Acoustic Transparency of Spandex - The Truth - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
Old 11-26-2015, 08:43 AM
Livin's Avatar
Quoted: 189 Post(s)
Liked: 51
MississippiMan
I'm almost done redoing the front wall of my 15'w by 24'l room. The wall where I can put a screen is 152" wide.
I'm currently using a Benq w1070 (will upgrade to a Sony or JVC when funds allow)
What is the largest size screen you would recommend for my setup? And what distance to mount the projector?
Thx
Sent from my HTC6525LVW using Tapatalk
________
Ltek
setup: Kodi, Paradigm-Velodyne-SVS, 120" DIY Spandex Screen, Sony 45ES
Livin is offline
Old 11-26-2015, 11:43 AM
jkosanke's Avatar
Originally Posted by bud16415 View Post
If I can ask a question about your setup?
How will you get your projector to focus on a curved screen? I also have been thinking about curved screens and the focus problem is my biggest issue in trying.
Bud,
The screen is 115.75" wide (ID) of a 2x8 support frame and 118.75" (OD). This is .5" over the calculated 115.25" width needed for a 125" diagonal 2.37:1 aspect ratio needed so the picture frame (wrapped in black velvet) will overlay the support frame on the inside by .25" on all sides. The depth of the curve at the center of the screen is only 3.5" in my case. I will check the focus when completed and if it is unacceptable I will go back to an anamorphic lens.
I am taking pictures and hope to share the tweaks I have made to other designs that have inspired and given me the opportunity to learn from the experiences of others on this great forum. I have attached a pdf file that I found helpful in creating a smooth curve.
I am not sure when I will be able to post my screen build as last week the northwest suffered a severe wind storm with a loss of power to approximately 175,000 people in the Spokane, WA area. Our power was restored after 3 days but many trees were also knocked down including a 70+' ponderosa pine on my house causing extensive damage. On top of that we received our first snowfall Tuesday.
I hope this helps and let me know if you have any other questions.
Jack
File Type: pdf Chords and arc heights - Math Central.pdf (358.9 KB, 29 views)
jkosanke is offline
Old 11-26-2015, 03:02 PM
jkosanke's Avatar
Thank you, your welcome....And I'll do my best.
With such a slight radius, if the Spandex is stretched equally across the Frame, with just a slight adjustment "directional-wise", it will conform to the curvature even better than a material without such 4-way stretch potential. In any case, it's easily adjustable. It won't take much effort, or a really significant difference in tension.
Since I do not know what materials or method you are using / have used to construct the frame, I'm limited in what suggestions I can provide. I can relate that if a Flexible Frame is used, and the material is stretched across it first, when it is bent into the Curve desired, the Spandex easily conforms equally to said curvature.
A great PJ, that. More on that below....
No.....White over White. You need none of the additional Contrast enhancement Black would provide, and two layers of White will effectively mask any surfaces behind the first initial layer.
Also, White on White will maintain the maximum allowable Gain that Spandex can provide.
And you should. By availing yourself of the Lens Shift, you should mount the PJ as far forward as you possibly can tolerate. Again, this is to preserve your available Lumen output, and therein the gain off screen.
Looking at all the above suggestions, if you place the PJ forward to 14'-3" to achieve 20 fl (18' would garner only 16 fl ) your results watching 3D in a totally darkened room would be very acceptable.
Following just behind it's fantastic Audio properties, the one other thing that helps justify Spandex above all else it it's smoothness. Using DLA optics, the last thing anyone would want is seeing any vestige of surface-induced texture. XD material just isn't in the same league in that respect. Virtually nothing "AT" is for that matter.
Hey...I got'cher back, Jack.
(...I couldn't resist.... )
MM,
Thanks for the quick reply and I hope you are having great Thanksgiving!
To answer your question about what materials or methods I have or am using I hope the following makes sense:
The material I am using for the support frame is almost clear, hand selected 2x8 fir/larch (nominal width is 7.25") with the 3.5" depth of the curve cut out over an arc of 118.75" leaving a 3.75" width at the center. I was going to route a key track approximately 2" back from the front edge to slide black .25"x.75" hex head bolts to line up with the black .25" (ID) grommets I was going to put in folded over and glued XD material to be tensioned with .125" 325 paracord. The .25" hex head bolts would be topped with black washers and locked in place with a black .25-20 x .375" Knurled Thumb Nut. Below the knurled top is a nice rounded groove to rap the paracord. Each side would have two paracord locks to adjust the tension independently. Two 1x3 clear hemlock supports placed 1/3 from the sides to provide horizontal support. Route a 45 degree angle on the back inside edge of the top and bottom support frame for long french cleats with an allowance to adjust laterally to center. Black felt on the wall facing edge. The outer picture frame wrapped with black velvet will overlap the inside edge of the support frame by 1/4" and will be built flat with 3 flush bolts on the top and bottom (1 in the center and the other two 1/3 from the sides to pull the frame to the curvature of the screen). The velvet frame is 3.5" wide and will extend 1.75" beyond the support frame. I was planning on putting 2 90 degree angle brackets in each corner to align the velvet frame on the support frame. If I put LED rope lights around back of the velvet frame there will be no light leakage to the inside. Additionally, if I put some LED lights behind the screen to light up the inside to see the speakers it will not leak out around the edges.
Now that you have saved me from the brink of ordering the XD material and I am sold on the white Milliskin I would still like to be able to adjust the tension on the Milliskin, if possible, instead of stapling?
Do you know if it is possible to fold over Milliskin 2 or more times and/or either glue or sew clear elastic to reinforce a seam to put grommets in? Or if the Milliskin can be folded over on itself to allow a a stiff wire to be inserted to provide tension in both directions? The more I think about it the more it seems like a lot of work since the stretchiness of the Milliskin is the tension that the XD doesn't have.
I am assuming that once the Milliskin is laid out the order of tensioning/stapling would be starting with the center top and bottom then the center sides and gradually work your way around in a circle until the corners are reached? How do you tell what is enough or too much tension for the Milliskin? Is the tension the same for both layers? I would think that once the initial tension is set that it would be fairly easy to duplicate by just watching the material as you pull and staple. Can a coin drop determine if the tension is correct? Or a spring scale for the opposite side of the first staple? Another thought I just had is probably the simplest - if the Milliskin should be stretched say 15% for every foot that would translate to 1.8" for every foot which can be easily measured!
What is the gain of 2 layers of Milliskin matte white you used in your screen calculations?
I am also considering implanting round coin sized neodymium magnets under the velvet to add 1.78/1.86 and/or 1.33 masking panels at a later date. Do you have any suggestions? Would the Milliskin matte black make a good AT mask?
I have 3 Sunfire CRS-3C speakers that will all be mounted vertically behind the Milliskin. Should the speaker grills be removed? What is the closest the speakers should be to the Milliskin?
Is there anything that an Audyssey XT32 calibration does not correct on an AT screen?
Wow, I hope this isn't too much information. Any suggestions greatly appreciated!
Jack
bharv2221 likes this.
jkosanke is offline
Old 11-26-2015, 08:07 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1773 Post(s)
Liked: 808
Originally Posted by Livin View Post
MississippiMan
Thx
Suggested Throw Distance: 11'
Foot Lambert for both the following size is 18 fl @ 0.9 gain (White on White Milliskin)
Largest Suggested Screen Size:
16:9 @ 126" Diagonal = 62" x 110" (view-able)
Mount Speakers within 6" of Spandex. You can remove the Grills...it cannot hurt
MississippiMan is offline
Old 11-26-2015, 08:11 PM
Liked: 808
Jack...lots to digest while digesting.
I'll attempt to answer you coherently tomorrow.
Old 11-26-2015, 08:24 PM
Livin's Avatar
Quoted: 189 Post(s)
Liked: 51
Would white on silver or black increase contrast noticeably?
I'm using BOM from Joanne fabrics with a 11' throw and the w1070 is super bright even in Ecosmart and Eco modes
________
Ltek
Livin is offline
Old 11-27-2015, 03:42 AM
Liked: 808
Silver underlay would give the most "controlled" increase....Black the most dramatic. But the subsequent loss of gain ( 0.8/ Grey - 0.7/ Black ) might overwhelm even the 1070's brightness at sizes larger than 120" diagonal....especially if any 3D viewing comes into play.
Old 11-27-2015, 08:53 AM
Livin's Avatar
Quoted: 189 Post(s)
Liked: 51
I guess I could do WoW and buy some Black and/or Silver for when I get a projector upgrade to an Epson 5025/30 or Sony? But even right now, Contrast & PQ is more important than brightness to me - trying to squeeze as much out of my W1070 until I can afford an upgrade.
How much difference is 15 or 16 vs 18 FL? If I want a 139-140" diag the calculator shows 15-16FL (looks like 140 is on the bubble) - placing the proj at 13' throw (which would be nicer since it would be behind the first row of seating (less noise).
thx for the help!
________
Ltek
Livin is offline
Old 12-06-2015, 08:39 AM
DavidK442's Avatar
Quoted: 513 Post(s)
Liked: 344
I concur. A couple years ago I resurfaced my 114" wide screen (130" diagonal) four times while experimenting with various combinations; WoW, SoW, WoS & WoB.(The poor frame looks like a pincushion from all the staples). I settled on WoB in an effort to optimize the balance between brightness and black level. Now 4000 hours later the image from my W1070 mounted 11' feet away is still very watchable however I am aware that it is tad dim. A bulb replacement will bring back the "pop", but White over Silver would likely have been a better compromise.
DavidK442 is offline
Old 12-12-2015, 08:26 PM
PrimeTime's Avatar
Quoted: 556 Post(s)
Liked: 267
Since I am planning only a 100" diagonal, WoB (or just W -- I have a black background) seems the best.
PrimeTime is online now
Old 01-04-2016, 11:48 PM
jkosanke's Avatar
Originally Posted by jkosanke View Post
MM,
Jack
MM,
Your quote:
Pictures attached,
The outside dimensions of my frame is 118.75" wide and 52" high. If I allow for a 50% stretch in both directions I would be cutting the spandex to 79.2" (W) x 36.6" (H). Stretching another 2" in each direction (1" around the corner of the frame and 1" to fold back over the elastic hem) would result in 54% stretch horizontally and a 59% stretch vertically. I have attached pictures of my frame with a 1/4" T-Slot routed around the entire frame 1-7/8" back from the leading edge. The 1/4" hex bolt will slide in the T-Slot with a washer and knurled knob to line up grommets attached every 2.5" (unstretched) and every 3.75" after stretching. The 1/8" paracord will be laced through the grommets and around the groove in the knurled knob.
Your quote:
I am not sure what you mean about "...with just a slight adjustment "directional-wise", it will conform to the curvature even better than a material without such 4-way stretch potential. In any case, it's easily adjustable. It won't take much effort, or a really significant difference in tension
I mocked up a table with dimensions of 118.75" x 52" and covered it with a tarp to keep from snagging the spandex when I work on it. Is a sharp razor the best way to cut spandex? Scissors don't seem to cut very straight.
I am ready to prepare the spandex to attach to the frame when I return from CES and was wondering if you have a final suggestions?
Thanks again for your help and Happy New Year!
Jack
Name:	Screen Frame Front View.jpg
ID:	1162842   Click image for larger version
Name:	Screen Frame Side Profile.jpg
ID:	1162850   Click image for larger version
ID:	1162898   Click image for larger version
jkosanke is offline
Old 01-04-2016, 11:49 PM
jkosanke's Avatar
MM,
Jack
MM,
Your quote:
Pictures attached,
Your quote:
Jack
jkosanke is offline
Old 01-05-2016, 06:53 AM
Liked: 808
MM,
Your quote:
Pictures attached,
Oh Jack.
The Spandex will never stretch to 50%. Not even close. 20% would be...well a stretch.
For your "Length" of 118.75" you'll need a minimum of 4 yards because stretching 3 yards (108") just won't happen without opening up the weave and also creating a "bridge" between the two higher end-points.
Your quote:
I am not sure what you mean......
As in most such use of Spandex you will be starting at the center of the long edges with your first attachment. Then the center of each end. Because of the Curve you will want to minimize the pull length-wise, and equalize any "bridging" through the "directional-wise" adjustment across the short axis.
Do not attempt to cut the Spandex on the Width side (58"-60") until your certain of the degree of stretch you'll use. I'm more than a bit concerned about your attachment method since this is not a non-stretch, dense cloth. I do suppose that if you cut the material to a dimension that includes folding and Hemming the edges for additional strength at the tension points, that would make a lot of difference.
That would mean cutting (with SHARP scissors) the material to 124" long and leaving the Width as is, and folding / sewing the perimeter edges to the actual screen dimensions. Then you'd stretch out to the amount needed to effect a smooth layout.
Jack
I hope I did in fact "help".
MMan
Old 01-05-2016, 02:28 PM
jkosanke's Avatar
Oh Jack.
MMan
MM,
Thanks for letting me know that 20% is the max I should stretch the spandex. I have seen posts where it was stretched up to 100% and that sounded well like a stretch. I want to be in the Goldie Locks range and your 20% number is the first I've seen.
My intent is to seam two adjacent sides first and clamp the corner where the seams meet and then mark the other end of the two seams before having two people pull each of the unfastened ends to measure a 20% stretch on the flat table. It would also enable me to see if say 15% or 10% would work fine?
Is the intent of the stretching just to make the screen material flat without an ripples or wrinkles? Is there a point where it is not stretched enough and it affects the AT? I purchased 7 yards and had it shipped wrapped around a tube so there are no folds. It also appears like they sent an extra couple of feet.
If 20% is the max, what is the minimum that I should not go below?
If I have problems with trying to use my approach to fastening the screen material I can always fall back on stapling.
I appreciate your quick response before I attempted to stretch the spandex to 50%!
Jack
jkosanke is offline
Old 01-08-2016, 02:25 PM
Pultzar's Avatar
Quoted: 47 Post(s)
I have been excited about Milliskin until I found out that the rolls are only available in 60" width. Does anybody know if this can be purchased wider?
I want to build a screen that is 72-75" tall and will need at least an extra inch for attaching to the frame...
Pultzar is offline
Old 01-08-2016, 03:53 PM
techtre2003's Avatar
Quoted: 159 Post(s)
Liked: 90
Here is a 120" wide spandex. It's only 2-way stretch though; not sure how much difference that makes...
http://www.spandexhouse.com/products...id%20Colors%29
techtre2003 is offline
Old 01-08-2016, 04:05 PM
Pultzar's Avatar
Quoted: 47 Post(s)
Cool thanks. I ordered a few yards of the 60" to see how well it stretches up but may get some of this to compare as well.
Pultzar is offline
Old 01-08-2016, 04:22 PM
Liked: 808
72 inches is doable...and approaching the maximum. Settle for 70"s and your in there.
Old 01-08-2016, 05:21 PM
Pultzar's Avatar
Quoted: 47 Post(s)
But my current screen is 72". How can one possibly go with a smaller screen? Not possible! hehe
I am interested in the AVS screen material but that isn't currently available.
Pultzar is offline
Old 01-09-2016, 06:21 AM
Liked: 808
Well I did say 72" was possible.Just that 70" was all the more so.
Stretching the 60" Spandex 8 " in each direction (16" total) is within reason. You'll just have to be certain you stretch it equally in all directions.
Old 03-07-2016, 11:13 AM
donaldk's Avatar
Quoted: 417 Post(s)
Liked: 86
Any discussion in this thread of spandex' rear projection qualities?
donaldk is online now
Old 03-07-2016, 11:35 AM
Liked: 808
Nope...but it does work, albeit with significant attenuation.
Old 12-08-2016, 03:08 PM
Time for a quick idiot check before I start buying things
Well, it's looking more and more like I will be following this path at some point in the near future.
I currently have an Optoma HD141x which is a great value for the cost, though it is neither the brightest nor highest contrast projector around. I am currently projecting onto a 100" diagonal 16:9 electric blackout cloth screen.
My room is multipurpose, but dark. The room itself is about 14' wide and maybe 28' long, with the screen on the 14' wide wall. All surfaces in the half of the room where the screen is are black. There is a window, but it has a blackout curtain that does a good job of blocking out light, especially at night when 90% of my projector use is. The other half of the room has light surfaces and some smaller amount of ambient light, particularly in the daytime of course, as it is a dining room that opens to a kitchen. So overall pretty well light controlled, but not quite bat cave. I will say that I have never felt like my projector wasn't bright enough, but I have felt like the blacks were not what I wanted them to be.
Now, I have three reasons to want to upgrade my screen:
1) My screen is cheap and has some minor wrinkles and such in it. It looks fine, I don't notice them while watching, but they're definitely visible and I know it could be better.
2) I am finally getting to the point where I am unwilling to accept voices coming from 2-3 feet below where the speaker's image is. I have a 5.4.4 Atmos/DTS-X surround system, it's silly to accept speakers that aren't where they should be. Plus with Mark Henninger's recent results using PA style speakers using DSP, I am jonesing to kick up my center channel performance in general.
3) I would like to step up to a 2.39:1 screen with the same image height as I have now for 16:9. I have plenty of room to the sides, in fact my room is just about the perfect width to have a 126" diagonal 2.39:1 screen (same height as my current screen) and still leave just over 2' on each side for a black Spandex panel for the main L and R speakers and subwoofers.
So, I used the Projector Central Calculator to determine my setup, it looks like at a 15' throw distance I should be able to hit my target image size. Now, I used a screen gain of 0.8 and got a calculated foot-lambert value of 21 fL, which should be just fine for a fairly well light controlled room, correct?
So 0.8 is a somewhat reasonable estimate for the gain of a white over silver screen made with two layers of milliskin, correct?
I would love to have the silver over white for even better black levels, but I'm thinking that my Optoma HD141x may not have the lumens to overcome that much attenuation in the name of black levels. I suppose that since I just have a straight white screen now, the combination of white over silver and the innate attenuation of having an Acoustically Transparent screen will probably be enough of a difference.
Also, I've seen some limits as to about how much to expect the spandex to be able to stretch (~20% max), but is there a target stretch amount? Basically the bare minimum it takes to stretch out all wrinkles, etc. and provide a flat plane? So if I need a length of 117", then 3 yds or 108" should be acceptable, as it's about an 8% stretch, or a 12% if I add 4 inches for stapling?
I think I've just about got everything figured out, but figured I'd run it past the forum in case I'm making some sort of egregious assumption.
Thanks for anyone that chimes in, and thank you SO MUCH to the OP for doing those measurements. It's so rare to see some hard performance facts in the DIY world.
skipford likes this.
kodyaudette is offline
Old 12-08-2016, 06:56 PM - Thread Starter
tuxedocivic's Avatar
Quoted: 1910 Post(s)
Liked: 1730
Hey glad the info is useful to you. I dont think Im much help to picking your screen and stuff, but just wanted to correct your final sentance. The opposite is true about hard performance facts. The diy always tends to lead the commercial realm in presenting good into. The commercial guys either are biased in their presentation or they conceal the facts. The DIY guys (speakers, amps, screens, wires, etc.) always want the truth and have no reason to conceal it. The commercial guys like to pretend and reinforce a misconception that the DIY guys have it wrong and only commercial products can possibly have the requisite R&D, field testing, knowledge, test labs, etc. to be able to produce the hughest level of performance. But I dont shy away from this: That logic is totally wrong!
Ryan
tuxedocivic is online now
Old 01-08-2017, 05:43 AM
kgveteran's Avatar
Quoted: 372 Post(s)
Liked: 131
Should the material be washed and dryed first ?
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
Old 01-08-2017, 04:47 PM
Liked: 808
No. If it came to you dirty or stained....call and arrange for a replacement.
Old 01-08-2017, 05:56 PM
kgveteran's Avatar
Quoted: 372 Post(s)
Liked: 131
Originally Posted by mississippiman View Post
no. If it came to you dirty or stained....call and arrange for a replacement.
10-4
Old 01-09-2017, 07:13 AM
skipford's Avatar
Quoted: 25 Post(s)
I am excited to read this! I too am very near a point of wanting to do the same as you and make the switch to 2.39:1. I didn't find where you stated what your projector hardware was going to consist of? Are you buying a new projector or does your current one support zoom for CIH?
Also my other dilemma is whether to go with spandex or milliskin. I have samples of both. Milliskin scares me for diminishing dB too much. I'm leaning toward spandex but don't want a screen door effect. What are your thoughts?
skipford is offline
Old 01-09-2017, 10:26 AM
Liked: 808
This all makes little sense. (...no offense...)
Milliskin IS Spandex, and is among the finest of Spandex Weaves.
Milliskin has show the least db attenuation of any Spandex weave.....
Milliskin shows NO SDE....at all...it's finer Weave does not accentuate any SDE that is coming from the PJ, nor does it introduce any "weave effect" in and of itself. Leastwise as long as your not watching content from >6" away.
Old 01-10-2017, 03:45 PM
skipford's Avatar
Quoted: 25 Post(s)
Sorry I meant Moleskin versus Milliskin.
skipford is offline
