Screen ratio is 1/4" to long - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-28-2013, 02:33 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I built a DIY frame and I just stapled the screen on last night. I got it back up into place and noticed that the length is off, too long, by 1/4 of an inch.
The vertical measurement it spot on, 54".
Am I going to have a problem here?
I can only guess what happened is when measured up against a white back ground the 1/4" was more noticeable vs. measuring into the carpet or whatever was behind the open space. Feel kind of embarrassed as I could have sworn it was perfect.
pdxrealtor is offline
post #2 of 3 Old 07-28-2013, 04:54 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
PDX,
What with your being just 1/4" off (1/8" x 2) and your effective use of Black Cloth surround, your going to be fine.
Remember this as well, 16:9 formatting as broadcast or viewed from DVD can easily vary as much as 1.5" on the width (3/4 x 2) so your well within tolerance and actually better than many Screen Mfgs manage.
MississippiMan is offline
post #3 of 3 Old 07-28-2013, 05:10 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Thanks for your reply. Feeling much better now.
Reply DIY Screen Section
