Do I need to put L brackets on both sides of the frame on a diy frame? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-07-2013, 02:54 PM - Thread Starter
Singh007's Avatar
I am going to build my own screen using blacktop cloth stretched over at wooden frame. Just wondering if the brackets need to be put on both sides or is it okay to just have it on one side? I would perfer to put them on me on 1 side because I am going with a very thin border and I don't want the brackets to come in the way and take away from my screen size.
Singh007 is offline
post #2 of 7 Old 01-07-2013, 03:18 PM
Durvelle27's Avatar
one side of the frame
Durvelle27 is offline
post #3 of 7 Old 01-08-2013, 01:45 PM
Warlan's Avatar
Quoted: 60 Post(s)
Cut triangular pieces of plywood (I used luan plywood, thinnest I could get) for braces instead. Take a square piece, 12 inch a side and cut it diagonally to make two triangle pieces. Repeat and you have the four braces. Glue + screw and you're done.
Warlan is offline
post #4 of 7 Old 01-08-2013, 02:31 PM - Thread Starter
Singh007's Avatar
So, the glue goes between the plywood and the front of the frame? Do I need to glue the edges of the wood pieces too? (where 2 pieces of wood are touching each other)
Singh007 is offline
post #5 of 7 Old 01-08-2013, 04:16 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1766 Post(s)
Liked: 806
Wow.
Nope....the Triangular Braces go across the "Back" of the Corners. When such larger, overlaying triangular wood braces are used, it can help a "one man team" get the edges alignedand laying flush to each other. But most importantly, those type of reinforced corners add considerable strength.
The only drawback is the "added thickness" a 1/2" piece of multi-layered (7 Ply) good quality Plywood adds I don't myself suggest using 1/4" Veneer-type Plywood ...but I prefer more strength.
Using "Wood Glue" is what you want to do, and Coarse Threaded Utility Screws (1-1/4" long) set flush into pre-drilled holes to prevent splitting of wood.
MississippiMan is online now
post #6 of 7 Old 01-08-2013, 10:29 PM - Thread Starter
Singh007's Avatar
Originally Posted by MississippiMan View Post
Wow.
I know where they go...i was just confused because the instructions have screws and glue..just wondering where the glue goes...but I figured it out now.
Singh007 is offline
post #7 of 7 Old 01-09-2013, 08:12 AM
Liked: 806
Well awlrighty then. I do realize how so many different takes and suggestions can get confusing. That has been the bane of so very many DIY'ers having to read so much and try to absorb / sort through it all.
But take heart....there will always be someone available to try to set things straight.....and add to the confusion even more. tongue.gif
Reply DIY Screen Section
