Spandex screen to speaker distance? - AVS Forum | Home Theater Discussions And Reviews
Old 11-27-2012, 10:22 PM - Thread Starter
allybuck64's Avatar
We are in the building planning stages of our room. What distance should I have between the screen and my LCR speaker? This distance will effect the depth of the stage and riser. Has anyone noticed the sreen vibrate from the Sub?
If this has been covered my apologize I tried to search the thread with no luck!
allybuck64 is offline
Old 11-28-2012, 08:12 AM
blastermaster's Avatar
Quoted: 433 Post(s)
Liked: 550
I haven't set mine all up yet (I'm at the screen stretching stage woohoo!), but I'd like to know the answer to that question, too. I have speakers with rear ports and they are happy when sitting around two feet away from the wall, but that sits them really close to the screen. I obviously don't want to see any movement in the screen. I'll have mine up tonight hopefully and I'll see how close I can get with the speakers then post back.
Video: Optoma HD3300, Panamorph UH480, Darbee Darblet, Samsung BD D6700 Blu Ray player, DIY Seymour Centerstage XD 138" Curved Screen
LCR - Tannoy DC12i, Sides - Tannoy IW63, Rears - Tannoy Saturn DC6ti Bookshelf, Ceilings - Tannoy CMS 603DC (TF), Tannoy CMS 601DC (TR), 3 Micro Marty/1 Full Marty DIY subs
Amplification: Emotiva XPA-3, Emotiva XPA-2, Outlaw Audio 7700, 2x Inuke 6000DSP
Receiver: Anthem MRX 720
blastermaster is offline
Old 11-28-2012, 10:52 AM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
i had mine just an inch away from the screen.
spandex behaves much more like woven screens rather than microperf ones. Perforated screens require 1 foot min. distance.
i have not noticed my screen vibrating from the LF reproduction. But this maybe depended on volume level, sub design (mine is sealed) , frame resonant frequency, how the screen is mounted, etc, etc.
zheka is offline
Old 11-30-2012, 07:38 PM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
Due to the size of my room I am using non ported mini type speakers mounted directly on the wall. The screen is about two inches from the speaker. Due to such small size of the woofer of these speakers I don't see any screen movement.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
Old 12-01-2012, 09:12 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1769 Post(s)
Liked: 807
I have not heard of a single instance where the SPL of even large speakers have ever created any noticeable movment on the surface of a Spandex screen.
This is due to the porosity of Spandex....air (...and hence "sound"...) can freely pass through.
MississippiMan is online now
Old 12-03-2012, 10:09 AM
Duane T's Avatar
My speakers are probably a 1/2 inch from the screen, speakers crossed over at 80hz, and I haven't noticed anything.
XBL GT: Big Bucket
Duane T is offline
Old 12-03-2012, 03:43 PM
rukus29's Avatar
Quoted: 35 Post(s)
i have mine ~5 inches from the screen. no audio issues. my sub is just off a side wall pointing parallel with the screen (about 3 feet in front) and have had no vibration issues with it.
rukus29 is offline
Old 12-03-2012, 10:08 PM - Thread Starter
allybuck64's Avatar
Thanks for all the replies. It looks like i will have about 1 foot of space.
