Building a Thin Edge or Edgeless screen. Materials, building methods and any other suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 12-22-2012, 10:27 AM - Thread Starter
darwindeeds's Avatar
HI Guys,
I have been reading a lot on this forum and finally decided to ask my questions.
I have done a few DIY screens for myself and friends using BOC and all them have turned out well. But recently I ran into a post of DNP Supernova Blade screen and I have been drooling over it ever since. I dont know if the price of ~3000$ is justifiable for the screen but I just dont want spend that much money on a screen. Hence I would like to build one similar to it. While I do understand that the screen material they use is of very high grade and works well with ambient lighting, the form factor is what impressed me the most.
I'm trying to build something similar to DNP Supernova Blade or SI Black Diamond Zero Edge with back lighting. More of mimicking the form factor.
I'm using an Epson 8350 projector in a fairly light controlled room and 120" screen would be ideal.
Here are the options that I have considered
1) Sintra board glued(?) to a thin wooden frame with LED back lighting.
Pros:
  • Highly recommended in most threads.
  • Light weight,
  • Paintable and probably will give me the best look.
Cons:
  • I live in St Louis, I dont think there is any place carries it around my city
  • hard to transport
  • it needs painting and cant be used as is
2) Wilson Art Designer Weight Laminate glued to wooden or metal frame with back lighting
Pros:
  • Easily transportable (can be shipped)
  • Sturdy (?)
  • Can be used as is (no painting required).
  • Easily Available (I dont know where to buy from, any suggestions?)
  • Could have a great look
Cons:
  • Heard abt hot spot issues and also saw a picture of one screen made out of laminate in terrible shape with bumps
  • Durability
  • Needs a heavy frame?
3) Work with BOC. I doubt if this is going to give me the Blade or Zero edge look?
Experts here please share your experience and suggestions?
darwindeeds is offline
post #2 of 28 Old 12-22-2012, 03:12 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
Originally Posted by darwindeeds View Post
HI Guys,
Pros:
  • Light weight,
Cons:
    Ha!
    Laird Plastics
    St Louis Area
    3128
    Rriverport Tech Ctr Dr
    Maryland Heights, MO 63043
    Manager:Scott Tobin
    Phone:888-287-0050
  • hard to transport
    Naw...easy. Lightweight. Durable. Bends enough to be helpful
    Yes it can, just not optimally. If you REALLY want a BD or DNP clone, painting "Anything" you have listed on here is a absolute prerequisite.
Pros:
  • Sturdy (?)
  • None of the above really, and it sure won't be ideally suited for a "Zero Edge" look with Rope Lighting, nor ever begin to act anything like any Ambient light Screen.
Cons:
  • Durability
All of the above. It just doesn't suit your purpose in any way I can get behind.
Sintra. Silver Fire 4.0
MississippiMan is offline
post #3 of 28 Old 12-22-2012, 03:16 PM
Kirnak's Avatar
Too find Sintra in your area, don't rely on the internet. You have to get on the phone and call around sign shops and plastic supply houses. I'd be extremely surprised if you couldn't find it in a city like St. Louis. Try the name Komatex as well, same stuff different brand. You'll want the 6mm thick stuff.
Oops MM beat me to the punch. Good for the OP, MM is certainly the go to guy on stuff like this. biggrin.gif
Kirnak is offline
post #4 of 28 Old 12-23-2012, 10:16 AM - Thread Starter
Thanks MM. You are the legend in the forum and thanks for sharing your thoughts. I guess Sintra is the way to go. I will call around and check out the place you have mentioned. You have suggested Silver Fire paint mix, I read in another thread that S-I-L-V-E-R fades over time and gets a yellow tone to it. Is that still an issue? I will do my research but if you have any reference to building Sintra screens, please refer me to it.
Is there a specific Sintra board that I should buy like White or Gray? 3MM or 6MM? Either way I plan on spray painting on it.
Thanks for the information Kirnak. I will go with the 6MM board and try the Komatex brand as well..
post #5 of 28 Old 12-23-2012, 01:12 PM
Liked: 806
Thanks for the effusive compliment. I hope it doesn't bring the Dawgs out to chew on my legendary leg. biggrin.gif
If you want to truly create a screen that comes as close to performing like a DNP "SN" as possible...or match / exceed the scope of a Black Diamond, Silver Fire is the application that must be considered.
S-I-L-V-E-R is all about having very appreciable gain but not sacrificing truly dynamic Colors and deep Blacks.
As for that "yellowing business"...that's almost assuredly a bunch of malarky...primarily because a very few have wanted to press an issue that MinWax Polyacrylic Satin will yellow over time. But you see, S-I-L-V-E-R doesn't use Polyacrylic, it uses Behr Faux Glaze.
To this date, no S-I-L-V-E-R I have ever been involved with, or helped another create has ever showed signs of yellowing....or fading. None. Nada. El Zippo. And I have one extremely large S-I-L-V-E-R (220" diagonal) to my credit that I can point out plainly that has been in use since 2006. If that Big 'Ol Sucker was even beginning to deteriorate, it would be terribly apparent. It resides in dedicated $150K Theater whose Owner is extremely picky...a real Performance Pre Madonna, and if he ever saw anything but what he felt was pristine...... eek.gif
As for Polyacrylic yellowing? Well, it hasn't ever done so on any of the 100s of screens I've painted. It only comprises just under 1/3rd the bulk content of the SF mix. The balance are acrylic painte, and water, both that would serve to dilute the Poly and further reduce any tendency toward yellowing....by my reasoning.
All I can actually do is speculate as to if you might ever have any issues therein. But that speculation is driven by several years experience, and since I've personally never had any issues, and "this Forum" doesn't have any posts to that effect that I can point to, I speculate that you also will not have any issue should you opt to use a mix like SF.
post #6 of 28 Old 12-24-2012, 09:06 AM - Thread Starter
Thanks MM for explaining that in detail. Between HTForum and this, there is so much of love/hate towards SF and Laminate. For someone who has no knowledge about either one of them, I'm having hard time deciding. I feel that the pros of Silver Fire is very good like appreciable gain, black etc but HTForum religiously hates SF for reasons like hotspotting. I dont understand why there is such a difference, is it because SF was developed here?
Also with the difference in opinion towards laminate, they seems to suggest laminate as the better of the two while you have strong opinions against it.
Can you please throw some light on it?
I really appreciate you thoughts and helps.
post #7 of 28 Old 12-24-2012, 10:27 AM
Liked: 806
So OK.
SF does NOT Hot Spot. It does have a positive gain factor, so the center of the screen...a VERY wide center, can show a variable level of brightness when a solid bright color is photographed. (...especially when "negatively" inverted.") And this is accentuated when a small screen is utilized, and even more so if a very small sample is used, placed at center. Those types of misleading methods are consistently used elsewhere in a attempt to show SF "in a bad light" but in fact, you will find virtually NO other similar commentary elsewhere. And you can be certain there are / have been enough SF End Users on AVS over the last 6 years that if only a small percentage of those had bad reports to relate, this DIY Forum would be inundated. But....it is not, and the very few who wander over 'elsewhere' certainly are going to be "educated" to the way of thinking that is prevalent on a Forum that is desperately trying to persuade any / all comers that their brand of DIY Screen making is the only valid way to consider.
And sadly, yes...SF is constantly targeted because SF is a AVS DIY Screen standard, resulting from a concerted effort to develop a alternative to expensive ambient light screens (...originally the SONY Chroma Vue...), due to a challenge directed squarely at this Forum by advocates of those expensive screens. But...no one else bothered to try except PB-Maxx and myself, and we pretty much nailed it in short order. At the time, a "few" people were engaged even back them at constantly harassing every advanced DIY application we / I offered...and back then, not a single one of them was but adamant that NO kind of application that utilized a reflective base was even worth considering.
It is a all to forgotten reason, that simple jealousy drove most of those comments. Not to say anything with that remark except that because of the exceptional amount of effort and time spent relating about out applications, and the inordinate amount of time spent helping all comers, we did in fact tend to dominate the Thread Board. For some, this "popularity" was intolerable...and our efforts "intentional" as far as trying to "own' this Forum.
Such attitudes are childish...and spiteful, and the type of posts generated and the bile that was spewed proved that. And as time progressed, it became a war of attrition that almost resulted in this Forum being closed. such was the single mindedness of a few people, whose primary goal became not so much ridding the Forum of my applications as much as it was ridding the Forum of me personally.
So those few moved (...or were made to move...) on by the Forum Administration, because as often happens when too much leeway is granted for too long, they took their actions much too far, damaging the Forum's reputation Worldwide (...and that was quite a feat to accomplish...) Of course, I played a part as I was one of only a few who stood up consistently (...with a bulls eye on my chest...) to those who acted so adversely and selfishly, and I would not hesitate to go "Mississippi" on 'em. Yes, I got censured at times when I got a bit to "adamant" at being called names and having accusations tossed my direction, but those others? Whoo Boy! Even after repeated temporary banishment s, stricken posts, and directly posted "Offical" warnings, they not only continued on, they elevated their contentious behavior to the point of accusing the Forum Administrators of favoring a person/s over the other.
Not a smart thing to do. The end result was a "very small" exodus to a location where those few could create a Draconian DIY Forum that is exclusive in it's acceptance of only what is considered acceptable on their terms. Crazily though...the same adverse behavior they felt so free to exercise on AVS is considered to be a "One strike and Your Out' sort of thing "over there". (Guilt driven...no doubt.. biggrin.gif .)
So there is your reason/s for the "hate" you read....and it's probably never gonna abate as long as this Forum maintains it's tremendous popularity...and I still draw in oxygen. redface.gif
Now after all that, on Christmas Eve, let me extend a Olive Branch of sorts (..well, at least a twig sized one...)
A time is coming soon when there will be far less a disparity in how DIY applications are presented. and excepting for missives like this one which try to set things in proper perspective, this Forum and me personally will not stoop to name calling or the degradation of applications or persons just to attempt to garner undecided followers. On truth, a close examination of posts show a lessening of all the adverse posting elsewhere, but as to if that will continue...who can say?
I sincerely hope that the tone (...if not indeed the intent...) of all posts in both locations can be hauled back into a "Happy Place". Aspiring or Wannabe DIY'ers deserve to be encouraged to explore options if possible, but if desirous of simply "gettin' it dun" , also be able to depend upon getting help when needed without dealing with acrimonious postings here or elsewhere.
So as often stated...let's all of us Play Nice, and stay off the "Naughty List".
Oh yeah. Laminate.
Well, there was once a time when any "Hang and Shoot' material was extremely lusted after. and Laminate served to allow people to have something along that order in sizes that most other materials could not. So some of the "less than optimal" aspects were pretty much glossed over. (...no pun that...)
Laminate is very brittle, and it doesn't take much of a miscue to render a over sized sheet worthless...or in the least only good for a smaller sized screen project.
Laminate possesses just enough of a sheen that often there is in fact a "Hot Spot"...which is correctly described as a "small" area of noticeable brightness that will move with the changing location of one's head.
Laminate as a rule demands that a very sturdy, very flat frame be built, one that will not tend to ever warp.
Laminate requires that it be effectively glued to such a Frame using a very thin but strong adhesive...usually Contact Cement. As such, it becomes a case where you get one chance to do it right...or scrap it.
So now...if one has a PJ with lower Lumens, or is using quite a bit of Zoom on a large Screen, many times the "Hot Spot" issue becomes less of a problem if not indeed resolved entirely.
All there rest of the caveats mentioned above deal with actual "building" issues, and if you / one can avoid them all, then yes, Laminate may be quite the serviceable material. And ("...heresy of heresies...) it can always be used as a "Canvass' on which to apply a painted Screen solution of choice should the "raw performance" not be satisfactory.
In the end, if a material like Sintra / Komatex can be had, it completely resolves all the adverse potential a Laminate brings to the table. As a staunch advocate for keeping risks at bay, I'll always suggest such material over a laminate. But when the need calls for a Laminate, then what is required is that the end user be informed and educated as to what to do...and what to avoid. It's really just that simple.
......and go eat some cookies. I'm sure they will be easier to digest than this self generated onus. wink.gif
post #8 of 28 Old 12-24-2012, 02:58 PM - Thread Starter
First of all, I called the Laird Plastics that you had suggested in the earlier post and they have 5' X 10' Sintra ready and available for pick up anytime (Awesome), I just need to figure out how to pick it up. frown.gif
Now on topic, thanks for taking time to explain whats going on. I hate to hear everything that was going on. With that said, I think SF is going to offer me the best brightness and I'm willing to try out the mixture. Plus I have tried black widow before and I had terrible time with it.
I will be happy to come back and post my DIY method.
post #9 of 28 Old 12-25-2012, 05:42 PM
Liked: 806
Luck can be fickle.
If your serious about accomplishing a really exceptional Screen build, ask for and follow advice...all of it, and don't just go off and "give it a shot".
There can be a huge gap between what you can accomplish on "hope & luck" alone, and what is actually possible with effective guidance and support.
So....choose wisely, and let "Luck" reside with those who are willing to gamble on uncertainty.
post #10 of 28 Old 12-26-2012, 10:47 AM - Thread Starter
Originally Posted by MississippiMan View Post
Luck can be fickle.
Well I'm definitely going to plan it out well. I'm looking for CAD like tool to draw out my sketches. I will use this thread to plan and build the screen. As of now here are the list of items that I think I would need.
  • Sintra 5' x 9' White board 6 mm thickness from a local dealer (~90$)
  • Color Changing LED Lighting x2
  • 1x4 Poplar for the frame.
  • Cove Molding. Going to use this to stick between wooden frame the board (Its hard to explain what I'm talking out. Once I get the sketch it will become apparant). Then run the LED along this.
  • Silver Fire 4.0
The build might have a 1/2" border like SI BD Zero Edge, I still haven't figured out.
What else do I need? Any other suggestions?
post #11 of 28 Old 12-26-2012, 12:02 PM
Liked: 806
Try Google Sketch-Up
It seems to be a very popular program, and the renderings I've seen are really precise and look expertly laid out.
You / we can get you to a true Zero Edge place...unlike that 'ol Mfg Screen pretender whose screen "DOES" in fact have a edge.
Please note that the Sintra is White. Your wall will not be. Ypu will want to use the white underside of the Sintra edge to diffuse and distribute the Light so it is not "harsh" looking as it exits out the edges. You want a "Glow"....not a hard "Bright" edge.
post #12 of 28 Old 12-26-2012, 03:20 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Sorry for hijack this thread, anyone know what's the gain of a plain white Sintra? 1.0?
WereWolf84 is online now
post #13 of 28 Old 12-26-2012, 03:36 PM
Liked: 806
Pretty close...no less, but probably not significantly more.
post #14 of 28 Old 12-26-2012, 03:38 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
post #15 of 28 Old 12-30-2012, 08:27 PM
tgse3's Avatar
100% agree with this!. Polycrylic and Polyurethane are drastically different materials. Will Polyurethane yellow over time? You bet. Will polycrylic? Not anymore than any other latex, and in fact I could make the argument that the addition of urethane molecules will in fact keep it more clear than 100% acrylic mixtures. If misinformed people believe it will, I'll be happy to give a sermon on the molecular differences between the alkyds and acrylics that comprise the two "poly"products. The solvents that comprise Polycrylic are drastically different from those that comprise polyurethanes (which in fact yellow more and more each day). In fact one of my manufacturers provides a 10 year labor and material warranty on products with similar molecular structure, if that tells you how confident we are in the resins. And when I say warranty don't give me that "but Behr, Lowe's, Sherwin, Menards, etc have lifetime warranties..." Read the fine print kiddos. As someone who works in coatings for a living I would have zero reservations about putting Polycrylic or other waterborne urethanes in my theater or anyone else's.
darwindeeds likes this.
tgse3 is offline
post #16 of 28 Old 12-30-2012, 09:04 PM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
Couldn't have been said better. The chances of boc, materials, textiles, and many hang and shoot substrates yellowing are far greater.
pb_maxxx is offline
post #17 of 28 Old 01-02-2013, 12:23 PM - Thread Starter
Alright I'm back after the break and thanks again to everyone and MM esp. I called the Laird Plastics and they have 5'x10' Sintra White 6mm thickness. They are willing to delivery it to me for 120$ including the shipping cost. Now the things I need....
1) What kinda of frame do i build? Should I fix the frame to the wall? I would prefer a removable frame.
2) How do I fix the Sintra to the frame? Again multiple options. Glue or use velcro. I like the velcro idea but is that a good option?
3) Should I paint the Sintra before attaching it to the frame or fix it to the frame and hang it before painting.
4) PAINTING, my nightmare. I have no idea how to do it. What do I need?
5) Back lighting, I plan on using
LED Lights, is this good? Or should I use the rope lights
Btw my point of reference has been this AVS post
Thanks again Guys!
Here is a poorly drawn Cross Section of my Plan
post #18 of 28 Old 01-02-2013, 04:35 PM
Liked: 806
Details will be forthcoming soon........................................after dinner and a few Margaritas.
post #19 of 28 Old 01-02-2013, 10:08 PM - Thread Starter
Oh I'm down for a drink! Btw what you do for the guys here is awesome. Respect!
post #20 of 28 Old 01-02-2013, 11:38 PM
Liked: 806
OK...say 4 of 'em. All Patron fueled.
post #21 of 28 Old 01-03-2013, 09:52 AM
Liked: 806
The best way to have a removable screen and a secure mounting solution....both at the most reasonable cost, is to have the Sheet overlay a frame of 1x lumber so that at least 1.5" overhangs the edges of the Frame. The overhang will be your "edge lighting shield"
Also, the Frame should have at least two vertical supports centrally located toward center so as to prevent any "outward" bowing by a unsupported center.
You could use Velcro....the Heavy Duty variety...and do so using long strips between 1/8" shims of material that help prevent surface dips. But don't expect the adhesive on the Velcro to keep hanging on if you ever pull the screen off. You can be certain that it will pull off the wood.....unless you shoot 1/2" staples through the "Hook" Pads. However the Velcro Pads on the material will come off, so you'll have to buy more to replace the part that pulls away.
And Velcro in the size and the amounts you'll need is not inexpensive. But if this Screen is to be "removable" it's about the only choice I can think of if your going for a Zero Edge look.
Frame it and paint it in place. You'll also need to use some Cardboard Wings along the Zero Edge to level out the 3/4" drop off so you prevent what is called Vortexing...(ie: The paint does not lay down along the edge, leaving a sparsely coated edge.)
http://www.amazon.com/Factory-Reconditioned-Graco-HV2900-Paint-Station/dp/B005QQ0AFS
It's really pretty easy....it just involves getting the viscosity of the paint correct, making sure you filter the paint into the Gun's Cup, and maintain a consistent pattern of spraying. See....it's easy! (...don't worry, we'll review technique later... wink.gif )
5) Back lighting, I plan on using LED Lights, is this good? Or should I use the rope lights
I use/used Rope Lighting...(...and 2x4 frame)...but recently LED "strip" offerings have come down in price a bit, and many offer alternating user-variable colors. Whichever you choose your screen design must incorporate access to a switchable electrical outlet located within the inside perimeter of the Framing, (...use a recessed outlet...) with a "pass through channel" through the framing (...or you dive under the Framing through the Drywall...) to allow the stringing of the lights along the outside edge of the recessed 1x framing. I noted on your drawing you used a "wedge". Don't.
Attach the lighting directly to the outside edge of the 1x
Thanks again Guys!
So OK....be advised that sometimes I can / do make things seem simplier than they can be. But also be advised that I'm available for virtually "Real Time" advice if you need it. Just PM me for a contact number, and if during the build, or during the acquisition of supplies you run into a wall of indecision or terror, you can call me....right them. Not post up afterwards in tears and frustration....or have to wait for me to get over a hangover.
post #22 of 28 Old 01-03-2013, 03:25 PM - Thread Starter
LOL, I do that during weekends.
1x4 is what I have planned for the frame and hang it using Z Hanger (thoughts?). Also is 1.5" a sufficient over hang? I was thinking more of 4-5". But again I dont know any better.
Agreed
"1/8" shims of material" Can you please explain this?
If the cardboard wings/painter's tape extends into the screen then there will be a border of unpainted area like your post (that has a border). Is that correct or should I stick the cardboard wings under the over hang to get the zero edge while painting? Also finding it hard to visualize this "3/4" drop off so you prevent what is called Vortexing" mad.gif
I dont have an outlet inside the frame but I do have one right under the screen area, Is that going to be a problem? Cant I plug it under the screen?
smile.gifsmile.gif Thanks for extending your support. I will PM my number.
post #23 of 28 Old 01-05-2013, 02:19 PM
odanota's Avatar
How is the build going? I am doing something very close to what you are doing so would love to hear how things work for you.
Have fun building!
odanota is offline
post #24 of 28 Old 01-06-2013, 09:18 AM - Thread Starter
Have fun building!
I have started getting the materials. I'm one month away from my first baby so time is on a crunch. I sure will update the progress. Good luck to you too.
post #25 of 28 Old 03-08-2013, 09:29 PM
onse's Avatar
onse is offline
post #26 of 28 Old 03-10-2013, 09:28 AM
jp86's Avatar
Looking forward to seeing how it looks! I will be doing something similar in a few months. I know it is recommended to have darker walls/ceiling in theater rooms, but how does that affect the LED ambient lighting? Should you leave the wall that the screen is on a lighter color or does it not matter?
jp86 is offline
post #27 of 28 Old 03-15-2013, 06:59 AM
tehotaone's Avatar
Quoted: 23 Post(s)
Guys I just completed an edgeless screen:
This is a fixed screen mounted to a wall in a a completely blacked out cave.
It is a 113 x 64 screen ( 130') No cost effective laminates or materials were available in my area
Construction is 2x4s directly mounted to the the sheetrock.
I used and amazing material called Flexiwhite from an online vendor on the net and through the "big river" (do a search for Flexiwhite screen material in the usual places)
I mounted the 2x4s to the walls adjusting them with the projector grid displayed.
Then I sanded the 2x4s smooth and file matched the joints.
Next up I covered the face and rollover surfaces of the 2x4s with Duvetyne tape. (this will keep the material from catching, and / or showing the surface differences underneath)
Finally, I stretched the material over the frame like a canvas, and air stapled it in place.
I have added 8-10' pieces of velcro to and bottom sides of the screen to attach masking panels made from felt.
It is completely edgeless and falls perfectly in frame, the effect is quite striking.
I have to say the FlexiWhite material from the "vendor place" is SMOOTH, very white and great to work with. It looks very much like a Stewart Snomatte 100 sample I have (texture wise, the Stewart is a warmer white)
The lack of any grain, fabric texture etc.. seems to make the screen disappear and it looks like a window when high displaying high quality 2d transfers and 3d material, it is easily my best screen to date.. over 14 years...
I will post pics as soon as possible, it looks amazing.
Carls Place Flexi White you heard it here first M-MAN!!
tehotaone is offline
post #28 of 28 Old 12-27-2013, 05:25 PM
icheat's Avatar
Quoted: 16 Post(s)
Has there been any progress on your build?
icheat is offline
Reply DIY Screen Section
