Optoma HD20, 80" diagonal screen, MDF - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-27-2013, 04:29 PM - Thread Starter
qwerty11's Avatar
I am going to use MDF as my screen foundation as the small size will easily allow for this to be done with one sheet. The projector will be 9 feet from the screen. Projector being used is an Optoma HD20. Light will be completely controlled in the room.
What paint formula should I use with this application? It cannot be sprayed on, must be rolled or brushed.
Thanks for the help!
qwerty11 is offline
post #2 of 3 Old 01-27-2013, 05:16 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1800 Post(s)
Liked: 819
MDF will require priming on both sides to seal it properly to prevent bowing / warping, and to equalize absorption.
Both sides should receive 2 coats - 1 coat of Primer at a time. The "rear" needs not receive any sanding after any coat, but the "Screen" side should get a light sanding after the 2nd Primer Coat.
When your ready to roll on a Finish coating, consider RS-MaxxMudd LL for an advanced solution, or a very light Neutral Gray for something crazy simple. Check out the DIY Sticky " http://www.avsforum.com/t/929997/beginners-guide-to-simple-diy-painted-screens " and read up on rolling as well as choosing a basic N8.5 Gray
You should expect to roll at least 3 light Finish coats of whatever you choose.
sdmbbs likes this.
MississippiMan is offline
post #3 of 3 Old 01-27-2013, 11:07 PM
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
Make sure you also prime all 4 edges.
Jim McC is offline
Reply DIY Screen Section
