epson 8530 screen help - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 04-29-2013, 08:37 AM - Thread Starter
bradtn's Avatar
Oh wow on my phone didn't see this post I will order these items sir
Sent from my Galaxy Note II
bradtn is offline
post #32 of 39 Old 04-29-2013, 08:41 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1816 Post(s)
Liked: 824
Originally Posted by bradtn View Post
http://m.homedepot.ca/Product/productdetails.aspx?ProductId=939822&lang=EN
I think im gonna go pick up this one will you give me your blessing ?
Nope. I have one myself, and it's designed for spraying thicker paints. It only works if you have an original Control Spray head with the smaller needle (...the Spray Heads are interchangeable...)
If your determined to get a corded Wagner, the first one you linked to would be a much better choice.
http://www.homedepot.com/p/Wagner-PaintREADY-HVLP-Sprayer-0529002/203474792#.UX6DZcrp9OY
http://www.homedepot.com/p/Wagner-PaintREADY-Stationary-HVLP-Sprayer-0529003/203474760#.UX6DYMrp9OY
Which Post? Which Gun?
I'm goin' crazy here!
MississippiMan is offline
post #33 of 39 Old 04-29-2013, 09:04 AM
pb_maxxx's Avatar
Quoted: 120 Post(s)
Liked: 56
oh no. do not get that one.
the head unit i clunky and poor designed. i've looked at that one thoroughly.
if you do... you'll need to get the "detailed" head attachment.
you are better off getting the new wagner "flexio" sprayers... which have a turbine engine.
pb_maxxx is offline
post #34 of 39 Old 04-29-2013, 10:10 AM - Thread Starter
bradtn's Avatar
I was confused as to cheap cost of this sprayer
Will this work
http://m.homedepot.com/p/Wagner-PaintREADY-HVLP-Sprayer-0529002/203474792/
That's a brand new model there....1st time I've seen one. It can work...but I'd rather see you use the Graco with a 1.5 mm needle kit.
Order this for 1/2 cost. http://www.gleempaint.com/noname.html
.....and this Needle: http://www.checkoutsupply.com/earlex-hvacv15-1-5mm-needle-brass-tip-hv3500/
You will still be $25.00 under the $99.00 cost of the Wagner. Less shipping.
That tip you posted will work with that sprayer right ?
bradtn is offline
post #35 of 39 Old 04-29-2013, 10:11 AM - Thread Starter
bradtn's Avatar
And by that sprayer I mean the gleempaint linked one
bradtn is offline
post #36 of 39 Old 04-29-2013, 10:17 AM
Liked: 824
Ok...I personally haven't ever seen or touched that newer unit. Nor the Flexio models.
Such is the case when you already have 2 Control Spray "separates", the Max and Plus, 2 Double Duty-s, two original Control Sprays, and a Graco / Wagner hybrid. (my favorite)
Yes.......and the 1.5 mm Needle Tip Assembly is the correct one.
post #37 of 39 Old 04-29-2013, 10:20 AM - Thread Starter
bradtn's Avatar
I wanna go with that one you posted from gleempainy paint and that tip but that tip says for hv3500? It'll still work with the gleempainy paint unit ?
bradtn is offline
post #38 of 39 Old 04-29-2013, 10:30 AM - Thread Starter
bradtn's Avatar
Thanks a ton both are ordered =D!!!
bradtn is offline
post #39 of 39 Old 04-29-2013, 10:42 AM
Liked: 824
Closure! At last !
I'm outta here for the afternoon. Available via PM if needed by anyone.
Reply DIY Screen Section
