Replacing an 80 inch TV - rear projection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-27-2013, 01:33 PM - Thread Starter
raksun9's Avatar
Hello everyone,
I am trying to replace an 80 inch TV and would like to place a projector in its place. The depth of the cabinet is about 18 inches. I have never worked with rear projection projector.
Is this possible at all. Any help is appreciated.
raksun9 is offline
post #2 of 4 Old 03-01-2013, 03:07 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1777 Post(s)
Liked: 811
Yes...it can be done...but not too easily or very effectively cost-wise. I'd have to suggest investing in a dedicated Cradle designed to convert a PJ to RP use. Then using Light Silver Milliskin as the RP surface. http://spandexworld.com/c3/catalog/product/5954
There are several Short Throw and Extreme Short Throw PJs out now that feature 1080i Resolution and HDMI inputs. They are very Bright as well, so no worries as far as having a dim image, especially at 80".
But are you palling to retain 4x3 formatting?
MississippiMan is offline
post #3 of 4 Old 03-01-2013, 12:32 PM
starley's Avatar
I would recommend using a proper screen just for this purpose, I tried a number of different materials similar to the previous comment and they were horrible.
I ended up using an acrylic rear projection screen form ssidisplays, you can check it out and they could probably recommend the projector as well. here is the website http://www.ssidisplays.com
These screens are hard plastic and have incredible picture quality for rear projection, should be able to order it cut to fit and integrate it nicely?
Good luck,
starley is offline
post #4 of 4 Old 03-01-2013, 12:39 PM
LastButNotLeast's Avatar
Quoted: 1497 Post(s)
Liked: 1099
How about trying to get more milage out of the set you have?:
http://www.avsforum.com/t/695922/dont-dump-your-crt-rptv
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
Reply DIY Screen Section
