DIY screen for Ben Q 1250 suggestions please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-20-2013, 11:52 AM - Thread Starter
Bavaria's Avatar
Hi
I'm looking for advice on the best DIY screen option for this projector.
The room is 9ft by 16 ft, very dark walls and ceiling, seating distance will be approx 14ft, screen size 106" diag. 16:9, totally light controlled.
I'm open to any option, I have looked through a lot of the threads but to be truthful my head is spinning from all the info and could use something related to this projector.
I did try it out on the white primed walls when I first got it and was quite impressed so I'm looking forward to seeing it on a better screen surface.
We live in the Niagara Falls region so we are close to Buffalo and Niagara Falls area for supplies that may be required.
Thanks in advance to your responses.
Cheers
Stuart
Cheers
Stuart
Bavaria is offline
post #2 of 8 Old 07-20-2013, 02:01 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2053 Post(s)
Liked: 909
Bavaria
Stewart,...... .
If you mean the "W1200"...here are my comments and suggestions.
  • The PJ, if ceiling mounted, needs to be at a very low profile, ie: close to the ceiling...especially if the ceiling is 8'. If 9' you have about 10" leeway. The W1200 has a whopping 18" Image Offset.
  • Throw distance should be minimized....set to 11' - 3"
  • Screen Material should be 5' x 10' x 6mm Sintra. ( 92" x 52" viewing area...cut dimensions: 96" x 56" ) Screwed directly to wall.
  • Sintra /Comatex / Source: Call Local Sign making Concerns or Wholesale Plastic Sheeting supplies.
  • Spray RS-MaxxMudd "LL"
  • Trim Screen with 3.25" Velvet wrapped MDF Base, overlaying the 2" excess where the screws attach the screen to the wall.
MississippiMan is online now
post #3 of 8 Old 07-21-2013, 07:06 AM - Thread Starter
Bavaria's Avatar
Hi Thanks for the reply.
No the projector is a BenQ W1250, I ordered it through the Canadian Costco up here. Some where I seem to remember reading it was tagged exclusively for Costco based on another model from BenQ
Apart from the throw distances can I still use the same materials and paint per your recommendation?
Cheers
Stuart
Cheers
Stuart
Bavaria is offline
post #4 of 8 Old 07-21-2013, 10:46 AM
Liked: 909
Hmmmm...., I did some checking and could find no re-badged BenQ's offered by Costco s in Ontario.
Yes, the suggestions provided should still be valid, but how's about you provide the skinny as to the PJ's actual specifications. That way, my "Yes" can make me feel more assured of it's validity.
post #5 of 8 Old 07-21-2013, 12:37 PM - Thread Starter
Bavaria's Avatar
Hi MississippiMan here is the specs on the projector and yes Canada is a strange place we like it that way:)
Enjoy 1080p Full-HD image projection up to 200” in the comfort of your living room with the W1250 Home Entertainment Projector. You’ll be captivated by brilliant image performance featuring the native 1080p DarkChip3 DLP Technology by Texas Instrument, 10,000:1 contrast ratio and a 2000 lumen brightness. Built-in speakers and easy set-up seal the deal on this user-friendly experience.
Projection System 1080p DarkChip3 DLP Technology by Texas Instruments
Native Resolution 1080p (1920 x 1080)
Brightness* 2000 ANSI Lumen
Contrast Ratio 10000:1
Display Color 1.07 Billion Colors
Lens F=2.59-2.87, f=16.88-21.88mm
Aspect Ratio Native 16:9 (5 aspect ratio selectable)
Throw Ratio 1.15-1.5 (79"@2M)
Image Size (Diagonal) 40"-235"
Zoom Ratio 1.3:1
Lamp Type 240W
Lamp (Normal/Economic Mode)* 3500/5000/6000 hours
Keystone Adjustment 1D, Vertical ± 40 degrees
Projection Offset Vertical 110%-130%±5%
Resolution Support up to WUXGA
Horizontal Frequency 15K-102KHz
Vertical Scan Rate 23-120Hz
Dimensions(W x H x D) 312 x 109 x 244 mm
HDTV Compatibility 480i, 480p, 576i, 567p, 720p, 1080i, 1080p
Video Compatibility NTSC, PAL, SECAM
Weight 2.65KG
Audible Noise 33/30 dBA (Normal/Economic mode)
Power Supply AC 100 to 240 V, 50 to 60 Hz
Power Consumption 353W/110V (typical), Standby < 0.5W
On-Screen Display Languages Arabic/Bulgarian/ Croatian/ Czech/ Danish/ Dutch/ English/ Finnish/ French/ German/ Greek/ Hindi/ Hungarian/ Italian/ Indonesian/ Japanese/ Korean/ Norwegian/ Polish/ Portuguese/ Romanian/ Russian/ Simplified Chinese/Spanish/ Swedish/ Turkish/ Thai/ Traditional Chinese (28 Languages)
Picture Modes Dynamic / Standard / Cinema / 3D / User 1 / User 2 / User 3
Accessories (Standard) Remote Control w/ Battery
Power Cord (by region)
User Manual CD
Quick Start Guide
Warranty Card (by region)
VGA (D-sub 15pin) Cable
Accessories (Optional) Spare Lamp Kit- P/N: 5J.J7L05.001
Ceilling Mount- P/N: 5J.J4N10.001
3D Glasses- P/N: 5J.J7K25.001
Carry Bag- P/N: 5J.J3T09.001
Interface Computer in (D-sub 15pin) x 1
HDMI x 2
Composite Video in (RCA) x 1
S-Video in (Mini DIN 4pin) x 1
Component Video in x 1
Audio in (Mini Jack) x 1
Audio L/R in (RCA) x 1
Audio out (Mini Jack) x 1
Speaker 10W x 1
USB (Type Mini B) x1 (for service)
RS232 (DB-9pin) x 1
DC 12V Trigger x 1
*Lamp life results will vary depending on environmental conditions and usage. Actual product's features and specifications are subject to change without notice.
Cheers
Stuart
Bavaria is offline
post #6 of 8 Old 07-22-2013, 10:24 AM
Liked: 909
Well that checks out to be a clone of the w1070, being 1080p and all.
Everything else I suggested above remains completely valid.
post #7 of 8 Old 07-22-2013, 01:28 PM - Thread Starter
Bavaria's Avatar
Hi Mississippi Man
Thank you so much for your help on this. I will post some pics and impressions of the results when I start the screen.
Cheers
Stuart
Bavaria is offline
post #8 of 8 Old 07-22-2013, 03:45 PM
Liked: 909
Originally Posted by Bavaria View Post
Hi Mississippi Man
We / I will be anxiously awaiting those posts!
Get'ter dun!
Reply DIY Screen Section
