for optimal listening. I will never go back to a non-AT screen - it's that good.
blastermaster is offline
post #7 of 30 Old 12-15-2012, 09:43 PM
Looks good Kristofer. I just competed my build. Need to get some pics posted on my thread. I ended up using the backside of the silver metalic(which was a white with a sheen) as my backer to the silver moleskin. I can definitely tell it is brighter compared to 2 layers of the silver moleskin on top of each other.
post #8 of 30 Old 12-15-2012, 09:52 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1782 Post(s)
Liked: 814
I'm about to do a Silver "Millskin" overlay directly against / on top of a SF v2.5 2.0 Drywall surface.
Epson 8700UB
122" diagonal.
I'm counting on the lighter Silver Spandex combining with a positive Gain non-absorptive "Silvery" surface to create markedly better Blacks without adversely attenuating Whites.
I'll be removing the Velvet Trim, stretching the Spandex out, stapling the material to the Wall, then re-applying the Trim and edging the extra material with a Sharp blade.
It will serve to be a AT Screen because the Screen Wall itself is acting as the Center Channel Speaker due to the use of Audio Transducers.
This will be a first time ever attempt for me using this Spandex stuff, and I chose the lighter Silver Millskin just to hedge my bet a little bit..
MississippiMan is offline
post #9 of 30 Old 12-16-2012, 04:43 AM - Thread Starter
Kristofer's Avatar
I'm still a little bit concerned about the trim/frame, but i saw a sketch that you MM did and i guess it's quite straight forward. Do you think it will show much if i use two pieces of black velvet on the longest sides of the frame? I have some velvet left from the drapes and i can of course buy some more but i'm thinking it might not show as it's kind of pitch black.
post #10 of 30 Old 12-16-2012, 11:23 AM
when i mounted my trim border i did thinks a little different. I wanted the flexibility to remove the trim without damaging the screen and trim if I needed to change viewing surfaces, i.e. new spandex. When I made my trim I made it so it would be larger than the screen itself. I allowed for about an inch of the trim on either side to extend past the screen.
1. I used some L brackets to connect the trim pieced together. So i ended up with a nice little or big rather rectangle. I laid this on the floor.
2. I laid the screen on to the trim/border, getting it nicely centered so there was equal amount of "show" of the backside of the trim.
3. I screwed L brackets to the trim. One side of the L would butt up to the perimeter of the screen. I did this around the screen.
4. It looks good while its on the floor, but when you stand it up the screen would just fall out so need to secure it.
5. I attached some screw in loops to the backside of the trim and to the backside of the frame of the screen.
6. I then used picture frame wire and tightly secured the trim to the frame.
Ended up turning out as I had planned. Much expensive than just nailing it to the frame. It gives me the luxury of being able to easily take of the trim to remove my spandex if needed without damaging the spandex or the trim. I would only have to invest in more wire if needed.
post #11 of 30 Old 12-16-2012, 11:24 AM
Epson 8700UB
122" diagonal.
Interested in your findings with your first spandex screen. Be very interested in your opinions compared to other substrates once you get your hands and eyes on it.
post #12 of 30 Old 12-22-2012, 02:10 PM - Thread Starter
Kristofer's Avatar
Ok! So the screen is just up! Haven't done the black velvet frame yet! I went with silver over white, we'll see how it turns out!
One question! We stretched the silver as much as we could, and i noticed two creases on the surface, don't seem to go away with the stretch. Do you think it will go away eventually or should i steam it?
I'll post some shots of the screen later tonight!
post #13 of 30 Old 12-22-2012, 04:55 PM
I threw mine in the dryer for a bit before I mounted it. What wrinkles left did pull out easy. I dont have mine stretched super super tight.
post #14 of 30 Old 12-22-2012, 05:41 PM
Liked: 814
Well I've certainly gotten behind the use of Spandex as an alternative to the varied Mfg AT Screens, and perhaps as a result, several others have recently embraced Spandex as a "Regular Use" Screen surface as well. So I figure it's about time I gave it a whirl myself. redface.gif
The Spandex will be overlaying an existing Silver Fire v2.5 2.0 painted Drywall surface. The Primer coats were rolled on (...don't do that! ) and some Roller Mark streaking along the Top edge of the Screen was / is apparent during brighter, light colored content. The SF 2.0 surface certainly has "MORE" gain than the White Spandex normally used for a backing so it should work very well in this instance.
Wholly unacceptable, but the proud owner (sorta) cannot allow another complete re-masking and Painting job because of spousal considerations. rolleyes.gif
So this is gonna be the "Fix".
By my figurin' even if the Silver Millskin Spandex comes slouchin' in at 0.8 gain, under the set distance and screen size parameters I'll still smack the Spandex with 20 fls runnin' on Normal Lamp, and a easy 16 fls calibrated (...in Living Room Mode...)
I'm fully expecting more fls, but to err in excess as far as not having satisfactory Foot Lambert is to be all the more happier to be in error.
post #15 of 30 Old 12-23-2012, 01:13 AM - Thread Starter
Kristofer's Avatar
We'll, i'm not talking my screen down now smile.gif but the wrinkles ar not visible when projected on, so i guess i'll just wait them out!
I didn't get around to take any shots yeasterday due to exhausting work of putting it up smile.gif Will try again today!
post #16 of 30 Old 12-23-2012, 03:11 PM
jeremyhelling's Avatar
Quoted: 25 Post(s)
I was going to ask if it was something you could see when the projector was actually on but it looks like y'all had that conversation before I had a chance to reply. Mine had wrinkles too but it's not noticeable once the lights are off and the projector is on so I don't plan to do anything about it. I envision that some people must have larger or worse wrinkles possibly because mine are hardly noticeable really.
Jer
'Build a man a fire and he stays warm for one night. Set a man afire and he stays warm for the rest of his life.'
jeremyhelling is offline
post #17 of 30 Old 12-24-2012, 03:12 AM - Thread Starter
Kristofer's Avatar
Well, i guess since i have three spotlights directly above the screen it makes it more visible, but i'm not gonna do anything about it ...
Merry christmas by the way!
post #18 of 30 Old 12-24-2012, 04:18 PM
Quoted: 25 Post(s)
Yeah, I have no lights on mine and can see where that wold create shadows that emphasize the wrinkles. Why aim spotlights on a movie screen?
Ho! Ho! Ho! Merry Christmas!
Jer
post #19 of 30 Old 12-25-2012, 03:11 AM - Thread Starter
Kristofer's Avatar
Well, it looks good when there is no movie showing, and i have those three spotlights on a seperate channel so when i dim the cinema the screen goes out last, which look kind of cool biggrin.gif
post #20 of 30 Old 12-25-2012, 12:06 PM
Quoted: 25 Post(s)
I chose function over form. No lights for me when I'm watching mine.
Jer
post #21 of 30 Old 01-10-2013, 03:27 AM - Thread Starter
Kristofer's Avatar
OK! Loooong time and no post from me smile.gif haven't gotten around to shooting any screen shots yet, been to busy watching movies biggrin.gif But it will come eventually when the velvet border is in place as well!
Well here's a shot of the screen up on the wall, i went with silver over white ...
RedBull1985 likes this.
post #22 of 30 Old 01-10-2013, 06:53 AM
RedBull1985's Avatar
^^Awesome mate...now do post more pics with content playing.
Regards
RB
RedBull1985 is offline
post #23 of 30 Old 01-10-2013, 07:50 AM
Liked: 814
Originally Posted by Kristofer View Post
If you have those forward Cans over the Screen and deep in the Corners set on separate Dimmers I'm bettin' you can. wink.gif
That's a Class act you have going there. But I gotta say I cannot remember any time anyone has posted images in B&W.
BTW, are you going to treat the inside surface area of that Shadow Box and the Soffitt Overhang with something decidedly less reflective than White?
post #24 of 30 Old 01-10-2013, 12:48 PM - Thread Starter
Kristofer's Avatar
I'm all about black & grey so i guess i could start naming the cinema "Kodak Tri-X" biggrin.gif
The three cans/spots over the screen is on a separate channel in the dimmer so i can have those glow for a while everything else is pitch black.
My plan was not to treat the "shadow box" but it has come to my mind lately that it may be a good idea, even if i'm not especially bothered by the small amount of light hitting the sides. But who knows, maybe it will make a bigger difference than i think!
I would like to thank you and everybody else here for all the great tips i've gotten along the way!
Here's a link to my swedish gallery, which of course is in swedish biggrin.gif But it has some of the building process ...
http://www.minhembio.com/Wildkris
post #25 of 30 Old 01-10-2013, 01:28 PM
muzz's Avatar
Quoted: 619 Post(s)
Liked: 385
I like the room too, but was thinking the same thing in regards to the gray box right against the screen.
Looks Good!
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is online now
post #26 of 30 Old 01-10-2013, 03:46 PM
Liked: 814
This Guy is too modest........
Seems apparent because the room's height is low, and the Screen both large and mounted lower to accommodate the Soffitt, the rear seating "Riser" is a "Nose-Bleed" affair.
I have to say that's the tallest Platform I have ever seen....without a step! :eek" Makes me think about the Movie "Vertical Limit". Talk about "Virtual Reality! tongue.gif
Kristofer, will your guests use a Ski Lift and a Bobsled Run to get up & down from that Mountain Top? biggrin.gif
Post a shot of that Riser for everyone to see!
post #27 of 30 Old 01-10-2013, 07:04 PM
muzz's Avatar
Quoted: 619 Post(s)
Liked: 385
No ya Big Dummy, they are all Swedish Gymnasts!
Geez......some people!
muzz is online now
post #28 of 30 Old 01-11-2013, 01:51 AM - Thread Starter
Kristofer's Avatar
biggrin.gif:D
Well it's quite high, about 15 inches smile.gif but it works the way i wanted to, everybody can see the whole screen no matter how their chair is set! And since we drink so much homebrew here in cold and dark Sweden, no one cares if they fall down from it smile.gif It's no problem climbing that step, but it would have been kind of cool if i'd recessed (don't know if that is the right word) one step into the riser. Maybe a future project! Any way it'll be ready when you all come to visit biggrin.gif
And here it is!!
post #29 of 30 Old 01-12-2013, 09:56 PM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
Really nice room. Thanks for sharing what you are doing. I really like that his hobby has brought people from different countries together. I have read quite a bit of your experiences. We are all in this together and sharing is a lot of fun.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
post #30 of 30 Old 01-15-2013, 01:26 PM
Hank's Avatar
Quoted: 67 Post(s)
Liked: 26
Beautiful room, Kristofer! Thank you for sharing the build with us.
Hank is offline
Reply DIY Screen Section
