Calculating Screen Size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-22-2013, 10:16 AM - Thread Starter
ghosthunter79's Avatar
I am mathematically challenged and need a little help. I am trying to build a 110" 16:9 screen. Simple enough....right? According to the calculator, the frame size should be 96" x 54". If I choose to put an inch or two black felt tape border around the screen, will that effect my measurements other than actual 110" screen size? Basically I want to use 8 foot boards and need exact measurements because I don’t have my projector to use to test it yet.... THANKS!
ghosthunter79 is offline
post #2 of 2 Old 02-22-2013, 01:15 PM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
If you use 8' lumber and build a 96"x54" frame your screen will be that size. If you use a 1" border your screen size will be 94"x52" or 107.4" diagonal screen. With a two inch border the screen will be 92x50" for a 104.7" diagonal screen.
ahajr143 is offline
Reply DIY Screen Section
