Adding upper 'stupid' masking - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-19-2013, 06:56 AM - Thread Starter
royi28's Avatar
Hi Guys,
I would like to add a masking to the upper border when using cinemascope ratio, the white above the picture drives me crazy...
I have a manual pull down screen.
I wan to add something simple, easy to deploy, easy to remove, was thinking of some black cloth hold in the side with some clip, will it hold properly? has anyone done something like this before?
adding some pictures:
royi28 is offline
post #2 of 7 Old 02-19-2013, 06:57 AM - Thread Starter
royi28's Avatar
royi28 is offline
post #3 of 7 Old 02-19-2013, 09:07 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1767 Post(s)
Liked: 806
Get a Roller Blind, paint it "Disney Color - Mouse Ears" black (spray).
Probably your best best considering your stuck with a 4:3 screen.
MississippiMan is online now
post #4 of 7 Old 02-19-2013, 11:03 AM - Thread Starter
royi28's Avatar
I want to have the option of 16:9 (without masking) - still, my main content is 16:9, so painting it won't work
royi28 is offline
post #5 of 7 Old 02-19-2013, 01:19 PM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
You can't project a 196:9 image on a 4:3 pull down screen without masking. The cloth idea you have is a mask and can be held in place with binder clips. A little more elegant solution may be found here: http://www.avsforum.com/t/1083120/40-diy-yardstick-frame-masking-system-for-pull-down-screens
ahajr143 is offline
post #6 of 7 Old 02-19-2013, 01:20 PM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
Sorry, it should be 16:9 (not 169:9)
ahajr143 is offline
post #7 of 7 Old 02-19-2013, 01:21 PM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
or 196:9
ahajr143 is offline
Reply DIY Screen Section
