Prepping for Glidden Diamond 450 - AVS Forum
post #1 of 10 Old 11-15-2013, 12:12 PM - Thread Starter
mijotter's Avatar
Liked: 58
Greetings, finally decided on going with the Glidden Diamond 450. However, the screen is already painted with a local Home Theater paint that I just did not like at all(2 coats primer, 3 coats top). Everything has been rolled on up to this point and I will roll the Glidden as well. Here are my questions:
1. Should I sand the wall currently? If so how aggressive? Do I sand the theater paint that is on there now all the way off, or just enough to get the wall smooth again?
2. Should I get an additional primer to put on before the Glidden goes on, if so what is recommended?
3. I have standard 3/16" nap rollers. Should I get a microfiber or synthetic one instead?
Thank you.
mijotter is offline
post #2 of 10 Old 11-17-2013, 07:32 PM - Thread Starter
mijotter's Avatar
Liked: 58
Anyone?
mijotter is offline
post #3 of 10 Old 11-17-2013, 09:28 PM - Thread Starter
mijotter's Avatar
Liked: 58
Want to get this started tomorrow. Any advice on the above would be very helpful.
mijotter is offline
post #4 of 10 Old 11-17-2013, 09:58 PM
pb_maxxx's Avatar
white paint on white wall... nothing to it.
unless your wall is an orange peel mess... no need to heavily sand.
if you desire, do a slight sand... smooth to the touch.
roll with your 3/16 nap roller. 2 coats... maybe 3 to be safe... and your done.
if your theater isn't a complete bat cave... then enjoy... otherwise, enjoy the washed out colors.
pb_maxxx is offline
post #5 of 10 Old 11-17-2013, 10:11 PM - Thread Starter
mijotter's Avatar
Liked: 58
washed out colors why? My room is a dedicated 100% light controlled room.
mijotter is offline
post #6 of 10 Old 11-17-2013, 10:21 PM
AVS Club Gold
MississippiMan's Avatar
Quoted: 32 Post(s)
Liked: 200
A simple typo, .as he meant to say: "If your Theater "IS" a complete bat Cave..., then enjoy..... otherwise enjoy the washed out colors. (...and Blacks.)
To quote James T. Kirk;
"I'm laughing at the superior intellect"
MississippiMan is online now
post #7 of 10 Old 11-17-2013, 10:28 PM - Thread Starter
mijotter's Avatar
Liked: 58
Ph ok whew. Ok, so some light sanding to smooth out the wall...again, and paint using the 3/16" roller I have already and no need to primer. Sounds good. One last question. I have heard as far as rolling to do 1 of 2 different techniques:
1. Tiddler's way expressed here:http://s94.photobucket.com/user/tiddlerPics/media/Rolling%20Vids/DownRollingPart1b.mp4.html
OR
2. A simple vertical strip followed by the next strip with a 50% overlap.
My brother even advised me to only go one direction (up) instead of up and down on the same strip...
Which was is recommended with the Glidden Diamon 450?
mijotter is offline
post #8 of 10 Old 11-17-2013, 11:39 PM
Kirnak's Avatar
I wish i could help with the rolling, but I pretty much stick to spraying! That said, I talked to a professional painter I met at Home Depot the other day who raved about how well the 450 rolled. I've rolled sample panels, and it really flattens out well. I would have to say that whatever technique works well for other paints will probably work just fine with the 450. The stuff is spendy, and I believe the primary justification for the expense--for the professional painters who it is intended for--is the ease of rolling.
Kirnak is offline
post #9 of 10 Old 11-18-2013, 12:43 AM - Thread Starter
mijotter's Avatar
Liked: 58
Thanks Nak. I've also been stalking your threads over on HTS with great interest. You and a couple other guys are what sold me on the 450.
mijotter is offline
post #10 of 10 Old 11-24-2013, 08:13 AM
awblackmon's Avatar
Nice to hear a good report on this paint. Glidden has been making some improvements in their paints the last few formulations. I like their paints but the only complaint I have about it is that colour matching from one formulation to another is lacking. I have been using Glidden in a lot of rooms and I have been pleased. Only time I had a surprise was when the new formulation came out and the colour was off when I had to do a touchup.
Alan in Boise
Enjoying films in my home theater room more than I enjoy them at the local cinema. Better bass, better surrounds, better picture. Cheaper popcorn.
awblackmon is offline
Reply DIY Screen Section
User Tag List
