Anybody use a colored Sintra screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-29-2013, 05:51 AM - Thread Starter
RSeiler308's Avatar
I've been using blackout cloth for my 110" screen. The picture is great, but the velcro I used to hold it to my aluminum frame isn't working. The corners keep coming off. So, I'm thinking of switching to a Sintra screen mounted to my existing aluminum frame. Wondering if anyone has tried a colored Sintra panel? If I could get a picture as good as my current one without painting, I'd be happy.
RSeiler308 is offline
post #2 of 4 Old 03-29-2013, 11:30 AM - Thread Starter
RSeiler308's Avatar
Thanks, yeah, that looks like Sintra white is pretty good as is. I thought perhaps a gray would be better, but those tests show otherwise.
post #3 of 4 Old 03-29-2013, 11:45 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1773 Post(s)
Liked: 808
Sintra has a slight Gloss, and it's not always distributed evely. To be safe you should thoroughly rub down the surface using a "dry" Magic Eraser to remove the sheen and reduce the surface to being a true "Flat" white.
MississippiMan is online now
post #4 of 4 Old 03-29-2013, 04:26 PM
Liked: 808
I have a 114" diagonal (56" x 100") Sintra Screen on Tap to spray soon, (late next week) down 'Nawlin's way der'bouts. It will be a Silver Fire v2.5 3.0hg (high gain) and the Sintra is in fact "Black".
I plan to cut the 5' x 10' Sintra down to 60" 104" and mask off 2" all around with Frog Tape. The "unpainted" Black border will be treated with a direct applique of Velvet if after the screen goes up it (...the raw black border...) doesn't look "gud enuf' "'
I've used Black before to help contrast performance, while using a very light, silvery gray top coat.
I will post a dedicated "Build Thread" as well, I just wanted to make the point that Sintra's real worth does not lie with being a "Hang-n-Shoot" option, but rather as being an excelent Substrate for almost any "Paint-able" application.
Reply DIY Screen Section
