New Install Paint Suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 09-19-2013, 12:15 PM - Thread Starter
DMVGamer's Avatar
This is my first attempt at something like this, I've been doing some reading and researching but want to confirm what I'm thinking before I dive into it. First some details:
Projector:
Vivitek D950HD
3200 Lumens
approx 15' throw distance
Screen size 120" 16:9 ratio
Environment:
Basement, controlled lighting
Two walkout doors that can be blacked out
Drywall with White paint throughout, recessed lighting
Projector Ceiling Mounted
I want have a paint that I can roll onto the wall with 1/4" nap roller and I think that the Glidden Diamond 450, Titanium White or the RS-MaxxMudd LL is what I should be going with but want to confirm. I'm still a bit new at this, so I figured I would post he before getting started, Also is there anything else I need to consider before really getting into this? Thanks
DMVGamer is offline
post #2 of 50 Old 09-19-2013, 07:49 PM
Jeff Stapley's Avatar
I have a similar setup and I love the Max Contrast Screen Goo
Jeff Stapley is offline
post #3 of 50 Old 09-19-2013, 11:45 PM
Kirnak's Avatar
Projector:
Vivitek D950HD
3200 Lumens
Environment:
I'm a big fan of the Diamond 450, but white is not the way for you to go. Way too bright for your screen size & PJ, and your room is not dark enough for a white screen. (White walls...) You could get it tinted to "Veil" a nice neutral gray, that would be at least as good as the Goo, probably much better and certainly cheaper. With your PJ you might even consider going with a much darker gray. The PJ you have isn't a home theater PJ, it's more of a presentation PJ. 35 db is quite loud and the contrast is pretty low. You'll need all the help you can get with a dark gray to get a decent picture out of it. Goo just won't cut it. Also, consider building a "Hush Box" to tame the sound level.
Kirnak is offline
post #4 of 50 Old 09-20-2013, 03:31 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 2165 Post(s)
Liked: 981
He can easily tame that beast, and also maintain better whites and improve Contrast by using a ND-Filter and a moderately Gray mix. Going dark Gray for the benefits offered by a Flat Gray alone is simply robbing Brightness and Whiteness to achieve blacker blacks. The only real choice to avoid all that is as to if he wants the color / contrast advantages that a reflective mix offers.
Silver Fire allows for a far darker "Silver Gray" surface without undue loss of gain...and with the PJ in question...as with other similar units, I use a SF v2.5 5.0 mix
But Kirnak is as right as he can be. A 120"er hit with 3200 lumen needs to have the light attenuated....but it needs to be done as it exits the PJ....not squashed out of existence by attenuation on the screen surface.
Last year at this time I highlighted a SF v2.5 4.0[/B application sprayed onto a 106" Tab Tensioned screen. The PJ used was a Viewsonic PJD 6683ws w/3000 lumens
DMVGamer, overview the results (...and ignore the few rants...) and you'll see that the combination you have can...and will work if you use the right "DIY" paint.
http://www.avsforum.com/t/1432177/painting-onto-a-106-tab-tensioned-screen-with-silver-fire-v2-5-4-0
MississippiMan is online now
post #5 of 50 Old 09-20-2013, 03:53 AM - Thread Starter
DMVGamer's Avatar
can you send me more info on the ND filter needed, also can I roll SF v 2.5? thanks for all the info from everyone.
DMVGamer is offline
post #6 of 50 Old 09-20-2013, 09:42 AM
Liked: 981
I'll find a "Set" for you asap....but................
http://www.adorama.com/TF77DNDK.html?gclid=COfS7vKx2rkCFQJqMgodUgMAmw
The ND linked above is a 3 Filter Set (...for the price of one from most Vendors...w/free shipping as well...) so you can do some preferential testing.
But you should use a metric measurement ruler to check the mm width of your PJ's lens before you order anything. The one listed above is 77mm
Here is a larger Filter:
http://www.ebay.com/itm/Tiffen-82mm-Digital-HT-Neutral-Density-ND-0-6-ND4-Filter-Authorized-Dealer-/380613821880?
It is only a 0.6 value, but my guess is that will be sufficient for your needs.
Lastly, there are "Infinitely Variable ND Filters....and although they cost a bit more, they provide "Dial In" performance, so there is no "That's too little....Oh Crap....that's too much" kind of occurrences.
http://www.filmtools.com/tiffen-variable-nd-77mm-filter.html?gclid=CJaxxqy02rkCFexDMgodD10AbQ
Spraying is a snap really...and very inexpensive with the following Gun / Needle Combo.
http://www.gleempaint.com/noname.html
http://www.amazon.com/gp/product/B004BG6DIM/ref=ox_sc_sfl_title_8?ie=UTF8&psc=1&smid=A2NWLOWWF5G7JX
post #7 of 50 Old 09-20-2013, 02:39 PM - Thread Starter
DMVGamer's Avatar
Thanks, didn't realize they were the same ones i use for photography, i'll see if any of the ones i have fit. I'll google some spray tutorials but I had never tried it before and wasn't going to make the investment, but that is reasonable enough. Thanks again!
DMVGamer is offline
post #8 of 50 Old 09-21-2013, 05:34 PM - Thread Starter
DMVGamer's Avatar
MM, does the entire 100mL of water go into the colorant mix? I saw it said for cleaning utensils and was a bit confused. Thanks
DMVGamer is offline
post #9 of 50 Old 09-21-2013, 09:24 PM
Liked: 981
Yes. It is used incrementally to clean the utensils, but obviously the material cleaned (along with the water) needs to be included in the mix.
Confused? Don't feel bad....that particular aspect is among the most questioned.
post #10 of 50 Old 09-23-2013, 06:35 PM - Thread Starter
DMVGamer's Avatar
In reading through the thread you referenced my hopes are high for this build. Got all the paint today just waiting for spray gun to come in, any last minute tips for spraying? Also I noticed you using the darbee processor, would that be of any benefit with the projector I have?
DMVGamer is offline
post #11 of 50 Old 09-23-2013, 08:41 PM
Liked: 981
It would be very difficult if not impossible to find a PJ the Darbee could not "help". Used correctly...it's that good. cool.gif
As for "tips"....
  • Make sure the Mix is right...and do not start spraying until your sure. Also be certain you have the right viscosity (...lack thereof actually...) Viscosity measured via flow-thru rate when straining is best to ascertain that.
  • Practice on a smooth, clean surface. A primed & sanded sheet of Drywall is a very inexpensive way to do that...and well worth it considering the substrate you eventually are going to be spraying onto.
  • Spray multiple very light, fast coats from 14" away, with 70% overlap. Let each coat dry (30 minutes minimum) and use a CLEAN Fan set to medium and placed at 8' in front of the screen to hasten / assure drying.
  • Look at how I secured the screen, and masked it off. You should try your best to stabilize the screen so it does not wobble with the gun's applied air pressure. Really, that's not a huge concern, but best allowed for anyway.
  • Use "Frog Tape" along the screen's border with the Black surround. When removing it, be "very" gentle, and pull the tape off "away" from the painted screen area.
  • Expect to apply at least 7 to 8 Duster coats...the very last one being at about 1 second per foot slower than the 3' per second speed used on all subsequent coats.
post #12 of 50 Old 09-24-2013, 03:55 AM - Thread Starter
DMVGamer's Avatar
Again thanks for the info, are there any videos displaying the recommended viscosity of the final product? Just curious. I'll let you know how the process goes.
DMVGamer is offline
post #13 of 50 Old 09-24-2013, 04:01 AM - Thread Starter
DMVGamer's Avatar
I'm applying to a clean painted wall, there shouldn't have to be any other prep to that should it?
DMVGamer is offline
post #14 of 50 Old 09-24-2013, 07:10 AM
Liked: 981
Sorry...I thought by referencing the thread you did you were planning to spray onto a Retractable Screen. redface.gif
If the wall is white....and very smooth...yeah...little prep is needed. But if not, white is pretty much essential as a background for the SF family of paints so as to optimize performance by avoiding attenuation due to absorption.
If you tape off a border area about 2" larger on all sides than your selected screen size, you can spray apply 3 quick coats of a White Primer, sand lightly, and get going from there.
PS...just about every "Screen Build" thread i have posted has Videos of both straining and Spraying. Go here for a complete list of Threads and review.
http://www.avsforum.com/newsearch/?advanced=1&sort=lastupdate&order=descending&type=35&createdbyuserid[]=50111
post #15 of 50 Old 09-24-2013, 08:46 AM - Thread Starter
DMVGamer's Avatar
Thanks, yeah wall it white and smooth, so I should be in good shape. Thanks.
DMVGamer is offline
post #16 of 50 Old 09-24-2013, 09:05 AM - Thread Starter
DMVGamer's Avatar
Will probably give it a few coats of primer and sanding all the same though.
DMVGamer is offline
post #17 of 50 Old 09-24-2013, 09:33 AM
Liked: 981
Let the last coat of Primer get absolutely dry before sanding. Sand using light, broad sweeping strokes. Your wanting to "smooth"...not "remove".
Myself, I'd apply 3 coats, sand.... 1 more coat, then one last sanding for a ultra smooth surface.
post #18 of 50 Old 09-24-2013, 12:46 PM - Thread Starter
DMVGamer's Avatar
How many coats of SF do you apply with 1.5mm needle on drywall?
DMVGamer is offline
post #19 of 50 Old 09-24-2013, 12:53 PM - Thread Starter
DMVGamer's Avatar
Based on this review the lumens are lower than advertised, do you still recommend the same SF mix?
http://projectors.reviewed.com/content/vivitek-d950hd-video-projector-review/blacks-and-whites
DMVGamer is offline
post #20 of 50 Old 09-24-2013, 07:01 PM - Thread Starter
DMVGamer's Avatar
After reading some of your other threads, I think i want to skim mud it first then i'll prime, does that seem reasonable. Thanks for answering my barrage of questions.
DMVGamer is offline
post #21 of 50 Old 09-24-2013, 09:21 PM
Liked: 981
A very light skim and sand assures that any hard to see pits and cracks get filled. If you skim and then scrape firmly keeping the Blade at a slight angle, anyplace that needed 'filling" suddenly pops right out.
In truth it's better to go to that trouble early on, than to prime...hide those blemishes from being seen easily, and then have them suddenly appear after a first or second coat of contrast enhancing paint.
post #22 of 50 Old 09-26-2013, 08:54 AM - Thread Starter
DMVGamer's Avatar
DMVGamer is offline
post #23 of 50 Old 09-26-2013, 04:47 PM
Liked: 981
Yay......you go Guy.
Me...I'm takin' a night off.......my 5th Grandchild is knocking at his mother's door, and is expected to make his first appearance before Morning.
I'm due into Denver next Thursday to see him.....gonna be great!
Post Note 4 hours later:
He's amongst us!
8 lb -21.5" Redhead
post #24 of 50 Old 09-27-2013, 11:05 AM
rengep's Avatar
rengep is offline
post #25 of 50 Old 09-28-2013, 08:39 AM
Liked: 981
Originally Posted by rengep View Post
You? Go figure......being of Viking heritage and all. tongue.gifwink.gifsmile.gif
Personally, I have always had a fetish for Redheads.........
"........but that doesn't mean we'll be sharing a warm shower in the wee hours of the morning. "
-- Clint Eastwood - Heartbreak Ridge
rengep likes this.
post #26 of 50 Old 10-03-2013, 05:02 PM - Thread Starter
DMVGamer's Avatar
Hey congrats, I'm trying to get these projects done before my first arrives in Jan.
DMVGamer is offline
post #27 of 50 Old 10-03-2013, 06:04 PM
Liked: 981
Thank you.
I'm enjoying lots of Q-time, and taking a CaCa load of pictures. No shots of CaCa though.
This little Dude has Forearms and hands like Popeye!
superleo likes this.
post #28 of 50 Old 10-05-2013, 10:24 AM - Thread Starter
DMVGamer's Avatar
"Spray booth" put up, skimg coat completed, and primer completed and sanded. Here are a few pics of the parts that I bought and the current progress. Will be spraying screen tonight, let me know if there is anything that looks out of place (sorry for the camera phone pics, I'll get the DSLR out later and take some better picture)
The room:
Wall Masked Off:
Products used:
Texture After Primer:
Looking forward to getting some paint on tonight and the border (velvet wrapped molding) tomorrow.
DMVGamer is offline
post #29 of 50 Old 10-06-2013, 06:28 AM - Thread Starter
DMVGamer's Avatar
And here is the finished product. Many thanks to MM for all the help on this, really turned out spectacular. Photos taken at 8:00am, no curtains up from double door next to projector, 6 recessed lights on in the back of the room. Front lights off. Nothing has been calibrated yet and the framing (4" molding wrapped in felt) should go up in the next week or so as I get time. Also coming is a Darbee Cobalt that is only bound to make things better. Video is a random hi-res youtube video.
I can only imagine how this will look once it sets for a couple of weeks.
DMVGamer is offline
post #30 of 50 Old 10-06-2013, 06:43 AM
Liked: 981
That screen has excellent prospects! If you have any mix left over, after 2 days carefully examine every inch for any excessive spray-induced texture. If noted, and since your "Booth "looks to be a pretty easy one to re-establish due to the Fur Down, a very light "sweep sanding" and 2 more very light Dusters with 70% overlap will give you final perfection. BTW...what level of Colorant did you add?
Congratulations! Your now in the select company of those who chose to spend pennies to the dollar t0 achieve results few others experience.
Reply DIY Screen Section
