Stretching BOC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-06-2013, 11:17 AM - Thread Starter
bdj5773's Avatar
I just bought a piece of BOC. It is 54" width. I need to get it around 58" width. The length is fine. Will this fabric stretch to get it that wide? I haven't actually tried to stretch it but it does seem rather rigid.
bdj5773 is offline
post #2 of 10 Old 01-06-2013, 02:31 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
Are you saying the frame is 58", outside edge to outside edge? If so, I don't think it will stretch nearly that much.
Jim McC is offline
post #3 of 10 Old 01-06-2013, 02:46 PM - Thread Starter
bdj5773's Avatar
No, I haven't built the frame yet, but was wanting to get it to 58" if at all possible. I was just wondering if this stuff is stretchable? It seems rigid and while I think it will stretch some, I don't think it will stretch another 4"
bdj5773 is offline
post #4 of 10 Old 01-06-2013, 03:27 PM
curttard's Avatar
Quoted: 136 Post(s)
Liked: 37
It doesn't stretch much at all. If you google there is a guy who sells it in giant widths although it'll cost a lot more than the standard 54" from Joann.
curttard is offline
post #5 of 10 Old 01-06-2013, 03:50 PM - Thread Starter
bdj5773's Avatar
I believe it will stretch about an inch maybe two. I will just have to work with what I have. I do plan of making a lot larger screen in the future to put in another room. I watched Transformers on the plain BOC last night and looked really good. Can't wait to get this thing painted biggrin.gif
bdj5773 is offline
post #6 of 10 Old 01-06-2013, 07:39 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
When I built a BOC screen years ago, it was 52" X 92". There was enough left over for about 1" larger in both directions, that's about it. You have to have enough on the back to be able to staple it good.
Jim McC is offline
post #7 of 10 Old 01-06-2013, 09:53 PM
curttard's Avatar
Quoted: 136 Post(s)
Liked: 37
I just stapled to the front of my frame (didn't wrap it around at all) and covered the staples with my black border.
curttard is offline
post #8 of 10 Old 02-03-2013, 01:32 PM
nagoy's Avatar
bdj5773, how much success did you have? i.e. how much give was there?
I have some JoAnn's BOC 54", and when I measured the width laying flat it was already at about 54-1/2". Since my original plan was for a 54" x 127"-ish 1:2.35 screen, I was hoping that there would be at least another half inch of give after putting screen-flattening tension on the fabric. This would mean I only had a half-inch to staple on the vertical frames, but I'm hoping that with some care and attention, this method will work out.
First post, btw! I just got myself the Epson 8350, my first PJ.
nagoy is offline
post #9 of 10 Old 02-03-2013, 04:09 PM - Thread Starter
bdj5773's Avatar
I had success getting the screen up. However, there is not much stretching with this material. I was able to stretch around 1/2" more and that was about it. I stapled the fabric to the front of the frame rather than wrapping it to the back and thus loosing width. I haven't painted it yet but will. I have been watching movies on the fabric as is and the picture looks pretty good, but I know once it is painted it will be awesome.
Good luck!!
bdj5773 is offline
post #10 of 10 Old 02-04-2013, 07:18 PM
nagoy's Avatar
Good luck!!
Yeah, I too am planning to staple to the front of the frame for maximum height. I took a 2-inch strip from the roll of BoC to experiment with, and found exactly what you did: there is about another half inch of play. With the material being 54-1/2-inch in actual width, this means I have exactly the width necessary for 54-inch height. I have been trying to finally decide whether to build a 16:9 (54x96) or a 1:2.35 (54x127), and while bigger is almost always better around here, I think the 2.35 dimensions might be just a bit too wide for my room dimensions. Decisions, decisions!
Did you also make a post asking about whether the supports would show up behind the BoC (e.g. by adding a riser around the frame)? I was going to round over the edges of the central support piece(s) so there were no sharp edges. From your experience with your frame, do you think that would be sufficient? It doesn't seem to be mentioned as being a common problem.
nagoy is offline
Reply DIY Screen Section
