DIY black screen tests - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 304Likes
post #541 of 1387 Old 11-23-2014, 06:27 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Here is a picture of the material In better light. The marks on it are from peeled off diffuser residue from previous experiments.
ID:	381938   Click image for larger version
ID:	381946   Click image for larger version
Lorddeff07 and imbloodyskint like this.
stephen77 is offline
post #542 of 1387 Old 11-25-2014, 03:13 PM
helderlima's Avatar
Quoted: 13 Post(s)
Stephen,
Do you sell or is thinking about selling this screen in full size?
I would buy it, but I need at least 98 inches (diagonal).
helderlima is offline
post #543 of 1387 Old 11-25-2014, 05:20 PM
Lorddeff07's Avatar
Quoted: 54 Post(s)
Originally Posted by helderlima View Post
Stephen,
Its not that complicated. Just look up High gloss black vinyl online and buy a can of window frost spray paint. Then of course use a backing substrate of your choice to apply the film onto. everything should cost under $200 or so depending on what you use for the backing board.
Or you can just buy a black high gloss acrylic sheet, though your screen size will probably be limited to 88"-98" or so and then get your window frost spray.
Lorddeff07 is offline
post #544 of 1387 Old 11-25-2014, 06:13 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Has anyone else made a test sample & had good results? If so please post. Im waiting on a charcoal & a black chrome sample to get here for further testing.
post #545 of 1387 Old 11-27-2014, 09:19 AM
Dave in Green's Avatar
Quoted: 1283 Post(s)
Liked: 850
It's always exciting to see progress being made on this project. There are two issues that come to mind about adding spray paint to this process:
One, it's not like the typical painted screen where you can cover up a mistake by adding another layer of paint. It sounds as if this process requires a precise amount of spray -- not too little and not too much. Using trial and error to calculate the exact amount is one thing, but consistently replicating the process would be a real challenge in the home DIY environment. In a commercial application a spray coating like this would likely be applied by robotic paint sprayers programmed to apply the exact amount each time.
Two, how durable is a light coat of window frost spray on high gloss vinyl or acrylic? I've seen sprayed window frost easily scratched when used on windows, and I'd think any kind of scratch or mar would be difficult to repair given that the window frost layer needs to be precise and even to produce a consistent image across the screen. This could especially be a problem if the screen were to be frequently rolled up and unrolled.
Dave in Green is offline
post #546 of 1387 Old 11-27-2014, 12:34 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
At first I had the same thoughts as you did about spray pait as an option. I assumed it would spray inconsistently with blotches in areas & running because thats usually what spray paint does but the frost didn't do any of these things. I made numerous samples & there was no problem duplicating good consisten results. The only time it was off is when I just sprayed way more than needed & in that case it smothered the reflective layer resulting in to dim of a picture. If you just hold the can about a foot from the surface & make one pass over it you will get the results you are looking for. The frost lays surprisingly well with no signs of blotching & running as long as you dont over spray it. On a larger surface I cant say for sure how well it will do but on comparison to the smaller samples I have made I dont forsee it being a problem. As far as rolling it up & down you may be right on the fact that it may not hold up to well but that was just a possibility I was throwing out there. We wont no until we put it through its paces but if we have to stick to a fixed screen then thats fine with me as long as we can just get this to work.
post #547 of 1387 Old 11-27-2014, 08:50 PM
Liked: 850
Thanks for the more detailed explanation. It does sound promising if the window frost spraying process is flexible enough to allow for the kind of human variations you'd expect, such as the exact distance of the sprayer from the screen, the optimum speed to move the sprayer across the screen while spraying, etc. With a little practice on small samples it sounds as if it's not too difficult to get the feel of how much spray you need to apply to the larger screen.
post #548 of 1387 Old 11-28-2014, 12:46 PM
imbloodyskint's Avatar
Quick look on UK ebay and can not find any material that will allow any bigger then a 80" 16:9 screen
Found this stuff, but would still be limited to a 100" 16:9 screen.
http://www.metrorestyling.com/ORACAL...emblk970ra.htm
imbloodyskint is offline
post #549 of 1387 Old 12-02-2014, 06:56 AM
Fairly New
Greetings, relatively new to the forum but spent hours( truly DAYS) filtering through all the well detailed and diverse information to produce an extraordinary screen at a low cost and simple application process.
Here is where I became stagnant!
Im having difficulty with deciding from an spandex screen or the vinyl screen.
My expectations (very little) are to have a screen similar to the Black Diamond screen but doesn't need to be black. It can be grey or white if I am able to get the same contrast and have close to true darkness instead of the washout darkness coming from my screen if this make since. I want something that still has decent picture quality in any environment. I don't truly understand all the science and mechanics behind light wavelengths and how it travels. Thats why I came to the expert or those better then me in this field. I recently stripped the layers off an lcd screen. There was a reflective material and an material that was transparent but also clouded. Put them together and put it next to my screen. Let me tell you, I thought I discovered the best thing ever since grilled cheese. Until I came here and seen y'all were light years ahead of me.
I like the idea of having a black screen that compliments contrast to give it the wow factor.So for starters I went to my shop and got a Glossy black vinyl and put that clouded transparent screen in front of it and the image was amazing.The issue I faced is when I look at the screen away from center focus. The image appears distorted or faded away. Is there anyway to make this better and still look good from roughly all angles. Im not picky about having the screen show in a 180 view but just enough to see the image clearly from every angle of the couch. Im starting to read more about the spandex but looking for all options from a beginners point of view with a budget of $600 living overseas.
My current set up:
Have a 150 inch screen from carls purchased from amazon.( typical front view projector screen)
Epson Home Cinema 8350
specs are 2000 lumens and a 50,000:1 contrast ratio
All suggestions are strongly encouraged.
HumbleHub is offline
post #550 of 1387 Old 12-02-2014, 07:35 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1762 Post(s)
Liked: 806
You should look into Threads that feature Painted surfaces, or hybrids of both paint & material overlay.
With all the alternatives available, not sure how you fetched up here where size is a limitation (currently)
Recently a Member posted about applying a solid Silver Metallic coating and overlaying White Spandex, which is a variation of, but very much akin to Diffusion based layering.
Considering the size of your present screen (150") I will state that you will not achieve gain, a wide viewing cone, and contrast enhancement from either of the aforementioned applications. And to acquire a truly watchable viewing cone of say....120 degrees minimum (60 degrees off center) you will need to consider a multi-paint "sprayed on" application. (...of which your current screen could serve as a substrate...)
I won't wax redundant about such alternatives on this thread (...as some do too freely in reverse on others....) so just take another "Day" and review some other Threads that have applications based on achieving the goals you desire.
MississippiMan is offline
post #551 of 1387 Old 12-02-2014, 08:25 AM
Im actually looking to downsize to a 48x86 or so screen. Could the theory be a lot easier with this size?
post #552 of 1387 Old 12-02-2014, 11:37 AM
Liked: 806
Well yes....that smaller size make the applications described wi8thin this Thread very attainable.
post #553 of 1387 Old 12-02-2014, 01:47 PM
Ftoast's Avatar
Quoted: 1915 Post(s)
Liked: 624
That 48" height will make finding options MUCH easier because it is such a common material width.
That smaller screen-size will also allow your projected image to be much brighter than before which will both help in widening your options to allow for things like darker top-layers or wider viewing-cones at a given surface darkness AND it'll allow your projector to fight more light with simple brute strength of brightness..always a good thing to have for projecting in a lit room.
For the most effective screen, people will be better able to help if you can try to nail down a couple more numbers. Besides screen-size (which you've mentioned), do you have a rough idea how far you'll probably be sitting from a screen that size and about how wide the seating arrangement will be?
Knowing that can allow suggestions that'll give you juuuust the right size of viewing-cone which means you'll have less need to make sacrifices in areas like surface-darkness and peak-gain.
-The narrower you can allow the viewing-cone to be, the less your screen will be affected by ambient light. This will determine how thick/thin your diffusion will need to be.
-At 48"x86" with the 8350, any gain from 0.6 and upward should provide over 16ftL..with a 1.0gain giving above 25ftL. Going much higher might get a little bright for nighttime use, but you're unlikely to find anything bright enough to actually cause problems.
-The screen's dark surface works with the boosted peak-gain to give you back a good chunk of the contrast you'll lose in a room that's too bright.
Still, any light hitting the screen from farther back (particularly from behind your seats) will washout any screen..even the darkest or most special. You should still try to control the room lights and sunlight to whatever extent you are able. Light coming from nearer the screen's wall and lights pointing away from the screen are the easiest to use without ruining your image.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
post #554 of 1387 Old 12-02-2014, 11:21 PM
My screen is 2 feet away from my couch to the right and 12 feet away from the center couch. My PJ is 12.i feet away from the screen and 5.5 feet above the ground to make it as parallel with the screen.
I really want to try 48x86 or 48x96.
So which types of materials should I use and how to configure the layers.
post #555 of 1387 Old 12-02-2014, 11:23 PM
the PJ is 12.5 feet away from the screen. Sorry
post #556 of 1387 Old 12-03-2014, 12:10 AM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
What do u all think about these results? The first picture is with the flash on. It completely washes out my comparison gray screen but doesn't touch my newest black screen sample. The rest of the pictures are without the flash. Couldnt be more excited. Im really starting to get the results I have been looking for since I first started this project. Luckily the best results are actually the cheapest & easiest to make. Im not going to go on about how this is the holly grail of dark screens im just going to let the pictures do the talking but they really dont do it justice. The last 2 are before & after.
ID:	399090   Click image for larger version
ID:	399098   Click image for larger version
ID:	399106   Click image for larger version
ID:	399114   Click image for larger version
ID:	399130   Click image for larger version
ID:	399146   Click image for larger version
post #557 of 1387 Old 12-03-2014, 12:14 AM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Meant to add these on the last post so you would know what the material looked like. First is with flash & second one is without.
ID:	399202   Click image for larger version
post #558 of 1387 Old 12-03-2014, 03:40 AM
Whats the material, and how does it look from the side view a couple feet away?
post #559 of 1387 Old 12-03-2014, 03:51 AM
Don't laugh but my daughters love the movie Frozen so that's what I'm using as an example. Here you can see my issue. Looks great from center view but not quite at different angles.
I'm using glossy black vinyl with a clear acrylic that I sprayed with frost spray.
ID:	399266   Click image for larger version
ID:	399274   Click image for larger version
post #560 of 1387 Old 12-03-2014, 08:28 AM
Liked: 850
What do u all think about these results? The first picture is with the flash on. It completely washes out my comparison gray screen but doesn't touch my newest black screen sample. ...
That flash comparison photo is one of the most impressive I've seen of any type of screen. Your latest experimental screen holds an amazing amount of contrast in the high ambient light of a camera flash that totally washes out a standard gray screen.
post #561 of 1387 Old 12-03-2014, 10:25 AM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Will take more pictures from the side tonight. Unfortunately this type of screen is going to have a smaller viewing cone & if you want to increase it will have to be to the sacrifice of other qualities of the material. To widen the cone you would have to add more diffusion which in turn would dilute the black & the reflectivity of the material. This would result in a light colored material with a dimmer picture. If the viewing angle is more of a necessity then those other factors then simply add more diffusion.
post #562 of 1387 Old 12-03-2014, 06:47 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Here are a few pictures from the side & the last 2 are with the flash on.
ID:	400322   Click image for larger version
ID:	400330   Click image for larger version
ID:	400338   Click image for larger version
post #563 of 1387 Old 12-03-2014, 08:29 PM
Ftoast's Avatar
Liked: 624
It looks like the viewing-cone is narrow enough to avoid even a pretty straight-on camera flash while wide enough to stay decently bright for a couch+1 viewing arrangement. That's a powerful combination!
If a larger screen shows some uniformity trouble, a very slight curve can fix that.
If this is still that glass-frost spray over gloss-black material/vinyl, has anyone tried a large enough piece to comment if it's still easy to spray the frost over a large area without too much trouble with overlapping or missing?
post #564 of 1387 Old 12-04-2014, 08:12 PM
kopmjj's Avatar
Quoted: 136 Post(s)
Liked: 24
hi nice result there since your post i have boght a sample of high gloss vinyl sheet 3mm and clear frosted arcylic sheet 3mm and combined them and comapred to my black widow screen i get better black infact the best ive seen, but the picture is slightly darker than my grey screen. is there would there be a better way to make it brighter?
im in the process of trying every type of screen so i can choose the best one for me.
i already tried black wido ultra, in the process of trying silverfire and also this.
i tried using vinyl wrap but im useless at sticking it on. and the frosted spray i bought didnt work as good as these ones...
http://www.trentplastics.co.uk/2012/...-/prod_88.html
http://www.trentplastics.co.uk/2012/.../prod_523.html
these are the samples i used and blacks were great but picture a little dark, also i didnt test the viewing cone yet but will do tomorrow and find out.
i have the samples so i can show you comparisons from my BWU screen tomorrow. but i just have a feeling this aint going to work out.
kopmjj is offline
post #565 of 1387 Old 12-06-2014, 07:44 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
I may use this material for my final screen & call it good. If u want an easy, cheap, & very effective dark screen material then I would highly suggest u all get a sample of this to see what im talking about. It is actually brighter then the current dark screen pictures I have posted & it doesnt require any diffusion or anything. All you have to do is stick this material to a surface & your done. I really believe it out performs my current dark screen material by just a smidge. The viewing angle is noticeably better because the brightness doesnt fall off once you get further off center. The one draw back some of you may have a problem with is it is a little lighter then the black material but not by much. It is called gun powder so it is a really dark gray but in comparison to the black screen which is once diffused takes on a dark gray tone as well. What I think is the best feature of this material is the fact that it doesnt need anything out of the box like a diffuser. You just adhere to a screen surface & your done. The second picture is a shot with the flash on. The top right corner is my previous black screen & the gun powder is the one in front of the Avengers at the bottom. I didnt do anything to it, just stuck it on there & took the pic.
ID:	406178   Click image for larger version
post #566 of 1387 Old 12-06-2014, 07:54 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
This is the screenshot from the ebay store for the material information.
post #567 of 1387 Old 12-06-2014, 09:21 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Since the screenshot wont work here is a 6$ sample u can get of the gun powder vinyl to test from ebay.http://m.ebay.com/itm/251396040990?txnId=1559057988015
post #568 of 1387 Old 12-06-2014, 09:30 PM
Liked: 850
This would be amazing if a single layer of vinyl car wrap can make a quality dark screen. Finding a single layer of any readily available material that works well is the holy grail of DIY dark screen. I guess it's fair to call this a dark screen as it's not pure black. But putting a frosted layer over a black material ends up turning it from black to dark gray, anyway. Looking forward to learning more details about this. I found a little more about this specific wrap at this link and this link.
post #569 of 1387 Old 12-06-2014, 09:49 PM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Its also 60 inches wide so it will almost produce 120 inch 16:9 screen. I Also believe this material could be applied to a roll down screen & could easily withstand the abuse the rolling would put on it. The fact that it is a car vinyl tells you that its made to be durable so I dont think a rolling screen system would be a problem at all. Since there is no diffuser of any sorts you wont have to worry about anything peeling or flaking off either. The material is pretty thin so I dont believe there would be any creasing or bubbling either. Only test will tell but I think it would perform well.
post #570 of 1387 Old 12-07-2014, 01:05 AM
stephen77's Avatar
Quoted: 114 Post(s)
Liked: 82
Here is a good light exposure picture between the gun powder & the original black screen. While I like the idea of the gun powder vinyl because its plug & play it doesn't hold up as well as the original black screen to light. Even though its not as good under ambient conditions it is still a very good alternative. The fact is that you pay 87$ for a 5ft×8ft piece of vinyl that can adhere to a screen material that most projector enthusiasts already have & you have a dark screen that rivals the best on the market. ..trust me this is still a very good option. The gun powder is on the left & the black is on the right as both of them are being demonstrated on the Avengers. The next picture is a comparison between a gray screen & the gun powder. The third pic is the gun powder covering the Avengers. The last picture is of both materials. The black is on the left & the gun powder is on the right. You can notice a few imperfections on the black from where the frost was sprayed on but you wont have to worry about any of that with the gun powder.
ID:	406482   Click image for larger version
ID:	406490   Click image for larger version
ID:	406498   Click image for larger version
HCORE likes this.
Reply DIY Screen Section
