150" 16:9 Spandex Screen with Panasonic PT-8000 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Archaea
post #1 of 12 Old 03-26-2013, 08:07 AM - Thread Starter
jmatt's Avatar
I am setting up my home theater in my new home and am going to go with a spandex DIY screen. My room is 14 x 20, complete light control, no windows, dark paint with a Panasonic 8000. I have two questions around screen size. I want to do a huge 16:9 spandex screen that will be about 150" D (72" H by 130+" W). Does anyone have experience doing such a large spandex screen in 16:9 format? Most DIY's that I have found are with 2.35:1 ratio. Will the spandex stretch to fit 72" high? I am planning a white matte milliskin over silver milliskin for the screen with a masking system for movies. Also, any concerns of the Panasonic not handling the screen size in a cave like room?
Thanks for any help.
jmatt is offline
post #2 of 12 Old 03-26-2013, 01:28 PM
ahajr143's Avatar
Quoted: 48 Post(s)
Liked: 32
There shouldn't be a problem with doing a spandex screen that size, but if you do 150" diagonal you are going to be at nearly the maximum zoom of the lens in order to get a reasonably bright image with a 0.8 gain screen. This assumes you are going to mount the projector about 15' from the screen. If you mount it further back it alleviates the zoom issue some but at the expense of brightness. You can use the calculator at Projector Central and play around with changing the throw distance and screen size and see what works best for you.
ahajr143 is offline
post #3 of 12 Old 03-26-2013, 05:30 PM - Thread Starter
jmatt's Avatar
Thanks. I am still in the planning stages, about a month away from doing the finishing work. I ordered my spandex for the screen today as well as some led lights to see if I like a zero edge backlit spandex screen. Like the way it looks in the demo rooms, so i am anxious to see how it looks at home.
I want to maximize the screen in the space that I have. I'll post pictures as I go through the process.
jmatt is offline
post #4 of 12 Old 03-26-2013, 09:45 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1768 Post(s)
Liked: 806
I gotta clarify a few things.
First off, the amount of stretch available to the 80-20 Spandex is considerable, and easily enough to accommodate the 72"s required without it being overstretched. You would want to stretch it evenly though.
Secondly, you absolutely need to minimize your throw distance. For a 150" diagonal screen that is 1.0 gain, the minimum distance is 14' - 9" which grants you 18 foot lamberts. Move out 9" to 15' - 6" and you only drop to 16 fls....a good place to be for almost any normal content. But 3D? Better close off the room into total darkness 'cause your off-the-screen reflectivity will drop to 7-8 fls And all the above is based on a 1.0 gain surface. The Spandex combo will equate to being at most 0.85 gain.
Onward...
It's a cool idea in any design, Zero Edge-ing w/ Back lighting. But when using a porous material like Spandex...or really any perforated / Weave material, you have to be 100% assured you won't have rear light leakage,
You will need a totally "Light Blocking" material behind the Spandex. For the size screen you have, and the job that needs doing, you should acquire your "Black Out Cloth" here:
http://www.rosebrand.com/product34/Blackout-Lining-IFR.aspx?cid=174&idx=21&tid=1&info=Masking%2b%2526%2bBlackout
Use the Pull Down menus to select the 110" wide material. You will only need 3 yards if you settle on 72" x 128" (147") otherwise spend the $9.00 more and go out to 150" (74" x 131"} because the Spandex will take those 2 extra inches in stride.
I suspect you might want to build your Frame from selected 2x4. or in the least 1x4 Poplar rigidly braced.
But in all this lurks the inevitable question? Is Spandex the best choice here? Well chosen White Blackout cloth will perform as well as...even better than White Milliskin Spandex as far as Gain, and would only require "ONE" layer to do so. That same layer would have no potential of lighting up from the rear mounted LCD / LED Rope Lighting.
Nope...if your gonna back-light, and you gonna go big, I don't think a dual layer Spandex / BOC backing screen makes much sense.
Go with a good material of close to 1.0 gain to achieve the minimum results stated above. BOC comes close.....,
..................but you could take it much further, and do so much better if you painted onto the BOC surface. You do need the gain boost, and should it also come with improved Black levels......what's not to love at 150"? cool.gif
BOC + RS-MaxxMudd LL
................it's where 150" needs to be.
I see you already ordered your Spandex. I'll trade you some RS-MaxxMudd for it. Game? biggrin.gif
MississippiMan is offline
post #5 of 12 Old 03-27-2013, 05:52 PM - Thread Starter
jmatt's Avatar
Probably should have mentioned that I am going for AT screen so the speakers will be behind the screen. I think the BOC is not AT. For the backlighting I am going to add a ridge to the back frame to point the led lights 90 degrees from the frame, and with a black wall hopefully that will remove any bleed through. What is a good AT backing thought o reduce the chance of light washing out from the backside?
jmatt is offline
post #6 of 12 Old 03-28-2013, 06:18 AM
Liked: 806
You will have to "Seal" any edging...a "ridge ain't gonna suffice. You could use "Outside Corner Trim", or simply screw on 2" Lattice to the Frame and then Caulk the edge that toughes the Wall with a very Dark Gray Caulk.
But ve advised that there is no "AT material that will provide anything acceptably "AT" and that would still be thich and dense enough to mask out any appreciable light that finds it's way behind the screen and reflects off the wall. Painting the wall a very, very dark Gray would help...but keeping all light from behind the screen is the best solution.
post #7 of 12 Old 05-09-2013, 01:07 PM
craig5571's Avatar
Hi ,
i was just wondering if you got your screen built yet and how it turned out? i am in the planning phases of making a 150 inch diagonal 16x9 spandex milliskin screen , using an benq 1080p projector
thanks
craig5571 is offline
post #8 of 12 Old 05-13-2013, 07:11 PM - Thread Starter
jmatt's Avatar
Not quite there yet. Contractor is working a little slower than expected. Just had the drywall installed and am probably a month away from getting to start setting up my HT. can't wait to get started. The more time I have to read what others are doing the grander my plans.
jmatt is offline
post #9 of 12 Old 12-18-2014, 09:13 AM
sjeffers244's Avatar
Have you finished this project yet and if so what are your impressions of the final product? I am debating doing the same thing for an Epson 5030 in our space.
sjeffers244 is offline
post #10 of 12 Old 12-18-2014, 09:33 AM
Archaea's Avatar
Quoted: 2852 Post(s)
Liked: 2431
@MississippiMan ,
I wanted to mention something I've found value in behind an AT screen. Perhaps its something else you can add to your generous knowledgebase that you share with others.
Certainteed makes a theater black f ceiling tile that is 4'x2' x either 5/8" or 1". It has a light reflectivity rating of 3% and a NRC rating of .65 for the 5/8" and .90 for the 1".
It is like looking at a black hole, and is basically a piece of very light absorbant material adhered to a piece of OC703 if I had to guess.
It makes a very excellent home theater ceiling tile, and I've also discovered an excellent AT wall covering as well. It is thin, provides noise absorbtion, and excellent light absoption. It is lightweight and sticks on the wall easily with 3M Super 77, or Locktite adhesive spray. I painted my baffle wall behind my AT screen matte black to start with, but there was still too much light reflectivity. When I noticed how much less light the ceiling tiles reflected than the gridlines on my drop ceiling that I had painted the darkest black I could find in matte paint I realized I should try some of these ceiling tiles adhered to the wall. It worked like a champion. Pictures are in my signature. Perhaps just another tool in your belt.
http://www.certainteed.com/products/.../smooth/314184
It costs around $6-$8 per 4'x2' tile and you'd have to buy it from a local drywall type retail or distributer, but it works great and I'm really quite happy with it.
It also eliminates any squeaky drop ceiling issues from traditional tile -- which is a huge bonus for ceiling application. I used 9" pink fluffy above the tile to turn my whole ceiling into a bass trap.
dabsabre likes this.
Archaea is online now
post #11 of 12 Old 12-30-2014, 09:51 PM
Bigdaddyo811's Avatar
Did you ever post pictures of this build and how it worked out? I want to try something similar.
Bigdaddyo811 is offline
post #12 of 12 Old 12-31-2014, 10:18 AM
Liked: 806
Look to your Thread for a important response.
Reply DIY Screen Section
