My DIY Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-05-2013, 01:25 PM - Thread Starter
351carlo's Avatar
I put the big room thread in the rooms sections, but here I'll copy the relevant posts. Feel free to ask questions.
2013 has been a year of upgrading.
Old setup:
Projector: Sharp Notevision Projector (XR41X)
Screen: The wall - Recently a piece of matte white backdrop paper
So I had a "projector" room, but it was time to upgrade. I had the bug for a new projector for quite some time, and after selling one of my toys, I figured it'd be a reasonable trade.
I browsed the forums and web and found a great DIY tutorial. I copied their design and it worked out great.
1x3" Poplar for the frame:
Biscuit Time
IMG_20130330_154227_zpse6407360.jpg[/URL
Routing a channel in the back side allowed the use of aluminum spline channels used for window screen materials. Again I found this online and had to copy it. The channels were available at Home Depot and I used a hack saw to cut them to size. They allowed the screen to be tensioned with the ability to later easily remove it.
I don't have any pictures, but I chose to use a 3M Spray adhesive to cover the frame boards with the black velvet material. I used brackets in addition to the biscuits to hold the frame together, and would later use Hang Man brackets to mount it to the wall.
The material is a simple piece of blackout cloth.
Here's the first series of tensioning the screen:
Here it is up on the wall!
Ok so the video was up to par now.
Tony approved:
Thanks for reading and if you have questions let me know!
Check out my room build - DIY Subs, Speakers, Projection Screen
JVC RS46
Pioneer SC-65
SEOS Fusion 10 Pure LCR, Fusion 8 Surrounds
2x DIY 15" Ultimax in Sealed Enclosures powered by iNuke NU6000DSP Amp
351carlo is offline
post #2 of 4 Old 05-05-2013, 02:11 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2127 Post(s)
Liked: 961
Pretty nice project 351carlo
Glad to see you chose BOC and not some Mfg Screen cloth.
The Frame w/Biscuits and Splines is superb. And perhaps someday, a switch to a coated BOC application can be your next significant upgrade. With your build, it will be neither difficult or expensive.
Once again....a great job!
MississippiMan is online now
post #3 of 4 Old 05-05-2013, 02:17 PM - Thread Starter
351carlo's Avatar
Thanks MM. I am a student first and foremost, although out of school quite a few years. I read many of your posts in preparation, and do plan a more elaborate screen later utilizing a hard composite backer and painted surface. For this first application, I figured the basic screen would allow me to switch out and test things easily. If I want to make a Sintra backing, I need only mount it to the frame. If I choose an A/T material, I can swap it out as well.
If I switch rooms, I will consider a 2.35 ratio screen with some sort of motorized black out side curtains.
Ah the project will indeed be never ending!
JVC RS46
Pioneer SC-65
351carlo is offline
post #4 of 4 Old 05-11-2013, 07:18 PM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
Great job. I like the spline. Next screen I do will have it included. Like you say, it just keeps on going. We always have a new screen to make. Such fun.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
Reply DIY Screen Section
