Wilsonart Designer White Montreal. Quebec - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-10-2013, 08:37 PM - Thread Starter
reffy's Avatar
Hello,
Hoping somebody can help me out to find a Laminate Wilsonart Designer white sheet (5x10 or 5 x 12) in Montreal or Quebec.
Desided to go the DIY-Screen route. The Laminate would serve for a fixed screen project and most important: - it would be cat save.
We have two monster cats who would love to play pirate with a tissue screen ;-)
Thanks in advance!!!
reffy is offline
post #2 of 4 Old 02-16-2013, 05:15 PM
Flacido's Avatar
If there is a Lowes in your area I suggest starting there. Wilsonart DW was definitely available through the Ontario stores at least as late as sixteen months ago. I cannot speak with authority as to the current situation in Quebec, or Ontario for that matter. Inquire at the kitchen counters department and expect it to be a special order that arrives rolled up in a box.
Flacido is offline
post #3 of 4 Old 02-16-2013, 07:23 PM
jwh92020's Avatar
Here is some info on a Wilsonart Distributor in Toronto. I'm sure they can tell you where the nearest dealer is to you. Might be cheaper than ordering through Lowe's or Home Depot. Good luck.
Wilsonart
380 Courtneypark Drive East, Unit A
Mississauga, ON L5T 2S4
Tel: 905-565-1255
Fax: 905-565-1280
jwh92020 is offline
post #4 of 4 Old 02-17-2013, 06:50 AM - Thread Starter
reffy's Avatar
Thank you for all the information!
Last week, i tried ordering from Rona, but they not called back.
I checked Lowes website and it seem they have no stores here in Quebec. Monday i will try the Wilsonart Distributor for availabiltity .
And i thought building the screen is more difficult, but finding the supplies can be challenging smile.gif
If all fails, would be a BOC / Blackout Cloth screen a good alternative for an Epson 5020 120" screen solution?
Again thank you both for your help!
reffy is offline
Reply DIY Screen Section
