So if I am painting my screen on drywall what am I using for the border around it? - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2013, 03:50 PM - Thread Starter
adisonjim36's Avatar
Ok so I know I am going "grey" w my paint but I was curious what I use to make the frame?
adisonjim36 is offline
Old 01-07-2013, 05:46 PM
tank01's Avatar
I went with a nice 3" door molding. It cost about 3.00 for every 8 feet. I painted it flat piano black and couldn't be happier. I also painted the wall of the screen in the same black, so the moldings are barely visible but their there.
infocus 4805, mitsubishi hd1000, optoma hd 20 for one month, and now epson 8500ub
tank01 is offline
Old 01-07-2013, 11:34 PM
Brad Bonnell's Avatar
wondering the same thing, saw some nice examples of crown molding with rope back lighting, anyone have any problems with this
Brad Bonnell is offline
Old 01-08-2013, 07:30 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
Guys, it's a simple as using 3.25" Primed MDF Base Molding. It's usually about $0.68 per Lf at Home Depot, more at Lowes. However at Lowes you can find smooth, rounded edge MDF Base in 2.25" width, which is great if you want a skinny'er trim for a smaller sized screen.
See this Tutorial:
http://www.avsforum.com/t/865218/wrapping-black-velvet-on-trim-with-mitered-or-butt-joined-ends
Using the same material (MDF) you can instead paint it Black as well, but in no way will that have as good a result or as impressive a look / feel as Black Velvet wrapped Trim.
If your referring to Crown that has a angle on each end, the issue is how to attach that trim using only that very small footprint. (...you can do it by ripping a very small Triangle to use as a "Nailer" and gluing it to the Wall first...) If your wanting to back light the edges with Rope / Led Lighting, the standard procedure is you have to fur out the main screen surface at least 3/4" (1.5" is best) and simply place the MDF Trim so that the outside edge overlaps the Rope lighting at least 1.5"
MississippiMan is offline
